Question about Flotec Pool & Spa
It makes a noise like a bearing problem - Flotec Pool & Spa
    Problem Solver:
  • 13 Answers
The most common problem I have found with pool & spa pumps is that the pump seal wears out, it starts to leak, calcium starts to build up which causes it to squeal. A pump seal is not too too hard to replace. But if your pump is squealing with a "grinding" noise as well, then that sounds like bearings. At that point look for another pump
Posted on Sep 04, 2010
Can cv joints cause noise when braking
No really because there is pressure both ways keeping them from making noise. Usually they make noise when turning(clicking type noise) or them hum at higher speeds. This also sounds like bearing noise. The way to tell the difference is bearing noise will get loader or softer when your are making turns. Axles will have a consistent noise to them. Now bearings will make a noise when stopping.
Mar 01, 2015 | Cars & Trucks
Front end rotation noise
It should have been thoroughly checked. Noises like these on four wheel drives could several different things. A bearing, CV axle, or the differential, or bearings in the differential. A wheel bearing will make different sounds when making a turn. A CV axle is a constant sound. Differential bearings can come and go, depending on if it is a bearing for the axle or a pinion bearing. Axle side bearings usually make a constant noise. The differential can also come and go. Depends on acceleration or slowing down. All these sounds are also with a vibration. Slight to harsh.
Oct 26, 2014 | 2007 Jeep Patriot Sport
Brush makes noise when engaged, I put a new belt
You don't say what kind of noise, but if it is a bumping noise or squealing noise, make sure both ends of the brush roller are clean. It may be binding.
Oct 05, 2014 | Vacuums
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
Drum Bearing
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 | Dryers
Indesitw123 front load washing machine making very loud noise when spinning
The noise you can hear is the drum bearings, the seal between the drum and bearings has failed and let water into the bearings which has destroyed the bearings.
Mar 10, 2012 | Indesit Washing Machines
I changed my clutch and releasing bearing but the noise is still there. When ever i release the clutch the noise starts like the release bearing problem and when i take off in first and second gear there...
a release bearing will make noise when you push on the clutch, the input shaft bearing will make noise when you release the clutch, the transmission will have to be removed and torn down to replace the bearing.
Apr 15, 2011 | 2004 Honda Civic
Hi my rx8 is makin a grinding noise from the gearbox and the noise goes away wen foot is pressed on the clutch makes a noise wen drivin in 1st 2nd 3rd n 4th gear noise goes in 5th and the noise is there in...
What?! Really! The noise goes when the clutch pedal is depressed! So the noise goes when the release bearing (throw-out bearing) is engage? So how would that be a release bearing/clutch problem? If it didn't make a noise until the clutch pedal was depressed, it would be the release bearing! In other words its the input shaft bearing and/or counter shaft bearing in the gearbox. Stop giving people bad advice
Mar 11, 2011 | 2004 Mazda RX-8
Car make noise, look like is left wheel bearing or transmission. When turn right noise dissapear. When car is risen on stands , noise only when left wheel is turning. It is wheel bearing or transmission...
Check the CV joint that the axle connects to. They make a clicking sound when turning a corner if badly worn. Both CV joints are commonly replaced when one of them goes out.
Sep 08, 2009 | 2002 Mazda Protege
5-speed transmission making noise in 3rd and 5th gear
are u sure the alignment (side to side, up and down) of the trans on the bell housingis not out of spec, that will burn the bearings out very quickly.
May 04, 2009 | 1998 Ford Ranger SuperCab
Loud noise when dryer runs
Two items on two different dryers can make this noise. One is the belt tensioner pulley and the other is the bearing on a Frigidaire dryer.
Sep 27, 2008 | Dryers
Pool & Spa Logo
333 people viewed this question
Top Flotec Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Flotec Pool and Spa Expert? Answer questions, earn points and help others
