Question about Canon PIXMA MP160 All-In-One InkJet Printer
How to install the cartridge - Canon PIXMA MP160 All-In-One InkJet Printer
  • 6,831 Answers
Hello
Have a look HERE.
It should solve you problem.
Kind regards
Andrea
Posted on Sep 04, 2010
How do you install cartridge in z82 printer
To install the cartridges, please follow the steps given below:
1. Press "Setup" until "Cartridge" appears on the display.
2. Press the "Right arrow" button until "Change cartridge" appears on the second row of the display.
3. Press "Enter/Select." Now you may install the cartridges in the cartridge carrier.
4. Press "Right arrow" to select the color cartridge type that you installed, once "Left Cartridge?" appears on the display.
5. Press "Enter/Select."
6. Press "Right arrow" to select the black cartridge type that you installed, once "Right Cartridge?" appears in the display.
7. Press "Enter/Select."
An alignment test page should print if "New Cartridge" is selected.
From
Jeethu
Sep 15, 2010 | Lexmark Color Z82 InkJet
Whats the meaning of error in canon e5 error?
"E5: The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur."
Jul 22, 2010 | Canon PIXMA MP160 All-In-One InkJet...
SCREEN READS "INSERT RIGHT CARTRIDGE" ONLY THE COLOR CARTRIDGE IS LOADED. CAN'T I STILL GET IT TO PRINT??????
No..! you need to install the black cartridge..!
The printer needs to be aligned with both the cartridges no matter if they are empty or full. So even if the black cartridge is empty and the color cartridge is full. The color will print and the black wouldn't.
But if you install only one cartridge it will not work as i said that the printer could not align to the cartridges unless both the cartridges are installed.
On some printers if you install the black one only it works. Without installing the color one. But on this printer It is mandatory to install both the cartridges together other wise it will give you error codes.
This model needs the cartridges to be aligned and then print and if you see inside the printer it has a carriage holder for two cartridges which moves back and forth to print.
So install the black cartridge and it will work perfect.
May 11, 2010 | HP OfficeJet 6110 All-In-One InkJet...
How do I align ink jets?
Microsoft Windows 95/98/Me:
(Applies to all printers)
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Nov 13, 2009 | Lexmark JetPrinter Z11 InkJet Color...
I installed a new print cartridge into my printer... after installing the new cartridge "install print cartridge" window prompt shows "unsupported cartridge" and instruct to install a correct print...
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Oct 12, 2009 | Dell 810 All-In-One InkJet Printer
I can't install a new cartridge in my printer.
Turned computor off, and only printer on. Carriage stopped right in the middle to allow installation!
Oct 02, 2009 | HP Office Equipment & Supplies
I want to install ink cartidges and do not know where to begin. I have misplaced my instructions
To install your Brother machine#s ink cartridges, follow the steps
listed below:
1. Make sure that the Brother machine#s power is turned on.
2. Open the ink cartridge cover. This cover is located on right-hand
side of the Brother machine#s front panel.
3. Pull down the four lock release levers. There is one lock release
lever for each ink cartridge.
4. Take the ink cartridge out of its protective bag.
5. Carefully remove the yellow protective cap from the ink cartridge.
- DO NOT touch the side of the ink cartridge covered by the yellow
protective cap.
- Take care when removing this cover to prevent spilling ink and
staining your hands and clothing.
- If the cartridge cover comes off when you open the bag, the cartridge
will NOT be damaged.
6. Install each ink cartridge in the direction of the arrow on the
label.
- Please note that each color has its own specific position. These
positions are indicated by the colors of the four lock release levers.
Do not install an ink cartridge in the incorrect position, as this can
cause print quality problems.
7. Lift each lock release lever and push it until it clicks into the
closed position.
8. Close the ink cartridge cover.
- If the LCD shows #Install Black,# #Install Cyan,# #Install Magenta,#
or #Install Yellow# after you install the ink cartridges, please verify
that you have installed the cartridges correctly.
NOTE:
* DO NOT remove the ink cartridges from the Brother machine unless you intend to replace them. If you do, it may reduce the quantity of ink left in the cartridge, which may cause the Brother machine to miscalculate the amount of remaining ink.
* DO NOT shake the ink cartridges. If ink stains your skin or clothing, wash the affected area with soap or detergent immediately.
* DO NOT repeatedly insert and remove the ink cartridges. Doing so may cause ink to seep out of your cartridges.
* If you mix the colors by installing an ink cartridge in the wrong
position, clean the print head several times after correcting the
cartridge installation.
* Once you open an ink cartridge, install it in the Brother machine and use it up within six months of installation.
* Use unopened ink cartridges by the expiration date listed on the
cartridge package.
* DO NOT dismantle or tamper with the ink cartridge. Doing so can cause ink to leak out of the cartridge
Apr 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
Installation of the cartridge for Canon Pixma iP1600 printer
To print normally, install or remove ink cartridges in an orderly procedure.
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
cartthingsnottotouch.jpg3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
ip1600puttinginink.gif4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Jan 06, 2009 | Canon PIXMA iP1600 Printer
How to change lexmark Cartridge
      3. Click OK.
Dec 09, 2008 | Lexmark X1150 All-In-One InkJet Printer
How to remove drum unit from kyocera fs 1920
Installing the Toner and Drum Cartridges
bullet.gif Installing the Toner Cartridge
bullet.gif Installing the Drum Cartridge
caution.gif CAUTION: Before performing any of the following procedures, read and follow the safety instructions in your Owner's Manual. Installing the Toner Cartridge Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier will not rotate).
  1. After confirming the Insert Yellow Toner (Y)message, open the front door.
  1. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
note.gif NOTE: You need to remove the protective cover only the first time that you install the toner. note.gif NOTE: Dispose of the protective cover after you remove it. note.gif NOTE: The protective cover is attached to each toner cartridge mount. mag_cover_5.gif
  1. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
  1. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
  1. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
  1. Close the front door.
note.gif NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly. close_front_cover.gif
  1. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
  2. Repeat steps 1 through 7 when inserting the remaining cartridges.
  1. When the Insert Drum or Insert Drum Cart message appears, open the front door, then lift and push back the top cover.
  1. Remove the protective sheet from the drum cartridge.
  1. To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
  1. Pull down the lever on the right to lock the drum cartridge in place.
  1. Close the top cover, then the front door.
note.gif NOTE: After installing the drum cartridge, the printer makes an adjustment for about one to two minutes. Do not turn off the printer during this time.
Aug 04, 2008 | Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
15 people viewed this question
old marine
old marine
