Question about Linksys Wireless-G WRT54G Router
I have fast access DSL Service and I cannot get the wrt54g router to hook up any suggestions?
  • 21 Answers
Go to your Start Menu and then to Run.
In the Run box, type cmd and hit Enter to bring up a Command Prompt.
In the Command Prompt box, type ipconfig
Write down the value next to default gateway.
Hook your computer up to the router using an ethernet cable. Power it up and you should see the lights on the router. To enter your router configuration page, type in the default gateway number.
You will be prompted for a username and a password. Leave the Username field blank and enter admin in the password field. (Please consult your router documentation for the default username and password.)
Click "Ok" to continue.
In the setup you will have to put in your host name and domain name and few other settings provided by your network provider depending on your network.
Then select save settings.
Posted on May 11, 2008
    Guru:
  • 1,342 Answers
Here's the D-Link support site
It will help you set up your router.
Can you hook up dial-up to a dsl modem
Can you hook up a dial up what to a dsl? A modem? No, you need a dsl modem for a dsl line. Typically, a dial up is POTS (Plain Old Telephone Service) and connects to a POTS 56,000 K modem. DSL will run much faster but not as fast as cable.
Jun 05, 2011 | Computers & Internet
Trying to hook-up a wirless router (Linksys WRT54G) to a SpeedStream 5100 for PS3 gaming on-line.
Before we configure router with PS3, we need first to make sure router is already configure to work with DSL modem. In Setting-Up a Linksys Router Using DSL Internet Service just click this link for reference.
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=7a7ce39e35c34b5a9f641429eddc075f_4521.xml&pid=80&respid=0&snid=1&dispid=0&cpage=search
And for PS3 configuration to connect wirelessly to a wireless router, just access the link below
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=6dd5053ce9dd47ef9a78dd0623966bec_20556.xml&pid=80&respid=0&snid=3&dispid=0&cpage=search
Cheers,
Aimee
Dec 22, 2010 | Linksys Wireless-G WRT54G Router
Wireless router disables fast access dsl
it may have corrupted firmware, try uploading newest firmware from manufacturer site and upload by wire trough GUI
Sep 13, 2009 | Linksys Wireless-G WRT54G Router
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
After successful instn of my linksys wireless router i cannot access to wireless online connection
Whenever you connect a different device to the cable/DSL modem the modem itself must be reset. Dont even waste a phone call to linksys. Its useless.
If you are using DSL depending on your ISP you may have to enter your account info into the router's PPoE section
Cable users should have the router set to "Obtain IP aadress automatically"
Use the reset button on the back of the router and start from scratch.
Unplug the cable/DSL modem power
Hook up your router WAN/Internet to the Cable/DSL modem Ethernet/LAN jack
Power on the Cable/DSL Modem first, wait about a minute, then power on the router.
Sep 25, 2008 | Linksys Wireless-G WRT54G Router
Problems
Yes, you've got a "broadband" router... won't help much with dial up..
Sep 22, 2008 | Linksys Wireless-G WRT54G Router
Hooking up wireless linksys
From ethernet of embarq plug it to the Internet port of Linksys. Your PC should be connected to port 1 of Linksys
Aug 17, 2008 | Linksys Wireless-G WRT54G Router
Linksys router
unplug your DSL modem. Wait 30 seconds and plug it back in.
Make sure the router is connected to a DSL modem. Lately I have seen DSL modems connected to offices that are really routers. If thats the case it may not be talking because the DSL is address the gateway with the same address as the router.
The best way to test this is to see what happens when you disconnect your linksys router and type in http://192.168.0.1
in internet explorer.
If the DSL modem screen appears, it's configured as a router.
Then you will have to take the linksys router and turn it into a switch with a wireless access point. I
Jul 14, 2008 | Linksys Wireless-G WRT54G Router
WRT54G
Make sure that the WRT54G has an internet signal coming in. Is the other DSL router have a wireless component to it? How are you wiring everything? How many ports does your DSL router have? If only one, go from the DSL router to the wireless router. Plug in your phones (VOIP) to the WRT
May 23, 2008 | Linksys Wireless-G WRT54G Router
Cannot connect with ATT modem
Connect your pc to the ATT box. If online, check the ip address of the computer. If the ip address is 192.168.1.x, then you just have to change the router ip address. The wrt54g ip is 192.168.1.1, it may be having conflict with the ATT modem. Change the wrt54g ip to 192.168.2.1
Good Luck
Mar 05, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
35 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
