I have a Whirlpool Duet Washer WFW8300SW and keep getting error code f 25. Last week tech came out and removed something from drain, seemed to work fine afterwards. Now have error code F-25 again. Please advise.
    Genius:
  • 1,073 Answers
Could still have resriction in the machine that was not totaly removed
Posted on May 11, 2008
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
The washer shuts off by itself, a message of "F21" appears on the screen. It happens twice last week. Thank you for your help, Autumn Lin
Hello Autumn,
The F21 error code means the pump has taken longer to drain the water than usually time it takes to drain. Here is what you check to see if something is in the drain pump filter restricting the water flow into the pump. I know i have the Whirrpool Duet washer pictured . Whirlpool makes that washer so other that the name "duet" everything is the same
The most prominent cause of your DUET washer not opening after the cycle is done and door remains locked is going to be a blockage in the drain pump. Here is what to check in the pictures below.oldtech2332_3.jpgoldtech2332_4.jpgStart by unscrewing that just a little and use towel/tupperware tubs and catch the water that will come out. Once all the water is out remove completly and check for a blockage
Aug 18, 2011 | Maytag MHWE300VW Washer
Whirlpool duet sport model WFW8300SW Have error F-22 and F-28, how to solve it? Thks
Relates to an electrical/electronic problem
Try the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer getting a f21 code.sems water not empting
"F21" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. In most cases, this means you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
You may have something getting caught in the pump impeller and slowing it down. Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
NOTE: The "SUDS" error can commonly occur with the F21 error code as this is can be generated when air is sensed in the drainage system.
If the door won't open it could be jammed due to the program being interrupted.
If you have questions about this repair, or require additional assistance, please let me know. I hope this helps you.
NOTE: If replacing the drain pump is required, the following link explains how:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
For troubleshooting guidance, the washer comes with a technical data sheet. It should be located behind the lower toe panel directly below the door. If not located behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes diagnostics procedures, troubleshooting tips and the error code list.
Nov 25, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Model #WFW8300SW Error code F then 20, what does it mean ?
does it do this a lot dont rate me till were done give me your complete model number
Jan 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
212 people viewed this question
Top Washing Machines Experts
