Question about Waterway 1 HP HiFlo Above Ground Pool Pump
I have a Waterway Hiflo 2hp and lately is kind of loud. Do they need like oil or some kind of maintenance? Thanks
  • 990 Answers
More often that not you probally had a leaking seal and the water is causing the bearing to rust and make noise. At this point you will need to have the motor rebearingd or get a new motor. depending on the age and condition of the one you have.
Posted on Sep 04, 2010
Pool pump makes a loud noise
bad bearings change pump and motor
May 14, 2014 | Waterway Impeller Pump 2HP SD WW
I just got a 2hp Waterway 48 hiflo pump. The discharge is facing up can it be rotated to the side or is it fixed?
There a four bolts that run through the motor into the wet end, or pump. Use a 1/4" nut driver and loosen the bolts until they are free of the wet end, then you can rotate the wet end so the discharge is face to the side. Tighten the bolts and your done.
Sep 07, 2013 | Waterway 1 HP HiFlo Above Ground Pool Pump
Rotate waterway hiflo wet end pump
take off basket then unscrew then turn to position
May 25, 2013 | Waterway 1.5hp Hi Flo Above Ground Pool...
I need to know the pressure the pump should be at when on i have an aboveground pool with a waterway pump.
There is no standard pressure your pump should operate at. Instead it will vary based upon the hydraulic load of the system and it's components. A range common to AG pumps/filters is between 10 and 16. As the filter gets dirty it will rise over time and then you'll need to clean the filter. A rule of thumb is 8-10 pounds over the 'clean' pressure you should clean the filter.
John
Jun 28, 2011 | Waterway 1 HP HiFlo Above Ground Pool Pump
We have a 3 yr old 2hp waterway pool pump that is making a very loud noise. It is still working but the noise is constant.
I have a 3 year old pool pump, waterway. I can hear the motor humming but the fan wont kick on. I pulled all hosed to make sure they were cleaned out. Any ideas why it would be froze up?
May 08, 2011 | Sport & Outdoor - Others
I have a Waterway 48-Frame 2HP 115v pool pump for my above ground pool. I just purchased it about 2 weeks ago from Rec Warehouse. It was working good no problem for about a week and half then all of of...
Check to see that the pool pumps mounting is secure. Loose mounting could cause the motor to run loudly. It could be bearings rubbing or a bent shaft. If it is new, this should not have happened. If you check the mounting and feel that it is secure, I would return the pump to an authorized Waterway service agent and let them look to see if the bearings or shaft are damaged. I would do this quickly while you can still return the pump if its defective.
Jul 04, 2010 | Waterway Spa Pump (Side Discharge) 1 HP...
Waterway 1 HP HiFlo Above Ground Pool Pump Logo
315 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
