The other day the water company was digging in our yard to fix a water leak and they hit the power line and it blew a couple of breakers in our house. one of those was for the computer and ever since then the computer won't turn on.
    Sergeant:
  • 222 Answers
They spiked high voltage and probably blew your motherboard. But possibly only the power supply. Higher quality one's have a fuse, check that. If you plug pc into a power strip check that fuse. Look at mobo and see if you see any burned capacitors. Depending on mobo it might have a fuse check that. If all else fails try a CMOS reset and see if it screwed up the BIOS.
Posted on Sep 04, 2010
Turned off power at breaker to water heater to fix a water leak under house. Turned power back on and no hot water..do I have to hit reset or something?
If it is a Gas Water Heater, you need to relight the pilot. If it is electric, I have never seen a reset on a tank. There is just the single or double element and a thermostat.
Check the breakers again, sometimes they look closed but they are slightly away. Pull the breaker on the heater all the way off and then all the way on until it clicks.
Dec 18, 2016 | Water Water Heaters
How deep to dig a french drain side of a driveway
It all depends on the soil conditions, you want to consider the size of your gravel that you use for your french drain and next thing is,
few days before you start to dig your drainage make sure you should contact your local utility company and driveway contractors. Recently, my husband and I just moved into a new house in Long Island area, and I wanted to install a French drain which would help me to hold water. So I got in contact with the local utility company and driveway Long Island contractors to have all the underground utility lines of our property which are located and marked.
Apr 11, 2015 | Plumbing
Timers problems
The lights are leaking power to the ground or to water nearby. When this happens the breaker trips to stop you losing more power. Look at the wires for the lights are they damaged, or has water got in anywhere?
Dec 20, 2013 | Hardware & Accessories
We have a primo water dispenser, model # 900183 and the water is dispensing as one slow stream not a fast full stram of water as it use to. how do we fix that?
Had the same problem. I tried cleaning it as instruction on the copany website with bleach and water. I also unplugged it for a couple of days to see if the lines were frozen. Finally out of frustration I put my mouth on the water dispenser, pushed the button, and sucked some water out and spat it out. After that I did the same thing again but blew into it instead. I did this a couple of times and my water dispenser went from a trickle to flowing like the day I first got it. Also, you should probably clean the water dispenser after doing this, just saying.
Apr 27, 2013 | Refrigerators
Hot water heater water, went out main line of house that enters house
You did smart thing turning off water and gas.
Play it safe.
Your water heater will NOT explode.
Conduct routine maintenance so water heater lasts longer. If plumber says you need new heater, then post question on fixya and include information showing on tank label on side of tank.
Also include why plumber says to replace.
Get another plumber.
Call city utility company to determine source of noise.
Dec 01, 2012 | Whirlpool Water Heaters
The 3/4" main water line has a leak and needs to
Hi. I seriously doubt that you can avoid digging a new trench.
Aug 01, 2011 | Plumbing
Leaking under ground pipe what water company says..........cant find a leak . grounds not wet any where no water under the house .how can i find the leak with out a plumber? cant afford one....lol
this sounds like a joint is leaking just but not enough for the water to surface try digging the main line from the meter to the house be careful not to damage any lines under the ground and mind any gas and electric lines. once you find the water line out of the meter trace it to the house as soon as you start digging into mud your gitting close to the leak. once found remove dirt so that repairs can be made
Dec 12, 2008 | Plumbing
Water heater problem (no leak on floor)
shut off the power to the hot water heater wait 5 to 15 min. If the noise stops it is the water heater eating up electricity. Turn it back on if noise starts again feel about 5 or so feet down the hot water line. If this line is hot you have a leak beyond the hot water heater. If you still hear it when the power is off to the water heater. next turn the water off on the cold water line at the water heater with the power off also Look at the water meter and see if the hand or wheel on the meter is moving and it should no be. Also think if the breaker to the hot water is off the electric meter should practically stop if no refrig oe anything else on. Have someone watch the electric meter and switch 1 breaker at a time leaving the one you just shut off in the off position until you cut them all off. Should the meter still be moving you have a main service cable shorting somewhere call the power company to advise you further if this is the problem.. Should just cutting the circuit breaker for the hot water heater stop the noise and down the hot water line is not hot then you are probably wasting power due to a thermostat or element inside the hot water heater.. Thank you j
Nov 23, 2008 | Ruud Central System Air Conditioner
Broken or leaking under ground water line
Norm, I expect you will find a one inch or three quarter inch pvc line running from the meter or pump to your house. If you dig fie feet fore and aft of the affected area you should have enough flexibility in the lines to make the repairs. Yoou will probably nee two to three slip by slip couplings and a tee and elbow of the appropriate size and a short length of pipe. It really depends on where the break is but more then likely it has occurred just behind the hub of the tee. You can possibly gain enough flexion in the lines to reduce parts cost but remember putting something in a state of stress already will greatly increase the possibility for future failure in the area again. Below is a picture of what I think you will find aand how I the repair will look.183cf5d.png
Sep 29, 2008 | Plumbing
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
