Where do you fill it with water, can't find the filling hole
  • 24 Answers
Fill what with water?
Posted on Sep 04, 2010
Tank is not filling but water come from bottom pipe
There is possible hole in tank water runs down inside tank out tube tank will not fill past hole in tank
Jun 06, 2016 | Water Water Heaters
Kitchen sink hole fills up with water when using the washing machein
After washing cycle all the water flows immediately from tub to drain pipe. If the flow capacity of sink is slow sink hole fill up with water .
Connect washing machine drain to proper place for drainage.
Oct 05, 2013 | Washing Machines
Washer not filling with water
sounds like a defective pressure switch that is just a spdt pressure operated switch and its stuck on the timer side of this switch and can't switch back to the fill side of the switch to fill the machine first before starting agitation,check voltage from the water fill wire off this switch for line voltage,then check from the wire on this switch to the timer for line voltage,probably no voltage from the water fill valve wire so it can't fill
Feb 21, 2013 | Kenmore Washing Machines
A stink bug climbed in the water chamber and we can't get it out. is there a solution?
Slowly fill the water tank with water. The stink bug should rise to the surface. Continue filling slowly and the flow of the water out of the fill hole should force the stink bug out! Remember as you're filling you must use something that will NOT block the fill hole or the water cannot drain and your "little friend" won't be able to be flushed out by the flow of the water.
I hope this helps!
Mar 07, 2011 | Rowenta Professional DX8800 Iron
Top loader washing machine does not fill up
very simple, your drain hose is below 4 ft, your drain hose should go in the hole between the hot and cold water, if you dont see a hole then it is covered, you need to knock out the hole...
Nov 10, 2009 | Washing Machines
Water continues to fill and overflows
1.Drain hose is too low. Minimum 30 inches from the floor.2.Water fill valve is defective. If it fills with timer set to OFF,replace the water fill valve.
3. The Air hose from the tub to the water level valve is pinched or stopped up with soap scum. Check the air hose for a pin hole,pinched or obstructed..
Jun 27, 2009 | Whirlpool Washing Machines
Fill up hole
i think this is related to the car that will not start maybe i meant to say fuel pump fuel tank fill up
Jun 22, 2008 | 1994 Chevrolet Caprice Classic
Our washing machine keeps filling with water and overflows. It will not stop filling with water no matter what setting it is on.
ck for stuck open fill valve ..with power unplugged does it keep filling if so valve if overfills only during fill cycle ck waterlvel control and associated hose to side of tub look for kinked or otherwise pluged line also possible pin hole in line
Apr 26, 2008 | Washing Machines
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
