If you have a 315MHZ LiftMaster Garage door opener do the following:
Follow the purple wire (Antenna) up and you will see a square purple button.
Press and hold the square purple button for ten seconds until the amber led goes out.
Press and release the purple button one time (The amber led will come on solid).
Press and hold the button on the garage door opener remote control for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
to program the wireless keypad do the following:
Enter a four digit code into the keypad then press and hold the enter button for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
Sounds like you have a chain drive garage door opener and you hear a humming sound when you push the wall console. The motor is running but the chain does not move. You need to replace the gear & sprocket assembly.
The specifications that you need are the model number off the opener. Then check the yellow pages for a Liftmaster or Chamberlain dealer. They will help you in a heart beat.
I know that that is a lift-master opener. chamberlain owns lift-master. but if its a new opener your looking for try the lift-master 3800 jack shaft opener. it features a low profile design that mounts next to the door instead of on the ceiling above the door, and also incorporates a battery backup so that you will never be locked out again.
The most common cause of this problem is a bad wall control the wiring going to it. You can eliminate both temporarily by removing the wire at terminal 1 on the back of the motor unit. The wiring sometimes is shorted by the staples the installer uses. The wall control gets used a lot.
The keypad outside has manuals online that you could use, but for simplicity, Have someone go to that back of the machine and press the "Learn" button, once its is pressed, the yellow light should blink. Enter a new code (4digit) into the keypad and press the enter button. You should then hear a click and the lights on the machine should flash. That will program your keypad.
