Question about LG Xenon GR500 Cell Phone
I have an LG Xenon and everytime I press "1" it says voicemail number not entered. How do I check my voicemail now?
4 Suggested Answers
SOURCE: Accessing Voicemail on LG KS360?
I had the same problem and I read the post from
Z1G ZA9, and that solved my problem. To give you step by step, because i had to search thru the fone and find the DTMF option, so here it is, and again a big thanks to Z1G ZA9. 1.press menu button 2.select "settings" 3.select "call" 4.scroll to bottom and select "send dtmf tones" and make sure they are on.
Posted on May 29, 2009
  • 53 Answers
SOURCE: how do I make a voicemail tone on the lg xenon?
okay call your voicemail which you can do automatically by holding down the one.Then you need to do option 4 which will get you into personal options and then option 3 which you can select before the voice says, and then next option 1 and then 3 and then record your personal greeting. After you are done press pound if you like how it sounds if not press star to make it better. Hope this helped
Posted on Aug 25, 2009
  • 106 Answers
SOURCE: I can not set up my voicemail on the lg Xenon How
you have to press and hold down 1 & then follow the directions
Posted on Feb 18, 2010
How to unlock the lg xemon (instructions)?
You can Unlock the LG XENON GR500 model Phone using the Unlock code,You can get the Unlock code and instructions from here
Classicunlocking.com and Unlock it from Network Lock....
LG GR500 Xenon Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your LG GR500 Xenon mobile phones. If you enter over a certain amount of wrong unlock codes on your LG GR500 Xenon mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your LG GR500 Xenon with a NOT ACCEPTED* SIM Card.
2 - LG GR500 Xenon will display "phone restricted" Select "Cancel".
3 - LG GR500 Xenon will display "phone restriction code" Enter the Unlock code. Select "OK".
4 - The handset is now successfully unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your LG GR500 Xenon is locked to.
(OR)
1 - Switch ON your LG GR500 Xenon with its ORIGINAL SIM Card.
2 - Enter2945#*9701#.
3 - A menu will pop up, Select Sim Unlock.
4 - Enter your Unlock Code and press OK.
5 - The LG GR500 Xenon will then reboot and the unlock is complete.
ORIGINAL: We mean, to use the sim card that was originally given to you by your network/service provider along with the LG GR500 Xenon.
(OR)
2 - Type *#865625#.
3 - Enter the unlock code twice.
4 - LG GR500 Xenon should say: Network Lock Deactivated.
5 - LG GR500 Xenon may automatically reboot and is now unlocked!
Aug 03, 2011 | LG Xenon GR500 Cell Phone
When someone calls me my phone does not ring but alerts me that I have a voicemail. It is going straight to voicemail.
check your incoming calls settings and see that you did not choose it to divert to voice mail number
Mar 28, 2011 | LG Xenon GR500 Cell Phone
How do you set your voicmail on the lgneon
To set up voicemail, push and hold the number 1 key until it dials into your voicemail box, then listen and follow the prompts to create a password and leave a standard or custom greeting. If this doesn't work, contact your carrier to reset the voicemail on your account. Hope this helps!
Jun 20, 2010 | LG Neon GT365 Cell Phone
I cant acess the voicemail from my LG xenon phone but i can access it from any other phone. can you pleas help why this is happening?
Your voicemail number on your phone is usally different than your own number. It's called a "retrieval number" which your provider has. You will need to contact them and get this number and they should be able to assist you with reprogramming the number into your phone. Hope this helped.
Apr 13, 2010 | LG Xenon GR500 Cell Phone
Where do i go to reset my greeting for voicemail
you press and hold down the #1 button on you & then your phone should say "calling voicemail" & then you just follow whatever instructions it says to access your voicemail. hope this helps:)
Feb 25, 2010 | LG Xenon GR500 Cell Phone
I can not set up my voicemail on the lg Xenon How does it work?
Jan 31, 2010 | LG Xenon GR500 Cell Phone
Its about my lg xenon cell phone . i broke my lcd
well with the voicemail,go to more settings, call fowarding then all voice calls. it will tell u what ure number sould be if you reset it =)
Jan 21, 2010 | LG Xenon GR500 Cell Phone
UNLOCK LG XENON PHONE
Unlocking LG Xenon step by step:
-1 After turning on your mobile phone, press: *#865625#
-2 Press Yes to continue.
-3 Enter the 16 digit Subsidy Unlock Code
-4 Enter the 16 digit Subsidy Unlock Code again.
-5 Device should say: “Network Lock Deactivated”
Dec 06, 2009 | LG Xenon GR500 Cell Phone
How do I make a voicemail tone on the lg xenon?
Aug 20, 2009 | LG Xenon GR500 Cell Phone
When you press numbers do they appear on screen as if you had pressed?
Is it that when you press a key your voicemail just does not respond to the option number you pressed?
If the answer is yes to these it sounds like you have turned off DTMF tones. If it is off, key presses look like they work but actually the phone is blocking the tone for that button from being sent down your line. People sometimes turn off by mistake or to stop their mobile number being visible when calling someone. If you look in menu and make sure DTMF tones are ON it should solve your problem? Hope that helps?
Apr 26, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
LG Xenon GR500 Cell Phone Logo
53 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
