I have just installed and have HS on indoor unit
  • 1 more comment
  • deanbrooks1 Sep 04, 2010
    The air conditioner starts then stops and has " HS" where tenp reading should be.
    So what does "HS" mean
    On Further investigation. IF I hit the mode button 5 times it goes Hl,HL,HL HL HL then 26
    Continue to press HL HL HL HL HL 26
    My other unit changes to different icons eg snow flake
    Hope this makes it clearer for
    you
  • deanbrooks1 Sep 05, 2010
    thank you,
    I am a Spa repairer fixing Pc boards on a daily basis. I have a good understanding.
    Voltage good
    Wiring rechecked. Good
    I installed 2 units at the same time so I cross referenced and all Ok
    Any thing else you can suggest.
    I have all testing equipment for anything I could Try
    Thanks
    Dean
  • 944 Answers
Note:wiring connection is wrong or proper volt is not being supplied.
Hello sir please don't swirtch on your Air Conditioner.There is some short circuit happening in your system.Check weather proper volts is flowing into the A.C.Some sort of wrong connection is being done which will cause the system warranty to be void.So please call the service engineer to work on it.I can help you out in this but you need proper hands on in it.
HL-High Limit (Float Switch) means Float switch Open circuit Off.Drain pump / Float switch-Float switch Open circuit (High level water alarm).
HS means -Heat Sink Sensor Temp. High-Heat Sink Temp. High-Open / Short circuit.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 04, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 05, 2010
    Have you checked -Heat Sink sensor and drain pump then that could be the problem
    Is this a new Air Conditioner or Old one.Officially HS refers to this sensor issue.Open the A.C check the board are ok.DO continuity testing.So you can find out the cause if its the board problem.
    Top Expert:
  • Heating & Co... Master
  • 75,797 Answers
I am sorry but I don't see any question here.
Model WS9611UN-IT - I am unable to receive the outdoor temperature. I have changed the batteries on the outside remote but I still do not receive the outdoor temperature. How can this be corrected
Remove all batteries, both outdoor and indoor. Install batteries in outdoor unit and wait for it to begin sending a temperature signal. Install batteries in indoor unit. You should see outdoor temperature displayed. If not, batteries, transmitter, or indoor unit may be defective.
Nov 16, 2016 | Measuring Tools & Sensors
Out do I get the outside temp back.
You have to remove all batteries, both outdoor and indoor. Install replacement batteries in the outdoor unit. Back indoors, install replacement batteries in the indoor unit and wait for temperature to be displayed. If nothing happens, the outdoor unit may have failed.
Jun 17, 2016 | Measuring Tools & Sensors
36VDC Indoor split in a 240VAC country
if you use the correct inverter and transformers
best if you just get new units designed to run in that country
Jun 23, 2017 | Heating & Cooling
I have a contractor that wants to install a 36000btu outdoor unit(model # mh080fxca4a) and two indoor 18000btu indoor units(model #mh052fnca). What would be the output of the outdoor unit? The contractor...
Yes it rated for a maximum out put of 36,000 btu (3 ton) with the right indoor fan coil units which based on the model numbers should give the 36,000 btu's combined when both fan coil units are on, otherwise 18,000 btu's (1.5 ton)per fan coil.
Aug 23, 2011 | Samsung Heating & Cooling
Have had panasonic re 12kr split airconditioner installed today and the installer didnt know how to wire the indoor unit to the outdoor unit.Because there is an extra cord on the indoor unit?
The power is supplied by wiring directly to the outdoor unit. The extra cord is not needed (just an extra they put in with the package).
Hope this helps(the installer) James
Apr 06, 2011 | Heating & Cooling
There is water coming out of my indoor unit. So much water that I had to shut off the ac unit. It is a Mitsubishi Mr Slim split type air conditioner/heating unit
water coming out of an a/c is normal .its water outlet hose is wrongly installed or not installed at all.get it installed.also level the indoor unit towards the water outlet side when u install the hose .
Aug 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Genius HS-03U Volume Control Help
It's not fixable.
Set as default audio unit to "USB audio device", because Genius HS-03U control the volume only sound device by default.
Headphones improperly trying to adjust the volume of "alien" audio devices, such as second sound card, if it is selected as the audio output device by default.
Oct 20, 2009 | Genius HS-03U Headset
Steamed up windows carrier humccsbp2412-a
it should not run while the fan on the furnace isnt running and if the humidity in the house is higher then the setting on the humidistat(HS). If he mounted the humidistat on the duct you need to make sure he cut a hole to allow the HS to sense whole house humidity thru the return air duct. if you turn the knob on the HS if you listen closly you should hear it click indictacting the humidity level as you raise the dail when you go above the indoor hum it will click and the humidifier should turn on and vise-versa. if it doesnt turn off /on when you hear the click then its wired wrong.
Sep 25, 2009 | Carrier LBP Humidifier
Carrier Model No 42NVQ007MM inv, NO Heat output
unit should be locked out on low temp and your electric heat should be running. is your installer a service tech or just an installer that could also be the problem if he is a service tech it would work correct when he left
Jan 31, 2009 | Carrier Heating & Cooling
Mitsubishi wall unit srk50zg condenser src50zg air con not heating new install
Double check your wiring .if the indoor fan is not blowing then you either have an electrical issue OR bad blower motor .
May 24, 2017 | Refrigerators
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
