Question about GE Dryer Repair Video Older Models
MY Dryer has no power to it. It is not the breaker.
  • GE Master
  • 2,534 Answers
Find someone with an electric multi-meter or an ohm meter and have them locate your problem. You can do this yourself, get someone to teach you how. You will need to take the back off the machine, or, depending on the model, remove the front and the top.
Be blessed.
Posted on May 22, 2014
I have a whirlpool electric dryer.. when I turn it on its been having a problem with staying on or not heating at all. It will spin and stay on but no heat.we have changed the element and it seemed fi
Sounds like a tripped circuit breaker in the power panel for the house. The breaker for the dryer is actually 2 breakers connected together so if one trips so will the other. Sometimes this does not happen and only one breaker trips. This condition removes power to the heating element but still supplies power to the rest of the dryer. Check to see if the breaker will reset by turning off and back on several times. Then check the power receptacle that the dryer plugs into with a voltmeter set to read 240 volts AC. If no 240 but 115 is present then replace the circuit breaker.
Nov 19, 2014 | Whirlpool Dryers
How to replace a fuse in a hotpoint
Check the circuit breaker for the plug the dryer uses. Open your house power panel and locate the breaker for the dryer. It will be 2 breakers connected together by a metal pin so when one trips it will trip the other. This shuts off 240 volts. Sometimes only one breaker will trip without tripping the other one. This leaves the dryer with 115 volts to work the rest of the machine but won't power the heating element. Replacing the breaker will fix the dryer.
Nov 17, 2014 | Hotpoint Dryers
No power to the display, dryer will not turn on
First thing you need to do is check the Circuit Breaker for the dryer. If it is tripped unplug the dryer and reset the Circuit Breaker. Now plug in the dryer and try to run it. If it does not work again check the Circuit Breaker again if it is tripped again unplug dryer and call someone that can help you or fix it. If the Circuit Breaker is not tripped check for good power readings on both power lines coming into the dryer. Should have 110V or more on each line to neutral, and 220V or more between each line. If you do not have the correct voltage at each line check Circuit Breaker for good power coming out.
Mar 13, 2014 | Maytag MDE9700AYW Neptune 174 Electric...
SHORTED THE DRYER BY TOUCHING WIRE TO BODY, THERES POWER INSIDE THE DRYER(LIGHT ON), BUT NOTHING HAPPENS WHEN SWITCH IS ON, CONTINUITYIS GOOD ON START SWITCH, WHERE DO I GO NOW
Power to the dryer is 220 volts, with half of the total voltage supplied by each of two breakers. The breakers are combined into one larger breaker, but each side of the breaker connects to a different buss bar in the breaker box. What it sounds like is that one half of your breaker is tripped, and the remedy is to trip the double breaker in order to reset the half that is tripped. If tripping the breaker off and back on does not restore the operation of the dryer, trip the breaker back off, unplug the dryer, and check for any burned wires at the terminal strip where the cord connects to the dryer. Replace any defective or burned parts.
Best regards, --W/D--
Mar 06, 2011 | GE DBXR463EBWW Electric Dryer
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
No power to dryer but have power at house...is there a reset button?
Check the circuit breaker in your housepanel. If it is tripped, resetting it will restore power BUT usually there is a reason for the breaker to trip. There may be an electrical problem with the dryer either an overload condition or a short circuit so check it's operation to be safe. If the breaker won't reset, unplug the dryer. If the breaker resets, then you have a problem in the dryer. if it still won't reset, then you have a problem in the wiring to the dryer outlet.
Nov 28, 2010 | Amana NDE2335AY Electric Dryer
LG Dryer DLE2516W contiuously trips breaker but only on heat setting greater than low
Your circuit breaker may be bad. Run dryer and if breaker gets hot after 10min or so the breaker is bad.
Higher heat settings draw more amperage thus tripping the bad or undersized breaker. 30 amp 2 pole breaker required.
Ck. the power cord for signs of arching. Replace power cord or outlet if damaged.
Jan 04, 2010 | LG DLE2516 Electric Dryer
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Dryer was working fine...then
You have a short circuit in the dryer. Check the incoming wires at the cord terminal on the rear of the dryer. If these wires are OK it could be a shorted heating element.
Sep 08, 2009 | Whirlpool LER5636P Electric Dryer
No power @ Dryer receptacle
Turn off breaker, Check and tighten lugs that feed dryer circuit at the breaker and at the receptacle, If that doesn't fix your problem you ll have to trace the wiring from breaker to dryer for broken wires.
Aug 03, 2009 | Whirlpool LER4634J Electric Dryer
GE Dryer Repair Video Older Models Logo
44 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
