Question about Apple iPod touch
Slide to unlock does not allow me to unlock my iTouch
  • 2 more comments
  • gbrown62 Sep 04, 2010
    Have iPod Touch. Not sure which of the two switches you are referring. The bottom circle bottom and the top on/off bottom are the only two that are functioning. I have held these two down simultaneously on several occasions until the apple logo appears (or just before it) and even once that caused a full restore to occur. Still no luck.
    Thanks for any help!
    Also, lock icon is ON at top middle of screen. Not sure if or where a reset button (hidden or otherwise) is located.
    It initially reacts to almost any slide action but at the same point moving left to right at about 1/4" it acts as if it has hit a wall and will not proceed to unlock. Very strange.
    Three attempts at this......no luck. Same issue.
  • Apple Master
  • 4,924 Answers
  • 1 Slide to unlock does not - reset-apple-ipod-classic-1.1-120x120.jpg Toggle the [Hold] switch on and off. (Slide it to Hold, then turn it off again.)
  • 2 Now press and hold the [Menu] and [Select] buttons until the Apple logo appears, which may take about 6 to 10 seconds. You may need to repeat this step.
  • 3 If the task seem a bit tedious, set the Ipod on a flat surface. ensure the finger pressing the Select button is not touching any part of the [click wheel]. Also ensure that you are pressing the [Menu] button toward the outside of the click wheel, and not near the center.
  • this is supposed to reset it ..
    also check the hold ..to not be on locked position ...
    If it has a reset button press it and reset it from there ..
    Pay attention cause it might have a hidden reset button ..looks like a hole in which you are supposed to enter something sharp and press in order to reset it ..
    if nothng works and it have a removable battery remove it a few seconds and power it back ..
    Posted on Sep 04, 2010
    • 1 more comment
    • Catalin Turcu
      Catalin Turcu Sep 04, 2010
      than it may be a issue of a screen calibration ...and in this case you have to try and slide to unlock somewhere near by ..and not in the line that it should..
      make several trials to slide mm by mm near by ..if it is the bottom line you have to slide..try a little higher..until it works ..
      after that look in the settings menu ..and locate screen calibration ..and fix it ..Its simple .all you have to do is to touch a screen point during it ..to let it know the exact positions ..
      But ..to get in ..you have to take it blind...mm by mm to hit the right spot where it reacts to slide action ..
    • Catalin Turcu
      try to reset again but this way follow this ..
      hold down the top button on the left (the one that locks it) and the
      home button (the circle button with the square in the middle) and keep
      holding it down until it goes blank and the apple comes up.
    • Catalin Turcu
      if it do not want to reset Im thinking that must be a issue with it physically and I suggest to have it fix on a professional environment ...if you think is worth the price ..or if it is in warranty better ..cause it do not seam to be something fix-able by settings ..If it was that the resetting should fix it ...either you are not managing to do it right ..or the Ipod is gone ..(at least the display commands..)
      It can be though just virusated,,,and a firmware update will fix it ..so this is why I suggest to take it to a repair shop ..cause there is nothing I can advise from the distance an work ..
    How do i unlock my ipod touch
    you slide the boxed arrow in the lockscreen
    if you want to get free apps
    the process is called "jailbreaking"
    simply type
    "how to jailbreak" followed by the Version like 4.2.1
    on youtube
    Oct 06, 2011 | Apple iPod Touch 8GB 32GB 64GB 3rd...
    My ipod touch is frozen cant slide the unlock bar ove but the wierd thing is the music is still playing
    go to an apple store or email them or go to an unlocking store and they do it for a fiver
    Feb 15, 2011 | Apple iPod Touch 8GB 32GB 64GB 3rd...
    Looping "slide to unlock"
    It sounds like a software issue. i would restore the ipod using itunes this will uninstall /reinstall the software- then re-sync to your CPU
    follow these steps
    Apr 13, 2010 | Apple iPod Touch 8GB 32GB 64GB 3rd...
    Cant turn off itouch, screen frozen . Slide to unlock not responding
    I would reset the ipod then restore and resync the ipod to the library
    Follow theses steps
    Apr 07, 2010 | Apple iPhone Smartphone
    How to unlock netgear on itouch
    Hi
    In order to unlock netgear on itouch You need to have the security key or the password of your wireless network
    Thank You
    Oct 30, 2009 | Apple iPod touch
    Won't let me slide to unlock my itouch
    Allow the iPods battery to completely die and then fully recharge it. If it wont unlock then your displays touch sensitivity is not working and you may need to replace the display or it may be cheaper just to replace the iPod Touch
    Jul 21, 2009 | Apple iPhone Smartphone
    ITouch screen not working !!!!!!!!!!!!
    Press the lock button on top and the home button at the same time and hold till the phone turns off. Wait 30 seconds and turn your phone back on. This worked for me just now!
    Jul 14, 2009 | Apple iPhone Smartphone
    Slide to unlock won't move. What now???
    i drop my ipod and i did everything and it still want move r unlock...............
    Mar 27, 2009 | Apple iPod touch
    Apple iPod touch Logo
    43 people viewed this question
    Top Apple Audio Players & Recorders Experts
    TO Lady
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
