Question about Samsung Televison & Video
I have a samsung LN32A450. When I connect my laptop to to it via the vga port the tv doesn't recognize it. I tried different resolutions and two different laptops: compaq Evo 180 & IBM ThinkPad. I know that the laptops vga outputs are functioning properly as i tested the same settings on a SONY Bravia KDL-32M3000. Thanks in advance.
Thru your laptop :)
Posted on Mar 22, 2009
How do I change source resolution on my TV?
connecting PC to Tv through VGA - Tom's Guide
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Connecting my Plasma to my PC via the VGA port. - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - Ensure that the VGA cable is working properly using other methods. Perhaps .... I am trying to connect my pc with my samsung tv. .... I'm very sorry to hear that has happened, and I apologize for any inconvenience this may have caused you. Connection between Dell laptop and Samsung TV
Jun 11, 2015
How to connect computer to tv with sound and picture?
Jun 5, 2015
PC Audio won't play through connected Samsung LCD TV
Jun 4, 2015
Connecting computer to TV
Jan 18, 2008
More results from
My custom built PC will not connect to my TV via VGA cable ... > Forum > Graphics Cards
Tom's Hardware Guide
Jun 28, 2013 - 5 posts - ‎2 authors
Jan 31, 2016 | VIA Computers & Internet
Unable to Connect Laptop to Samsung LED TV
VGA is analog - HDMI is digital
if u have a cable w/o a converter it won't work unless your video card supports digital signal output through VGA port function. Please consult with your laptop's user manual for more information.
Dec 10, 2013 | Compaq Presario Notebook
I have a Jensen (JE1909ACB) 19 LCD TV Can't get it to hook up as a monitor on my desktop. It reply's unsupported mode.
Are you using the VGA port on the Jensen TV? What is your computer's OS?
The usual reason for the unsupported mode message is that the the computer did not recognize the TV as a monitor on boot up or that the previous settings were incompatible with the TV. (For example, if you previously had a CRT connected to the computer and used a refresh rate of 75 Hz, the TV can't handle the refresh rate. It needs to be set at 60 Hz.)
First turn off both the TV and the computer. Then turn on the TV and set it for the PC input (assuming you are using the VGA port). Next turn on the computer. If you have Windows XP or later, it should find the TV and set the resolution without any input. (If it doesn't, use a different monitor and set the resolution to 1366 x 768 and 60 Hz. Then try again.) If you used the HDMI port, try the VGA port. This TV doesn't understand a computer signal over the HDMI port (only set top boxes).
I hope this helps.
Dec 08, 2011 | Car Audio & Video
I want to use my television as a computer screen. How do I switch the television to proper mode?
Look for a button on the remote or the TV itself labeled Source or Input. This should let you change the input between TV, AV, HDMI (on some TVs), and PC. Just press the button repeatedly or use the up/down arrows.
Before setting the input to PC (VGA), turn off the TV and the computer. Then connect the VGA cable (M-M) and the audio cable (a 3.5 mm M/M cable, if you plan to use the TV speakers) between the two units. Next turn on the TV and set the input to VGA. Then turn on the computer. (This is if you are using the VGA or D Sub 15 connection.) For a desktop, if you do not have another monitor connected, the TV should automatically be detected and the resolution set with any Windows OS (XP and later). However, you may need to reset the resolution and the refresh rate. For Windows 7, right click on the display and choose Screen Resolution.
For a laptop, you may need to enable the video port in the BIOS. Accessing this depends on the manufacturer of the computer motherboard. (Often Esc, F1 or F2 is the key to press after turning on the computer but before the OS loads. This can be tricky to time correctly.)
With a laptop or a desktop with another monitor attached, you will need to tell the computer how to deal with the multiple monitors. (Extend, monitor 1 only (or laptop internal monitor), monitor 2 only (external monitor), or dual display.) For my HP laptop with Win7, I choose Graphics Properties instead of Screen Resolution. There may be a keyboard Fn shortcut to access this.
Some TVs will accept a PC signal on the HDMI port (directly from an HDMI port on the computer or via a DVI to HDMI cable). Not all TVs do this. (Without the model for your TV, I can't confirm if this will work. If it doesn't, it is because of the differences between the PC output signal and that of set top boxes (cable or blu-ray players).
I hope this helps.
Aug 18, 2011 | Insignia Televison & Video
Can you help with connecting a laptop VGA to a philips hdtv lcd (model #32pf7421d) with a component cable? The laptop recognizes that it is connected, but nothing comes up on the TV except for...
Check your laptop with the same VGA cord on some projector or a monitor. If it works there, then there is a problem with your TV's VGA switching circuit. If it does not work, then there is problem with either the VGA cord or laptop's VGA port. To rule out the possibility VGA cord , replace it with new one. Please give the feedback for this so that further diagnosis can be done, if you are comfortable with the TV's electronics.
Aug 09, 2011 | Philips 32PF7421D 32 in. LCD HDTV
COBY TFT LCD TV/2204 works fine connected to TimeWarner cable without HD box. Get same channels as Samsung TV without box in Kitchen. However, I cannot get my old Compaq laptop to drive the 2204 as a...
the native res. for the TV is 1680 x 1024.
you may want to try a different resolution
like 800 x 600 or 1024 x 768. not the native resolution
of the laptop.
Dec 27, 2010 | Coby TFTV2225 22 in LCD TV
Trying to connect laptop to Samsung HD LCD TV using VGA cable.
I had the same problem with my Samsung series 6 32" Lcd. After many hours of trying different settings and banging my head on the wall I found the solution. What the problem is your VGA cable not supporting the high resilotion of your Samsung TV. The simple solution is to buy a new VGA cable that supports HD. Take a look at this site you need something like this one! Hope this helps.....C
Sep 19, 2009 | Philips 32PF7421D 32 in. LCD HDTV
Can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Dec 01, 2008 | Toshiba Satellite A205-S4617 Notebook
LCD TV and VGA output
The resolution and refresh rates have to match exactly to the TV for it to work correctly with the computer.
The newer computers are using much faster refresh rates by default. Their default resolution is also different.
Consult the manual for the TV and see if the computer's external monitor output can be set to match to what the TV exactly requires. Both the refresh rate and resolution are critical.
Jerry G.
Apr 20, 2008 | Televison & Video
Televison & Video Logo
91 people viewed this question
Jerry Greenberg
Jerry Greenberg
