Question about Kitchen Ranges
My bissell preheat has no suction release water but will not **** water up had only two months
  • Kitchen Ranges Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 04, 2010
My pet wash bissell shampoor won't pick up the water
Hey Deanne!I know how frustrating it is not having suction when you need it.
Here's a quick link to troubleshooting steps to assist you with the suction.
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 23, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissel powerwash 1690 does not dispence water
Hey George, not having spray when you're ready to clean can be frustrating.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1052&cid=ccsocial
Jan 21, 2013 | Bissell Carpet Cleaner Powerbrush Deep...
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
Bissell ProHeat can't get my cleaner to **** any water back up.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
iup
Jan 06, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell proheat 2x won't release soap water
heatman101
tyu8
Jun 20, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
MY BISSELL PROHEAT WONT SUCTION
heatman101
ffuutr
Jan 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet shampooer priblem
Something is probably clogging up the suction.
Try to snake it out with a coat hanger or similar tool.
Often, especially with shedding pets hair will clog the suction pipes.
Jan 17, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
BISSELL PRO HEAT X2 CLEAN SHOT
Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use) and is on the underside. It is a small (1 inch square) red plastic filter with a little door on it. Open the door and you will probably find it is clogged with hair, carpet fibre., etc.. Clean this out and you will hopefully have suction again.
Nov 19, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9400 ProHeat Upright Upholstery Hose
Set Ready Tools Dial to the Hose
Setting. This will allow spray and
suction from the hose.
Set Custom Clean Dial for Heavy Traffic, Normal
Clean, Light Clean
, or Rinse, as desired
Attach the cleaning tool to the end of the hose.
Plug in and turn on the Power Switch and Heater
(if desired).
Clean by pressing the trigger to spray solution
onto the area to be cleaned. Slowly move the tool
back and forth over the soiled surface. Release
the trigger to suction soiled water. Continue to
clean in the area, working in small sections, until
no more dirt can be removed. Rinse (optional)
and suction as needed.
May 26, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Kitchen Ranges Logo
88 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
