Question about GE Dehumidifiers
Is there a manual for GE Model ADEW50 LNL1 ? No problem, just would like access to manual if there is one.
I HAVE A ge 40 pint dehumidifier it wont run because it says the container is full and there is nothing in it
i did have one of a simmiliar model do just this same thing it turns out i hit the sensor float inside removable bucket part and knocked it out of its little hole it fits in , hence the it no longer connects with other part of overfill sensor thats buryed inside machine, so it allways says its full , i put the little float back in it's hole and now it works ok
Oct 20, 2014 | GE Dehumidifier With 40 Pint Capacity
My GE 50 pt humidifier works great - except it will not let me set the fan speed to low or medium - it runs on high all the time. I am SUPPOSED to be able to set fan to low.... HELP IT"S TOO LOUD ON...
It sounds to me like you have a defective switch. I would recommend that you contact a G.E. dealer with the model and serial number and describe your problem.I can't find the right file right now but I believe thatthis switch is about twenty dollars.Thank you.
May 14, 2011 | GE AHG40LA Dehumidifier
I got a letter telling me that ge dehumidifier is on recall model no. AHW30LK,G1 serial no. DM138705 the phone I call is busy1-877-593-8721 can you help me.
Unfortunately, 1000's of these units were recalled and there 100's of 1000's of owners of the Dehumidifier calling. You'll have to be patient and keep trying. Early morning is usually the best time. Start at 8am. The number you were given is for the company that's handling the recall for GE.
Feb 04, 2011 | GE Dehumidifiers
Model 501D(had the wrong model number before) When I turn the unit on where the humidity is set there is a code CO 01. Unable to find my manual. the unit starts then turns off.
I will advice you check the water bucket to see if it is full and empty the bucket in a sink if needed. GE dehumidifiers have a safety feature that shuts down the device when the water in the bucket reaches a certain level.
Install the bucket correctly in the unit by hooking the slots on the bucket on the posts on the back of the device. The dehumidifier will not run if the bucket is not properly setup in the device.
Take care.
Aug 30, 2010 | Comfort-Aire BHD-501 Dehumidifier
We bought a ADEH 50 LNL1 Serial 106143 this summer. It does a great job at removing water from our basement,needing emptied every 24-36 hrs. However it is always so hot in whatever room we set it that...
Unfortunately not....you see a dehumidifier puts the heat back into the room... it does not remove any heat...but... the heat from the fan motor and the compressor is added to the room... thus the heating that you are noticing...
Sorry I cannot give better news... :-(
heatman101
Aug 29, 2010 | GE Dehumidifiers
I have a GE Dehumidifier Model AHW50LMG1. Am trying to find out how to clean the container that the water is collected into. After use the container contains residue from collected water that I am...
Vinegar is the proper way to clean all parts of a humidifier. It stops scale and kills bacteria and fungus. It can be processed through the heating element without any adverse effects.
Thank you,
James.
-------Please vote 4 thumbs up 4 me!!!----------
Apr 24, 2010 | GE Dehumidifiers
How do I access and clean the filter, and how often?
Pull out drain bucket, under lip of bottom front of cabinet (top of bucket area) remove blue tape and slide down filter, rinse or vaccuum off 1/yr.
Manual should be on line, but google full model number (sticker at rear of bucket area)
Jan 04, 2010 | Kenmore 54351 Dehumidifier
The dog chewed the cord on my LG dehumidifier. Where can I get a replacement cord?
Go here online:
http://www.partselect.com/MultiModels.aspx?ModelNum=AHG40LJ&SearchTerm=cord&RefineSearch=0
or go to any GE home appliance dealerwith the model number and they'll order it.
Jul 08, 2009 | GE AHG40LJ Dehumidifier
Dehumidifiers Logo
160 people viewed this question
Top GE Dehumidifiers Experts
J.D. Browning
J.D. Browning
AZBen
AZBen
Are you a GE Dehumidifier Expert? Answer questions, earn points and help others
