Question about Mitsubishi WT-46807 46" Rear Projection Television
My 46" Mitsubishi television turns on and then turns right off. I did the test that you suggested to others and the 2 pause 2 code came up. Can you send me the reapir instructions as well? joshsiegel13@yahoo.com.\r\n I look forward to your response! I want my TV back! Thanks
  • Mitsubishi Master
  • 8,457 Answers
This problems is the DM power board have many dead capacitors.U must have soldering iron and solders.U must know to do basic soldering.Try website like Tvrepairworld.com to buy a DM power board capacitors repair kit.Must replaced all those dead capacitors,will solved this problems.
Posted on Sep 04, 2010
When I turn the tv on,,it just turn off,,
do the self check this model has. When green power light goes out on the front of the set press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then let go of both.
Power light (green) should blink a two digit code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Sep 14, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Turned off and power light blinks
Please let me know if the blinks separated with a pause, if so first blinks is denoting the first digit then pause blinks again denoting the second digit. Example, if the error code is "22" the unit will blinks two times pause blinks 2 times and will repeat the error code. It will help to determine where the fault came from.
Jdvillanueva
Jun 24, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Same guy more info...code 2 blinks pause 2 blinks
this code indicates that a power supply line. is shorted. the safty cuircits have detected an overcurrent or overvoltage situation.
Mar 04, 2011 | Mitsubishi WT-46809 46" Rear Projection...
On my mitsubishi wt-46809 the error code is 2 blinks pause 2 blinks. What is this?
it is short protection and means one of the fuses for the convergence circuit is blown.
I can help with this if you want.
SD TECH
Jan 14, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi model Wt-46807 Power shuts down after turning on. Tried the solution of pressing the menu & input buttons at same time for at least 5 seconds. Power light error code was 2 blinks/pause 2...
hi,
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Oct 16, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Green light comes on then goes right back off.
The TV indicates an error code 22 (short circuit protection). Check 2 STK392-570 convergence IC for shorts and 5amps pico fuse for open. I usually replace both STK's.
Dec 25, 2009 | Televison & Video
When i turn it on it shuts right back off
Please do the self check this set has:
When the power light comes on and goes out press and hold both the MENU and Input (also called Device) buttons at the same time for at least 5 seconds and then release both buttons.
The power light will blink a two digit error code--for example--2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means and what may actually be the problem.
I am here to help people.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 16, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Tv turns on then right off
NEXT TIME IT SHUTS DOWN: when green light goes out on THE FRONT OF THE SET: press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and then release both.
This is the self check this model has---power light should blink a two digit code---for example--two blinks, a pause and two blinks and the set will repeat the error code about 10 times.
1 blinks and then 2 blinks is NO ERROR DETECTED
2 blinks and then 2 blinks is short protect
ETC.....Let me know if you get an error code and I will tell you what the problem is---hope you find 2,2 that is the most common and the most easy to repair.
SD TECH
Oct 22, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubish WS-819 Protective Shutdown. 2 blinks, pause, 2 blinks
Over 95% of the time a 2 - 2 blink code on that model is a convergence output problem. You need to replace both of the convergence output IC's and perhaps the pico fuses feeding them voltage. The pico fuses are F9A04 and F9A05. They are on the same board with the convergence outputs.
May 29, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Oval shaped picture problem with Mitsubishi WS55807
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is
Nov 21, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WT-46807 46" Rear Projection Television Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
