Question about Garmin GPS
Has no factory preset voice speaker at all.Just got What can I do.
    President:
  • 1,514 Answers
1. Press the Volume (Speaker symbol) in the bottom right corner and check that the mute box is not ticked. If it is press it and it will be ok. Also check that the volume isn't fully down.
If that doesn't solve the problem it may be because the voice file is not selected or has become corrupted.
2. Press Tools (The spanner symbol), then press Settings, then press Language. You will see a bar for Voice. Press Voice and select a different voice. If this doesn't solve the problem it's most likely because the voice file has become corrupted. To replace the corrupted file.
3. Download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and connect your satnav to your computer. Install webupdater and your satnav will look for updates. After it's finished it will give you an option to download voices. Click the ones you want and press next. The voices selected will be downloaded to your satnav.
When you have removed the satnav from the computer you'll need to select a voice again as described in para 2 above.
Posted on Sep 04, 2010
The voice speaker fads out but all the other speakers are still working
Unfortunately, you haven't given much info at all. Not the make and model of your head unit, the make and model of the car, whether you're using factory or aftermarket equipment, etc. A shot in the dark, and prior experience tells me that your center channel's voice coil is bad, and the speaker needs to be replaced.
Jul 02, 2017 | Car Audio & Video
My yamaha psr s 700 changes sound sometimes hand with all d bottons Woking if I start d keyboard all botton will not come up util 20mins after switched off plz I really a solution cus im so tired
lots of issues there
will need taking apart to find the faults and repair
some possibles
power source input low
internal circuity faults
switches
dry solder
diode faults
internal dust build up
One of Yamaha's new arranger keyboards, the PSR-S700 is the more entry-level model, but still comes with a range of impressive features:
  • 61 touch responsive keys
  • 96 notes of polyphony
  • 5.7-inch QVGA LCD capable of lyrics and score display
  • AWM (Advanced Wave Memory) sample sounds
  • 813 preset voices made up from 317 voices, 16 drum kits, 480 XG voices
  • 10 MegaVoices
  • 11 Sweet! Voices
  • 18 Cool! Voices
  • 14 Live! Voices
  • 9 Organ Flutes
  • 2 layer voices
  • Large number of preset and user-definable effects including reverb, chorus, 4 x DSP (Digital Signal Processing)
  • 205 preset 8-part auto-accompaniment + user category with mixer controls
  • 16 track recording
  • 30,000 note capacity
  • Performance assistance technology
Sep 15, 2016 | Yamaha Music
What is the button combination to reset the Denon AVR-1601 to factory presets?
switch off, then hold A and B speakers, then switch on and hold about 3 seconds. This is reset to factory defaults.
Jul 22, 2011 | Denon AVR-1601 Receiver
All the speaker outlets seem to work fine, except the fronts, all will work, but if i plug the fronts in, all the sound then tends to just fade away, and then i have nothing, no sound. i can't figure...
I would:
1- First make sure you are properly testing using a reliable source, such as a CD Player or itunes. 2- Make sure the Listening Preset is not on Dolby Pro Logic. Make sure it is on Stereo mode and see if the problem persists.
What usually happens is that when listening to 2ch (Left and Right) Audio such as Television or Music and Dolby Pro Logic is on as a preset, Dolby Pro Logic analyzes both Stereo tracks, tries to detect the voices (center channel), ambient sounds (surround and fronts) and processes the signals into a 5.1 or 6.1 System. You tend to get a fading effect when Dolby Pro Logic is selected and listening to an old VHS, DVD or even music.
To remove a preset, make sure you select the Stereo button at the bottom left of the remote to pan through the options.
Hope this helps
Jul 21, 2011 | Harman Kardon AVR 230 6.1 Channels...
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
No sound of voice, only surround sound
If you do not have a center channel speaker connected, then in the reciever setup menu for speakers, there should be a selection for center channel that says something like either yes or no. I'm guessing it says yes. Then you need to select "no" so that the circuitry will direct sound specified for the center channel to be reproduced through your front speakers.
Dec 07, 2009 | Pioneer VSX-D711 Receiver
How do I get off Military time?
Sorry if this posts twice...
To reset your Pure-Fi Anytime, do the following:
Press and hold the Source and Preset 2 buttons (shown below) on the top of your Pure-Fi Anytime for 5-10 seconds.
NOTE: The reset procedure will restore the Pure-Fi Anytime to factory defaults and all presets will be cleared.
Jan 21, 2009 | Logitech Pure-Fi Anywhere Portable...
How to retrieve voice mail from another phone
The factory preset code is "11".
Call your phone from a touch tone phone. Enter your remote code (11, or whatever you set it to) during the greeting message. The number of new messages will be heard, and the new messages will be played.
Jan 17, 2009 | Panasonic KXTG2344 Cordless Phone
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
