Question about Craftsman Garden
Craftsman leaf blower, model 358.794772. Starts fine and runs good for about 10 minutes then starts to run slower and sometimes stops. I cannot restart until it is complete cooled down.
chad7houston
  • 62 Answers
SOURCE: Homelite leaf blower bogs down.
I don't mean to over simplify this, but are you using fresh gas? Gas blowers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with gas blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Posted on Oct 08, 2008
SOURCE: can't start my leaf blower
You might have damaged the "spring re-wind" or the cord is jambed. If you know how to disassemble the housing (see owner's manual), then check to see if the cord is stuck, then manually re-wind it and pull it slowly and then let it rewind slowly. Do not attempt to remove the spring housing unless you have several hours to spare to rewind the spring, as it will "unspring" with great force - all over the place. Zing! The only other solution, of course, is to take it back to Sears for repair. Yuck. Have had several in the shop for other reasons that couldn't be easily DIY repaired - time after time.
Most ****-smen products cause more headaches than they prompt smiles of joy. I have pretty much determined that the manufacturers of ****-smen (who ever they are) plan it that way. Most home-owner products of this sort only last for 3-4 years, if you're lucky. I have also tried other brands; none are much to rave about. You could always do what I do, if I don't have any warrantee time left, or an extended agreement; give it a nice funeral (or run over it with a tank and send the remains to the CEO of Sears) and spend the money for a new one (any brand - even Craps-men) or use a rake..... :(
If you do get it to work, try pulling the cord with less force and NEVER let it "spring back" by letting go of the handle. Let is rewind as you hold it. GOOD LUCK!
Posted on Nov 09, 2008
  • 211 Answers
SOURCE: leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Posted on Dec 05, 2008
kachbibi1
  • 979 Answers
SOURCE: craftsman leaf blower/vacuum
I have a Craftsman and you should have a separate attachment to it. Your motor will turn the same, instead of pushing air out the pipe, you will draw air in through the air intake.
Posted on Feb 03, 2009
EarthJam
  • 23 Answers
SOURCE: runs fine &then suddenly stops
IN the tank there is a intake tube on the bottem of that tube is a tiny filter. you can reach in and pull it out the tank enough to work on it.
It is clogged pull it off let it dry for a day and then blow it clean fron the gas line side OUT.
or echo sells tune up kits for 10 bucks at home depot. -Jeff Anchorage Small Engine.
Posted on Feb 04, 2009
I have a Craftsman 4 cycle Leaf Blower Model 316.794830. It starts up fine a little slow to warm up then blow for about 2-3 minutes slows down and quits and stops.
The carburettor may need to be adjusted. The tool for this is not readily available, so I suggest to take it to a lawnmower centre.
Oct 08, 2017 | Craftsman Garden
Common carb problem, sometimes the fuel hoses need replacement. Clean carb with carb cleaner. Be sure to remember where all parts go. Get a repair kit, very cheap, clean out all ports with brass or steel bristle or something small. Put back on engine if still has problems replace carb it could be worn out
Jan 11, 2014 | Craftsman Garden
My echo pb-201 hand held leaf blower starts and runs for about 2 minutes then begins to sputter and stop. Sometimes I can get it to work for about 4 minutes but then stops.
may be a clogged fuel filter or bad fuel lines check to see if they are real soft if so replace it they are fine the may need a carb kit
Jan 13, 2011 | Echo Garden
Plugged it in and it won't run but it was running fine when I put it away two weeks ago.
Check the plug for loose wire or at blower where wire it enters to make sure the wire was not pulled and disconnected inside. If after looking and it is not a wire, check the brushes on the motor. They could be worn out or not making a good contact. Blow out brush housing and re-install brush sometimes this works. That's about all I can think of unless there is a safety switch then check that. Good luck.
Nov 22, 2010 | Toro Craftsman 225 mph Electric BlowerVac
Briggs and Straton 8 hp, craftsman snowblower stalls
Sounds like you coil is over heating after running a few minutes. The windings are seperating, then when it sools they make contact again. Try replacing the coil.
Feb 05, 2010 | Craftsman Garden
Hi. My craftsmal leaf blower runs OK for 3-5 then dies????
Could be a blocked vent on your fuel tank - is there a vacuum in the fuel tank immediately after it stalls?
Oct 25, 2009 | Craftsman Garden
Runs fine &then suddenly stops
Dec 24, 2008 | ECHO, Inc. PB-251C Handheld Blower
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
143 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
