Question about Mag Innovision LT982s 19" Flat Panel LCD Monitor
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up? My monitor will turn on for about 1/4 to 1/2 a second and then turn off...the monitor light then turn orange. I can not get it to stay on. I can turn it back on by turning the power off and then back on, then it will do the same thing as mentioned above. My monitor is Mag Innovision LT982s 19 in. Flat Panel LCD. I'm going to try some of the things mentioned below....but I don't know what some of the terms mean.
  • 4 more comments
  • marimir Aug 06, 2008
    Power light goes from green to orange, screen remains black.
  • Anonymous Aug 06, 2008
    Same problem!
  • storrs10 Aug 08, 2008
    exact same problem
  • krumz2003 Sep 19, 2008
    We bought TWO of these monitors at the same time and BOTH are now doing this black-out thing as mentioned by others. Shut off monitor, turn it on... then screen goes black again. Seems odd both of ours are doing the same thing... does MAG program these things to sell more monitors? :(
  • malnarja Feb 12, 2009
    My LT982s we have had for four years just started doing this. It acts like it is on with lights and sounds but then no picture. Tried hooking it up to laptop and I can set some settings but no picture. The green light stays on though.
  • Anonymous May 21, 2009
    mine too... had it about 4 years. bummer!
This is an easy problem to diagnose but not so easy to fix. the power inverter for the backlight is dead. this is a very common problem with lcd monitors, if it is a module they are usually range in price from $20-75.
Posted on Jan 19, 2009
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
Posted on Aug 06, 2008
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Mag Innovision LT982s 19 inch flat screen monitor
Often the plug of the power cord and its mate, the jack in the monitor, would have to conform with the region/country of its intended use. Having said this, then it is possible that your particular version is meant for another country but is likewise sold in your country. A picture of the monitor's connector would help narrowing the selection and possible source/supplier. Pls post if able.
Alternately, you could try viewing the different types here, here or here to get the specific part number or model of the AC cord.
Incidentally, most electronics shops/stores sell a variety of power cords, perhaps a visual check would further assist you.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 02, 2008
yes the power supply or capacitors are shot. the part u want is from proview technology inc
attn: parts dept.
7373 hunt ave
garden grove,CA 92841
it is the lcd power supply, P/N 860-ALZ-M713W-f
F0742683G
1-800-776-8439 follow prompts....ed
Posted on Feb 10, 2009
SOURCE: My mag Innovision flat lcd monitor is blank after 3 seconds..
It is not easy. I slip a knife in the bottom edge and slowly work my way around the bottom opening it a little by little. Once you get the bottom and part of each side you can push the plastic towards the top and it will pop off. There are plastic clips holding the bezel down. I always break a couple on opening, but at least the monitor gets fixed. This is not made to open, so good luck.
Posted on Sep 22, 2009
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Monitor is blank/dimension 2400
If you put a spare monitor on your computer and everything is fine I'd say it has an electronic problem. If the screen is still blank I would look at the video card or PC itself as the problem. Just for fun check the video cable for bent or missing pins.
Mar 23, 2009 | Computers & Internet
Monitor is bad for sure. Try another known good monitor on your computer and if the problem stops then you know for sure the original monitor is bad. Hope this helps.
Feb 01, 2009 | Dell Dimension 3000® Pentium® 4...
there is an hardware issue in your lcd it needs to change one of the capaciter please take it to a lcd technician
thanks
Jan 24, 2009 | Acer AL1715 17" LCD Monitor
YOU NEED TO HAVE THE INVERTER BOARD REPLACED.
YOU CAN USUALLY FIN THEM ON E BAY OR YOU WILL HAVE TO TAKE IT IN IF YOU DON'T FEEL COMFORTABLE REPLACING IT YOURSELF.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
do you have an aftermarket video card. In the bios you have to tell the computer if it is looking for a agp/onboard or PCI video card. Either that or the video driver or settings are wrong Try safe mode to check
Jun 25, 2008 | Dell Dimension 2400 PC Desktop
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
Mag Innovision LT982s 19" Flat Panel LCD Monitor Logo
1,095 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
