Question about LG CU400 Cellular Phone
How do i remove a blue circle dot by the bars?
The bobbin case went ajar while sewing blue jean fabric. I cant figure out to put it back in. Your help is very much appreciated :
Hi Debbie,
This type bobbin case can be a pain to get back in. On photo #1, at the top left you see a silver piece (circled in red) with a rectangular hole in it (circled in green)...take a flat head screw driver and insert it into the slot then twist to the right so the little bar/flange (circled in blue) will twist to the left past the bobbin well wall (marked in neon green). Photo #2 Now the bar/flange (marked in blue) should be on top of the bobbin well wall (marked in neon green). Now set the bobbin case in the bobbin well (marked in pink). Photo #3 as you set the black bobbin case in, kind of angle the flat part that is marked by the orange X so that it will begin to underneath the bar/flange with large orange circle. It won't go in all the way but just start it and then set the rest of the case down in the well. Now twist the entire black case to the right and the flat black are marked with the orange (X) should slide underneath the bar/flange marked with orange circle. The flat piece marked with a purple (X) should be sitting in the area marked with an (X) in the bobbin well. Now take your screwdriver and stick it in the rectangular box and twist it back so the silver piece marked in blue with go back over the edge of the black bobbin case to help hold it in. Hope you can understand my instructions and good luck!
Apr 11, 2016 | Singer Merritt 8734
Gta liberty cheats
UP, SQUARE, SQUARE, DOWN, LEFT, SQUARE, SQUARE, RIGHT
Weapon set 1 UP, CIRCLE, CIRCLE, DOWN, LEFT, CIRCLE, CIRCLE, RIGHT
Weapon set 2
UP, X, X, DOWN, LEFT, X, X, RIGHT
Weapon set 3
L1, R1, TRIANGLE, L1, R1, CIRCLE, L1, R1
Money Cheat ($250,000)
L1, R1, CIRCLE, L1, R1, X, L1, R1
Full Armor (Blue Bar)
L1, R1, X, L1, R1, SQUARE, L1, R1
If you want more cheats go here.
Full Health (Red Bar)
Oct 30, 2010 | Sony PlayStation Portable (PSP) Console
Hi there,there is a ring of blue dots
clean the lense of your projector, dirt or moist of water may be possible reason
Feb 18, 2010 | Canon LV-S3 Multimedia Projector
Blue Dots at bottom of screen
i have 6 grey perfect circles on screen of sony 52 inch kdlw3000
Jul 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue dots and blue screen on Hitatchi 50"
Bad Light Engine Call UED for rebulit one 1-800-648-6657 They are not cheap.
Dec 26, 2008 | LG RU-44SZ51D 44" Rear Projection...
Two blue dots on the screen
its sounds like the guns has burnt your yube, when switching of does your tv show a bright circle in the middel, or while watching. Smack your tv on the side while on see if the picture goes away or make a bright circle in the middel, this is caused by a bad solder joint but you wont get rid of the bunt pixels sorry.
Nov 26, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue dots on LCD screen
You will most likely need to replace the panel. You will have to contact Sony and they will send a Factory Trained Technician to your home to replace it. Since you are not on Factory Warranty this repair will cost you. You may find it cheaper just to replace the television.
Oct 12, 2008 | Sony KDF-42WE655 Television
Kf-42610 blue hue and blue dots on screen
Hi Guys
The Blue dots or discolouration you are seeing is due too the Blue LCD screen having cracked from excessive heat. This normally happens when you have a power failure while the Television was on. This obviously because the Blue LCD sits next to the lamp - the main cause of heat. The correct part number on the 60" is A-1086-952-A. It is very, very ,expensive.
Sorry to have been the bearer of bad news. Good luck : )
Aug 29, 2007 | Sony XL-2100U Projector Lamp for...
LG CU400 Cellular Phone Logo
172 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
