Question about Delta Saws
Table saw blade is slipping but nut is tight.10" cat#34-670 serial#K 9343
4 Suggested Answers
  • 68 Answers
SOURCE: 10'' table saw binding?
Sounds like you lost a spacer that goes behind the first flange against the motor bearing, you could use a lock washer if you bend it flat.
Assemble:
spacer washer,
first flange,
blade,
second flange,
nut.
I think the first flange is rubbing the motor housing.
Posted on Apr 26, 2009
VtToolMan
  • 704 Answers
SOURCE: I need a manual for a delta saw
Here's a free manual you can download that provides an exploded view of all the parts and a complete listing of each part in the saw.
http://www.ereplacementparts.com/images/dewalt/34-670_Type_2.pdf
Here's a link to the Delta-Porter Cable website where you can also get a free manual via download. Just select which version you have, either Type 1 or Type 2 on the bottom of the page and download that for free
http://www.dewaltservicenet.com/SearchResults.aspx?q=34-670
Hope you find this Very Helpful and best regards!
Posted on Dec 10, 2009
SOURCE: I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Posted on Mar 04, 2011
How do you change a blade on model 36-075
Lots of saws have left hand threads on the nut that holds the blade in place. It is designed so that if the saw starts up and the nut isn't snug, the nut and the blade slipping on the turning arbor would tend to tighten the nut as they slip against the force of the spinning arbor.
1. Unplug the saw.
2. Hold on to the blade tightly with one hand.
3. Put the wrench on the arbor nut and turn it in the direction you would turn it as if the wrench were turning the blade to cut wood.
If you've previously overtightened the blade, jamb a piece of wood against the teeth and the saw table top and then follow step 3.
If the motor is on the left side of the blade as you face the saw, then it's a standard right hand nut.
If the motor is on the right side of the blade as you face the saw, then its a left handed nut.
Sep 17, 2014 | Delta Circular Saw Blade, 10 Dia, 50T -...
Why does the blade on my table saw slip
This is a very dangerous situation. There is only one answer: You have to tighten the nut on the drive shaft more securely. Also, many saws use some kind of compression washer with the nut. Make sure the compression washer is in place on the OUTSIDE of the saw blade under the nut.
Sep 09, 2014 | Saws
My saw powers up but blade is not moving
Is it belt driven and the belt is slipping or broken?
Is the shaft nut holding blade on loose?
Reverse threads are used on the nut to hold the blade. Was the wrong nut used and the blade is not tight?
The bearing on the blade shaft could be frozen.
Some of the possibilities I could think of so I hope this helps.
Oct 07, 2013 | Saws
Black & decker 10" table saw -where is the blade
The Blade is held on by A Nut and Washers. Remove the Blade insert and you should see the nut and washer
Jun 26, 2011 | Black & Decker Saws
Replacing 10 in blade
Look at the threads on the saw blade arbor, that will tell you which way to turn the nut to get it off.
May 04, 2010 | Craftsman 10" Table Saw
How do I change the blade?
Unplug the saw. Remove the plate that the blade goes through this will allow access to the nut. Raise the blade several inches above table deck. Place a block of wood under the teeth to bind the blade so it won't rotate you should be standing on the infeed side of the blade. With a wrench loosen the nut (Towards You) Reverse to reinstall. It is also a good idea to wear leather gloves in case you slip the blades can still do damage even when dull. Hope this helps please rate if this was helpful in any way. Good Luck and have a great weekend.
Mar 31, 2010 | Jet 10 In. Proshop Contractor Style...
Assemble:
spacer washer,
first flange,
blade,
second flange,
nut.
Apr 26, 2009 | Saws
How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Jan 20, 2009 | Craftsman 10" Table Saw
Can't Get Blade Off
without a model number I cant look at a breakdown but if it is like the table saws that I work on I would assume that you removed the center plate to get to the hex nut and spindle, if so what I have to sometimes is put my wrench on the spindle and brace it against the saw frame and using a soft mallet tap on the hex wrench to loosen the nut. After this initial blade change the hex nut has to be tight but not to the point of breaking wrenches. If this doesn't work get me the model number and I will dig deeper to try and help
Jan 01, 2009 | Skil 10" Table Saw
Saws Logo
90 people viewed this question
Top Delta Saws Experts
Craig Butler
Craig Butler
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Delta Saw Expert? Answer questions, earn points and help others
