Question about Maytag Dryers
I have a maytag gas dryer, model mdg9206aww, i have no clue how to put the belt on could you please help? a picture would be best if possible, thank you!
  • Maytag Master
  • 43,501 Answers
Here is what you are looking for...
Maytag Dryer Belt Diagrams and Replacement
heatman101
Posted on Sep 03, 2010
Need help putting new belt back on Admiral dryer model ADG 7005 AWW, possibly a diagram?
Hi bgpace02669..
To to this webpage to see a picture of how to route your belt.
Please take time to rate me
http://www.expertappliance.com/dryerbeltconfiguration.html
Jul 09, 2011 | Maytag ADG7005AWW Gas Dryer
Gas dryer runs and heats but won't blow air
Hello, Thank You for using FixYa. I will be helping you today.The belt for the blower came off and most likely the pulley.If the pulley came off put locktite on it before installing the pulley to prevent it from happening again.
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | Maytag Bravos 7.0 Cu. Ft. Gas Dryer
MDG9206AWW MAYTAG DRYER MAKES A SQUEALLING NOISE. I HAVE THE DRYER APART AND THE FRONT DRUM SUPPORT "BUSHING" ( THAT FELT CIRCLE)APPEARS TO BE THE PROBLEM.ITS MISSING AND CRUMPLED IN SPOTS.. ...
If you purchase a new FELT there may be a more modern way of installation. If it's the same with clips then you will need to clip new felt on the same way as original. Good Luck Friend.
Oct 10, 2017 | Dryers
I have a Maytag Model pyet224ayw electric dryer, The belt broke and I replaced it. Now when I put the new belt on, every time that I turn it on the belt jumps off the tention pully. Can the problem be that...
http://www.applianceaid.com/maytag-dryers.html
this site has proper belt routing pictures for several brands maytag included might be helpful the only other thing i can think of the idler may be worn out or bent or drum may be tight not turning properly should turn freely with belt loose from inside dryer
should be able to push vanes and rotate drum easily
good luck ron
Dec 10, 2009 | Maytag PYE2300AY Electric Dryer
Model mdg9206aww wont heat
Firstly, ascertain that you have made a positive heat selection on the control panel temperature switch.
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
More information
If your dryer doesn't heat, check these first:
Igniter
Gas valve coils
Thermal fuse
Igniter http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di3018&PartID=3018 Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di3479&PartID=3479
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di516650&PartID=516650 On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Other components that could keep it from heating.
Hi-Limit Thermostat
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di481329&PartID=481329
Cycling Thermostat
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di484291&PartID=484291
Temperature selector switch
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di516542&PartID=516542
Flame Sensor
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di2681&PartID=2681
Motor Centrifugal Switch
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di776953&PartID=776953
Gas Valve
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di1689&PartID=1689
Timer
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di516525&PartID=516525
Sep 07, 2009 | Maytag Dryers
My husband is right now hanging a belt in out
angie tell him to stop relax it is a bit of a pain to do it must be done fron the front patince it will go
Jun 26, 2009 | Maytag MDG2706A Gas Dryer
Needing 15-20 year old apartment sized dryer belt.
go to a Maytag service agent
even the unit is old , there is a good possibility that the belt is still in use or was discontinue recently and they may have spares
Aug 19, 2017 | Zanussi TC180W Electric Portable Dryer
MAY TAG NEPTUNE DRYER BELT INSTALLATION
hi thanks for the question go to repair clinic punch in your model # it will bring up the picture of that set up thanks the appliance doc
Jun 22, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
231 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
