Question about Vacuums
Singer 6235 is stuck in reverse. How do I fix it?
How do I replace the Feed Drive Geer (Singer Part #174488) on Model 6234?
Go online with make and model and search or go to manufacturer web site or find a local service centre and ask there.
Sep 21, 2014 | SewShop.com Singer Model 6235 Instruction...
Machine is stuck on reverse mode
Try this,Go back to straight stitch, zero your stitch length,zero your stitch width, turn your hand wheel towards you for few rounds then select a stitch length and see if the reverse lever will work normal after this. Otherwise get it fix by a local technician.
Nov 08, 2013 | Singer 4423 Electric Sewing Machine
Singer quantum le my sewing machine is frozen and
Check to make sure you do not have a small piece of thread stuck in the raceway area
Aug 12, 2013 | SewShop.com Singer Model Quantum LE...
The reverse won't work on my singer 9018 sewing machine
STITCHING IN REVERSE
• To reinforce beginnings or ends of seams, push in
reverse lever
(1). Machine will straight stitch in
reverse for as long as you hold the lever in.
• For continuous reverse stitching, push lever in and
slide it to the left to lock. Unlock reverse lever by sliding
it back to the right and letting it return to its normal
position. if you need a manual let me know,,
Nov 25, 2012 | SewShop.com Singer Model 9018 Instruction...
I have a Singer 478 sewing machine and need to replace the top gear on the verticle shaft. Is there a repair manual for doing this. There was not category expert on this so please direct to the correct...
This is an easy fix. a lot disassembly required, you will need to gain access through the belt side to the singer cover plate,four clips hold it on from the back side. Once that is off, two screw hold small access plate which is under the letters Sin, remove plate, rotate shaft to access screw through opening which holds Vertical Top Shaft Gear, Singer # 155819 in place. Remove bottom cover, locate belt pulleys (2), remove cam tensioner, with a hex wrench remove pulleys, this makes it easier to remove lower belt. with a long thin, blade screwdriver, loosen screw on gear (through small access cover), slide shaft downward Rand R gear, reverse process, done. Be sure you document removal, take pictures, mark references with marking pen.This makes reassembly easy. I just replaced mine, I am handy but not an expert, hope this helps you...
Jan 27, 2011 | Vacuums
My Singer Sewing machine (model 6215) is now only sewing in reverse. After pressing the backstitch button, the button seemed to stick in the backstitch position. I was finally able to pull the button out...
It's stuck inside. Open it up so you can see inside the bottom, look for the feed dog mechanism and you'll find where length of step is varied, this is where the reversing takes place too. Tapping gently and oiling will free it up.
lp
Dec 29, 2010 | Vacuums
Vacuums Logo
116 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
