Question about LG LDF6810 Built-in Dishwasher
Water inlet shut down within two minutes,with IE error could this be inlet valve
  • axford Jun 06, 2008
    Thanks for the feedback but it was the inlet value that was gone i fixed it myself for $45.00 running good for now
Probably problems w/ the motor burning up. I had my LG replaced for the same reason, that one also did not work. I demanded and received a refund and went and bought a different brand!GOOD LUCK!
Posted on May 31, 2008
Error message IE
IE Error
Water inlet error. Cause : Correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes
Check to make sure the water valves are fully opened
Nov 26, 2010 | LG WM-2277HW Front Load Washer
My LG WM2277HW washer always gets an IE error. To finish the wash, I change the setting to Speed Wash and punch Rinse Spin. Sometimes, I get lucky and the wash finishes. Most of the time, I get another...
Hi
Thanks for using FixYa. Error IE water inlet error which occurs when correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes. To start with you can try to clean the filter if this wont help then you'll have to replace the water inlet valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 27, 2010 | LG WM-2277HW Front Load Washer
Keep on getting the IE erorr
Error code IE means an water inlet error. Correct water level is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes.
Make sure water supply tap is open and not frozen. Check and clean water inlet valve from debris. If the issue persists, replace water inlet valve.
Oct 18, 2009 | LG WM1814CW Front Load Washer
Ie error code
The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound
Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
Sep 20, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
IE problem
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Cut power by tripping circuit breaker or unplugging power cable for ten minutes.
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
Dec 23, 2008 | LG LDF8812 Stainless Steel Built-in...
What does IE on the display mean?
IE means inlet error. Most likely the washer took too long to fill, due to a plugged screen where the hose attaches to the inlet water valve. Frozen water line would do it also. Or a bad water valve.
Dec 05, 2008 | LG WM1814CW Front Load Washer
LG Dishwasher ie error code problem
Possible cause:
Remedy:
Oct 31, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Flashes 13?
IE = Inlet Error. if the water level has not been reached in a certain amount of time, you will get an IE code. Most likely cause is clogged inlet water screen, inside the threaded end where the hose attaches to the machine. Other possiblities are valve shut off, kinked hose, open water inlet valve solenoid coil.
Sep 28, 2008 | LG WM1814CW Front Load Washer
IE Error - stressed motor
Possible cause:
Remedy:
Jul 27, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG LDF6810 Built-in Dishwasher Logo
96 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
