Question about Sub-Zero Bottom Freezer Refrigerator
I have a Sub-Zero Model 550 whose freezer does not get very cold even though the set to 10
    President:
  • 1,891 Answers
Set freezer for 0 deg and clean the coils on top . and make sure the fan up top is working . very important .. mm 550 are r12 and may be low or refergent . this is somthing you may need a service tec to ck but do the cleaning first and see how it works. mm
Posted on Sep 03, 2010
I need instructions how to replace the cold control on Sub-Zero 550 Freezer.
Here is a pic of the insides. The cold control is at top right of this pic and the capillary tube goes from it across to middle and then down the centre. All this is can be reached from the back of the refridgerator.
http://www.bing.com/images/search?q=Sub-Zero+Model+550+Manual&Form=IQFRDR#view=detail&id=E7AB2341111D09E747ABB1092D17C1338277BB7F&selectedIndex=0
Dec 20, 2013 | Sub-Zero Refrigerators
Sub zero model 550 freezer not working
how old is it and is everything warm in freezer?
Jun 18, 2012 | Sub-Zero Bottom Freezer Refrigerator
My subzero 550 never stops running. everything is working fine, just had freezer compressor side charged. it just seems wrong to be always running??
try to adjust your thermostat normal setting maybe you set it to maximum setting thats why the temp. cannot reach even your comp.running long hours. or maybe your ref . is over loaded try to lessen the load or your door is have leakage of cold air try to fix gasket.
Mar 04, 2011 | Sub-Zero 700TC Bottom Freezer Refrigerator
My Sub Zero 550 model seems like it is running all the time. It is too cold in the refrigerator compartment,and the condenser fan runs constantly. Adjusting down the temp control has no effect. Freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 15, 2010 | Sub-Zero 650 / O Bottom Freezer...
Freezer reads 00 but the frig section reads 57....where is the line to the frig...seems that is plugged
i coud not see the model # of your sub zero . some models like th 550 / 650 use 2 compresors . freezer system maybe ok when fresh food is not . . first thing to do is ck the cond coil up on top and clean it and mk cure the fan is cooling the coil . you moy have a cold control failure . and the fresh food comp may be low on gas . these are the most common cause for your problem .. mm feed back pls ..
Oct 24, 2010 | Sub-Zero Bottom Freezer Refrigerator
I have a sub zero (model 550) bottom freezer. Moisture appears to gather at the right side of the freezer then ices up to the point that the drawer can not be opened. I have replaced the drawer seal and...
I had this problem several times and have learned alot. Hopefully some can benefit from my learning and mistakes.
On the inside of the freezer on the right is a drain tube. The defroster cover flows into this little drain. This drain goes into the pan at the bottom of the freezer, and the water evaporates. My subzero 550 had an old drain heater already in there, but obviously not working properly.
First, defrost the freezer completely. I had also poured hot water down this little tube, but this takes too long, and doesn't clear the drain completely. Also, see if you can tolerate turning the freezer temp setting down. I had mine at 1, and it was sufficiently cold. With this simple method, note the weeks /months until it happens again. If you can live with this, you are done.
If not, order a drain heater (contact Clarke Customer at 800-305-0722 and order item number 4202160, Freezer Drain Heater - under $40). I installed this and got some success, and am still counting the weeks after 8 have already passed.
Good luck
May 16, 2010 | Refrigerators
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero Bottom Freezer Refrigerator Logo
296 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
