Question about TurboChef TORNADO Electric Oven
What does f3 mag mean on the display? - TurboChef TORNADO Electric Oven
    Scholar:
  • 75 Answers
F3: Magnetron Current Low
Fault is displayed when the current transformer
(CT) on the I/O control board does not detect
enough current. The fault is monitored when the
microwave is on during a cook cycle or self-test.
The fault is cleared from the display at the onset of
a cook cycle if the CT detects current or when the
magnetron is successfully energized in Test Mode
Posted on Nov 01, 2010
Display shows food done within 2-3 seconds. cycle is programmed for 15 seconds heating What is causing the problem
That typically means the microwave circuit is not powering on so the oven turns itself off. Most of the time when that happens you will get an error code flashing on the bottom of the screen. If F3 MAG CURR. Look at my previous answers on fixing that
Oct 11, 2015 | TurboChef C3 Single Oven
F3 Mag Low Current
did you check transformers. also k1 , k2, k3, relays. also make sure all wires are put back right and the diodes are going in the right direction.
Mar 29, 2014 | TurboChef TORNADO Electric Oven
I have a turbo chef oven, I have F1 and F5 error on the display! Any suggestion?
Troubleshooting...
Faults Requiring Service Call
If one of the below faults appears on the oven display, call 800-90TURBO (88726) or +1 214-379-6000.
* F1: Blower
* F2: Low Temp
* F3: Mag Curr
* F4: Monitor
* F5: Mag Temp
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 01, 2011 | TurboChef TORNADO Electric Oven
"F3 MAG CURR" error message,
Its a big pain in the *** issue.
IF YOU KNOW HOW TO USE CLAMP AMMETER THEN ONLY YOU CAN USE MY METHOD TO TROUBLESHOOT IT.
MAKE SURE OVEN HAS 5000V IN THE CAPACITOR.DISCHARGE THEM FIRST .
AND IF YOU DON'T KNOW THEN STOP HERE
STEPS
1. open right side pannel
2. press back key to turn off oven
3. press back and enter key simultaneously.
4. enter 9428 then press enter.You are directed to testmode.
5.put clamp ammeter on the primary wire(orange in color).The one which come from top and looping the IO board.
6.Under Displaty screen you see Word Magnetron.Press and hold the soft key to energize the magnetron.
7.Check the amperage.It should be under 14-16 Amps.
8.If its half of the value or nothing comes then.
9 half value means(one magnetron is working
10. No value means F3 fuse blown and check the cause why it blown(physically look at the transformers and the capacitors and the diodes that they didn't burnt or change their shape.
IF YES THEN REPLACE IT.
OKAY LET ME KNOW IF YOU CAN REACH UPTO HERE .
AND REPLY ME
THNAKS
PLEASE RATE MY WORK
Sep 06, 2011 | TurboChef TORNADO Electric Oven
Hi, F3 mag curr. what is means and how do I fix it?
F3 is an complex code.
Easy fix is look at the transformers and the capacitors and the diodes.If it seems that any component has changed its appearence then fix it and replace the F3 fuse(3rd one from the front).
If the magnetron is bad ,then to check that you must know how to use clamp ammeter.
let me know if you know how to use clamp meter .
I will give you the solution .
NOTE oven has 5000V in it.
make sure you dischared the capacitors.
Thanks
please rate my work
Apr 16, 2011 | TurboChef TORNADO Electric Oven
F 3 mag error. had a bad magnetron and hv transformer. went head and changed both hv transformers,diodes,caps,magnetrons. worked for about 5 hours and its back to blowing f3 fuse. Any ideas
F3 errors can indicate a mag problem. Did you replace both mags? It can also be a door switch. If your fuses are good, you need to inspect the 2 magnetrons. If you have a burned tip on one the waveguide and waveguide cover it will need to be replaced.
Feb 05, 2011 | TurboChef TORNADO Electric Oven
TURBOCHEF TORNADO OVEN...Errors F3 Mag Current and F5 Mag Temp just began. They appear occasionally, now and then. Oven temp seems about right to me. What needs replacing or attention? Thanks!
the mag's only activate while in cook cycle, it will be hot as normal with toasted subs that are cold in the center.
AMP draw the Mag's and ohm the Mag thermal couples
Oct 14, 2010 | TurboChef TORNADO Electric Oven
F3 MAG Error
open the right side panel and change 3rd fuse from the left
Oct 18, 2008 | TurboChef TORNADO Electric Oven
How did you fix your F3 Mag Cur code?
There are 2 mags in this oven yo have to figure out which mag is bad and replace it. This can be tricky and dangerous since there is a 4800 volt cap you will have to disconnect.
Oct 17, 2008 | TurboChef TORNADO Electric Oven
TurboChef TORNADO Electric Oven Logo
530 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Shehu Pro
Shehu Pro
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
