Question about Maytag Neptune MDG5500AW Gas Dryer
My dryer doesn't heat up - Maytag Neptune MDG5500AW Gas Dryer
  • 10,319 Answers
Inspect and clean the exhaust venting system thoroughly and try it again. A moister sensor detects lint build up and puts the heat into a check mode.
Posted on Sep 03, 2010
Change element in a samung dv665j
Usually, one takes the rear cover off revealing the element area. I doubt if the heating element is burned out. Typically the small thermostat or thermal fuse link blows before the heating element goes. You would have to see the diagram of your model online. Most sites have the exploded parts view of that section online. If you don't have a meter tester you may have to replace all 3. Some models have them all tied into 1 board. This site has video troubleshooting. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-160-1067262-/Samsung-Dryer-doesn-t-heat-DV665J Samsung Dryer Doesn Heat
Sep 13, 2014 | Samsung Dryers
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Dryer doesn't shut off and doesn't get hot
Look at this video to help you fix the no heat issue.
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
My Maytag gas dryer won't heat
Hello Todd,
Their are several things that could cause the dryer to not heat, i have posted a tip i wrote what to check whena gas dryer doesn't heat
http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Nov 12, 2011 | Maytag Dryers
Dryer runs but no heat. My husband is pretty smart with appliance fixes. Do you think that this thermal fuse solution would be easier enough for him to fix or should we get a repairman?
The thermal fuse is not going to be the problem...when the thermal fuse has gone out the dryer will not start so since it runs the thermal fuse is good. The number one thing that is wrong with a gas dryer when it doesn't heat is going to be a broken igniter,this tip i wrote explains what to check when a gas dryer doesn't heat http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 12, 2011 | GE DBXR463GD Gas Dryer
Clothes dryer don't run
sounds like a bad cycle timer switch
Apr 22, 2009 | General Electric Clothes Dryer Knob -...
Dryer doesn t get hot
it is going to be either the igniter for the gas or the heating element
you probably have an electric igniter. it is not igniting the gas to make the dryer heat i would definantly start with that
Jan 07, 2009 | Kenmore Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
