posted by towwman on May 11, 2008
some tell me its the voltage regulator & some say its the stator.how do I check if its the stator
1 Other User Has The Same Problem
Comment by Guest, posted on May 23, 2008
low charging on a 1998 ultraclassic, tested the stator..... 30 AC v at 3000 rpm..is this low?
Solution #1
posted on May 18, 2008
The only defect a stator would have is it's either delivering no or low voltage output. By design, it will always put out higher voltage than required. It is the job then of the regulator to control how much is pushed to the battery. If the battery is overcharging, then the regulator would be at fault.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Harley Davidson Harley-Davidson
Email this problem
Email this problem
Can you Help with these Phones problems?
Harley Davidson Harley-Davidson Motorcycle...
no fire
no fire
i have a 98 fatboy and when the... Answer This...
turn signals
turn signals
My turn signals quite working... Answer This...
04 1200 Sportster - backfires -...
Have had 2 dealer ships work on... Answer This...
motorcycle bag install
quick release harley davidson... Answer This...
check engine light
check engine light
check engine light comes on... Answer This...
Repair Service
Find Phone Repairman Near You:
