Question about Protron PLTV-32 Television
No Picture, Indicator Light Green
I turn on the TV, the indicator light goes green, the backlight comes on, but no picture, after you turn it on that way, (using the "button" on the tv, the remote dosen't seem to do anything), you can only turn it off by switching the main switch on the back next to the power input. I tried what the tech support said about "letting it sit idle unplugged for 30 minutes or more, then turn on with remote only and hold power button for 8 - 10 seconds", which i think is a load of bullsh*t, i think it's just to get you off the phone.
If anyone has any ideas, please let me know..
  • 1 more comment
  • John Budzichowski May 11, 2008
    I just disassembled the back of the TV to look at the power supply, but what the back has on mine is just the regular 3 prong computer like plug, then it goes into a PCB that has the usual odds and ends of the inside of a monitor on it, so it dosen't have the typical power supply like say a laptop or other monitors, it's just a standard plug.. any help here as to what i should look at to fix this?
  • John Budzichowski May 15, 2008
    I have actually fixed this problem. It would do what i stated above. So i removed the back, and started unplugging a plug, turning on the TV to try to get any kinda of response out of it. One plug i picked did it, turns on, but i do not know what features it disabled, I can get my computer to hook up and work fine with it, so .. If someone has a wiring diagram for this TV, i could tell you what I did to fix it. more specifically
  • Anonymous Sep 17, 2008
    Hi the green light comes on if i touch any button on the tv the blue light will flash the remote does nothing once it has turned the red light to a greeen light. I would be happy if i could just use it for a pc screen but i get no responce at all from the tv could any one pleasde help. thank you gordon.
  • 2,326 Answers
If your TV is a year old or more, chances are that the power supply is starting to fail on your TV, causing all kinds of erratic behavior up to the point of not turning on anymore.
I service these power supplies since it does not look like there are many service parts available anymore. The only way to get this TV functional again is to repair the power supply to the component level.
Posted on May 11, 2008
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
No sound and no picture
The green indicator merely lets you know that power is getting to your TV. The absence of picture and sound could be due to power supply failure
May 18, 2013 | LG Televison & Video
DX-LCD32-09 green light and backlight comes on for about 5 seconds and then backlight goes off green light stays on
Hallo there
You could try to adjust the colour setting in the PICTURE menu and keep a enough distance between the tv and other electronic objects in the room.
Give it a try
Kolbrun
Mar 17, 2012 | Dynex DX-LCD32-09 LCD TV
My mitsubishi hdtv1080 is stuck on camcorde, how can I get it off?
When I turn the Mit. 1080 on, the green indicator light comes on for about 3-5 seconds then it goes off. TV never comes on (no picture or soun, nothing). What is the problem. thanks
Feb 06, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Picture goes out after 3 seconds then may come back on then off again
If green light in front of TV blinks while picture goes off and comes back then its symptom of weak lamp that need to be replaced.
And if green light does not blink in above process then let me know.
Thanks.
Nov 23, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
How to get a picture and sound
if you still have a problem (and the tv!) email me at gmail.com
Nov 09, 2006 | Protron PLTV-32 Television
Protron PLTV-32 Television Logo
146 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
