Question about Yamaha HTR-5840 Receiver
Shuts off My Yamaha HTR-5840 won't stay on after I push the on power/stand-by button. It stays on for a few seconds and then a click sound is heard before it goes off. I reattached all speaker cables, then removed them one at a time, then removed them all and it still happens. Thanks for your help. Brian
  • 1 more comment
  • Anonymous May 13, 2008
    Hello my name is Terry I have this same receiver,I have 4 main speakers,2 rear surround speakers and a subwoofer,dvd player ,cd player,and hi definition digital personal video recorder.After playing my stereo at 70% volume level for about one & half hours the stereo turns itself off ,I turn it back on ,sometimes it shuts off again right away,other times it takes ten to twenty minutes to do it again.I have tried running just 2 main speakers instead of 4 and it still happens.I took the receiver into a electronic repair shop and they ran some test and found nothing wrong with it.After bringing it back home and hooking it up to the rest of the stereo,the same continues to happen. Please help if you can.
  • holmem May 26, 2009
    I have the same receiver. I moved my system to another cabinet, noticed that after years of being crushed too tight in the back, the panel with the speaker connections is warped and pushed in. When I first reconnected my speakers, I had a failure that was also immediately tripping the shutdown and powering off. Then would display "check speaker conn" when powered back on. The speakers are all ok (work on other channels), but this one rear channel now has no sound, but no longer trips. I'm assuming I've either lost the amp, or there is a physical fuse (componet type) somewhere. Can I get a schematic or just a diagram of where to look, or possibly help with identifying which transistor to go after? Is it possible the speaker post has broken loose from the internal connection to the board? Thanks!
  • Anonymous Mar 13, 2014
    I used to hear sound effects out of the rear surround speakers but haven't heard anything in a long time. Could I have possibly turned it off somehow on the remote?
    Novelist:
    Champion:
  • 236 Answers
Brian, you have a system failure in your audio amp section. this is a multiple channel amplifier and you have to get it checked only by service personnel. your power outputs transistor probably busted and your unit wont stay because that is your protection circuit working. it protects your unit from further damage.
and for the other comment, your unit will shutoff after long epriod of time at 70%, you need more ventillation to your unit. i would suggest that you use a small fan or blower and place on top of the unit. this will provide more air circulation to your amplifier. The units is tripping already at high temperature and 70% is already a long way to go at more than an hour with all channels working. adwditional ventillation only will help you. dont let it happen though always or it will damage you amp and end up like the later unit that turns off after few seconds. busted output stage already.
Posted on May 14, 2008
Diode problem
Posted on May 11, 2008
Using Bose 901 Equalizer on Yamaha HTR-5840 Reciever
The manual is linked below. Page 19 advises you to use the "MD/CDR" - "IN (PLAY)" and "OUT (REC)" analog audio jacks.
http://data.manualslib.com/pdf/20/1975/197493-yamaha/htr5840.pdf?ace7c7b79ec34305a811125fb9ef1160&take=binary
Jan 27, 2014 | Yamaha HTR-5840 Receiver
Won't stay on
You're best bet would be to buy compressed air and blow out all dust and dirt that has made its way inside the receiver. If dust is clogging the fans it will overhead and shut itself off.
Mar 14, 2013 | Yamaha Natural Sound Htr-5660 6.1 Channel...
Location of fuse in yamaha htr 5840 receiver
This is old, but unplug the unit, remove the cover and check the vertical power board where the plug wire enters. There are two fuses on this board, both are 8A125V. These are the only fuses in the unit.
Jan 25, 2012 | Yamaha HTR-5840 Receiver
Yamaha htr-5840 won't work with comcast remote codes, tried all codes, nothing will work, remote is Comcast dvr 3 device
I have a Yamaha RX-V571 AV Receiver and the published codes don't work for my Comcast silver remote w/ Red OK button. Managed to make it work while living in MD. Now in FL, have new remote and don't remember how I made it work before. Would love some help. T Y
Sep 19, 2011 | Yamaha HTR-5840 Receiver
Yamaha receiver model HTR-5840 will not switch on.Fuse is o.k.
By fuse OK you do mean the one inside it? If so check the power switch, then check the power transformer.
Mar 05, 2010 | Yamaha HTR-5840 Receiver
No sound from htr-5840 when switched on. I hear
These units have protection circuits that will prevent the speaker relay from engaging if there is a problem detected. There is also a circuit that causes a delay in the engaging of the relay to allow the amp to "settle in". This prevents the old "thump" that was common in older models when the set was first turned on. In your case, either the RC circuit is faulty causing excessive time to pass before turning on the relay, or there is excessive voltage floating around that the protection circuits are detecting and thus preventing the relay from turning on.
In any case, this will require additional diagnosis using some test equipment. This is not a problem that will be easily resolved remotely. Please bring this unit to a repair shop for an estimate. Once you have that info, we can assist with the actual repair.
Dan
Aug 25, 2009 | Yamaha Audio Players & Recorders
Htr 5590
Mine played for about and hour then cut off. It would cut off randomly after this hour. I initially thought it was overheating but after seeing other people had it happen after immediate turn on it must not be the case. Intermittent problems like this are difficult to troubleshoot which is why I came to this site hoping someone had found a simple answer. I am a technician and will have to do it the hard way. When I find the answer I will report my findings to this site.
Apr 14, 2008 | Yamaha HTR-5590 Receiver
HTR-5790 shut off problem
WOW this worked.. Hold down the ABCDE and the preset tuning right arrow and then hit power.. It puts it into a diagnostic mode, but it stays on.. I just rerouted my video to not use the receiver  and the audio works perfectly now.
Nov 26, 2006 | Yamaha HTR-5790 Receiver
Yamaha HTR-5840 Receiver Logo
408 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
