Question about Bogen Communication Bogen / Manfrotto 516 Pro Video Fluid Head 516 Tripod
Head does tilt smoothly on 516. How do I get it smooth? Eric
    Problem Solver:
  • 15 Answers
Not fully understanding your question. You stated that the "head does tilt smoothly on 516. How do I get it smooth". What are you asking exactly? How to smooth out the pan as well, or how to make it tilt even smoother?
Posted on Sep 07, 2010
How do I change a burner on a smooth top stove?
usually the top will tilt back so you can get to the elements .
Apr 09, 2016 | Kenmore Kitchen Ranges
The Tripod Head Pan and Tilt are EXTREMELY difficult to move.
Un;less something is caught inside the working parts, or there is grit inside, it should move smoothly. I would recommend that you send it in for repair. http://www.manfrottotripodparts.com/repairs.html
Feb 21, 2014 | Manfrotto Mk394-h Photo/video Tripod Kit
Need part # for slides
Part number for the from slides that allow the tub to glide smoothly is WE1M504 and your unit requires four of them. Good Luck, Eric
Mar 22, 2012 | GE DBSR453EBWW Electric Dryer
Hi. Our 8560MFP has come up with the error code 07,010.43:93096, plus the message "power down error - head not parked" - is this something we could look at ourselves or do we need professional...
7,010.43 Printhead is stuck or is not tilting properly over the cam.
Initial Actions
• Check that the Process Drive gear train is properly homed.
• Check for obstructions or ink spills around the Printhead.
• Verify the Printhead travels smoothly from left to right.
• Check the Printhead Restraint Arms.
• If the problem persists, follow the procedure below.
Table 1 7,010.4x through 7,015.4x Troubleshooting Reference Table
Applicable Parts Wiring and Plug/Jack References
Process Drive, PL 4.0 Right Side Harness / I/O Control, Figure 8
Head Tilt Solenoid, PL 4.0 Left Side Harness (2/2), Figure 5
Head Tilt Gear, PL 4.0
Restraint Arms, PL 2.0
Head Maintenance Clutch, PL 4.0 I/O Board (2/2), Figure 10
Table 2 Printhead Restraint Fault 7,010.xx through 7,015.xx Troubleshooting Procedure
Step Questions or Actions Yes No
1 Reboot the system.Does the error persist? Go to Step 2. Complete.
2 Check the Printhead Lock Arms. Go to Step 3. Repair or replace Do the arms rotate correctly? the Printhead Restraints
3 Check for ink spills around the Printhead Go to Step 4. Remove ink spills or obstructions.
and Printhead Tilt Gears. The Printhead
should move when pushed left or right.
Is the area around the Printhead clean
and unobstructed?
obstructions.
Jul 04, 2011 | Xerox Phaser 8560MFP Laser Printer
We are getting white vertical lines running through our barcode label. it looks like printer ribbon is wrinkling when printing them on long runs. How can we stop this
When you have this problem you need to determine if the ribbon is wrinkling before or after the head. If it is before the head then you need to adjust the bar prior to the head. There should be a phillips head screw there and directly behind it there is an adjustment. Loosen the screw and then move the bar (it is slightly arc'd) so it smooths out the ribbon. This is the least likely suspect. Most likely the head is not square. If the head is not square with the roller below it will cause the ribbon to "dance" as I call it. It will slowly move over then jump back to its rightful position. Or it could just wrinkle. If this is the case and your print looks good then you can adjust the ribbon bar right where the ribbon comes out of the head. There are two screws at the top. Loosen both of them and this adjustment bar will slide all the way back. Once this goes back. Manually manupulate it until it smooths out the ribbon. Once you manually figure out where it is smooth then tighten the screws back up. Feed a few labels and see if the ribbon is smooth.
Jan 27, 2011 | Datamax I-4208 Thermal Label Printer
The head of the mixer is vibrating (shaking) a lot when mixing. It does this so much that I feel as though I need to hold onto it when it's mixing. If I turn it on without the bowl and just run the...
I am sure you are locking the tilt head in the down position when your using it right? If so then check to see if the beaters are hitting the bottom of the bowl. If they are then there is an adustment screw that sets the height of the head in the down position.
Jan 01, 2011 | KitchenAid Classic Stand Mixer
My drivers side head light goes off and on. what can it possibly be?
First remove head light bulb and look at the little spring in it, check that it is smooth from one end to the other, if it's not smooth could have a break in it and when you hit bumps it stops making connection and light will go off and back on, if bulb is good then you need to start checking ground.
Jun 30, 2010 | 2000 Volkswagen Jetta TDI
Cooktop light stays on after all control have been turned off
Smooth Top? Light is activated by a thermostat on each burner under the glass. Most are available only as part of the burner assembly and not as a separate item.
Eric
Dec 08, 2009 | Whirlpool Kitchen Ranges
Photography Logo
178 people viewed this question
Top Bogen Communication Photography Experts
Tony
Are you a Bogen Communication Photography Expert? Answer questions, earn points and help others
