Question about LG LRE30451 Electric Kitchen Range
Burners not working on LG stove - LG LRE30451 Electric Kitchen Range
I lost power for a week after a hurricane and my Lg stove reads Ncal, the burners work but the oven doesn't and every time the stove top is used the fan stays on all the time
Hello -
The Ncal error code on your LG gas range may mean there was damage to the oven control board, which is electrical. There could have been damage to the wiring.
Personal opinion: Contact an authorized LG gas range repair center and arrange for a repair technician to come and take a look at your stove.
Best wishes.
Jan 17, 2018 | LG Kitchen Ranges
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Lg STOVE MODEL LST5651SW BURNER STAYS ON, DIDNT NT TURN OFF OR COOL DOWN ONCE TURNED ON
Its not the burner, but the switch or relay it controls. With a meter you can track it down an order the part yourself. Be sure to look for things like bugs. I found a bug in a clock that caused problems once. Becareful you are dealing with high voltage. If you are not sure call a tech.
Jan 28, 2015 | LG range & stove radiant cooktops...
How do i open the top of stove to clean its lrg30855st
Turn off the gas. Lift off the burner cap and the burner head from all remove the torx screws under each of the five burner heads then lift off he top. The picture on these two pages of the manual show where the screws are and what the stove looks like with the top off:
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=21#manual
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=22#manual
Oct 05, 2014 | LG LRG30855ST Stainless Steel Gas Range
Can I replace a kenmore stove burner with a GE burner
It depends on the Kenmore Model. Kenmore is the brand name for models sold by Sears, but they are not all manufacturered by the same company. They are made by Frigidaire, GE, Whirlpool, Amana, Samsung, LG... just to name a few. If you can post a model number of your Kenmore, I can give you the options for which elements will work for your machine.
Jul 11, 2013 | Hotpoint WB17X5113 Stove Surface Burner...
Hi i have a lg lrg30355st (lp gas) gas range. i
Hello I have the same stove and same problem...also boiled water and now it wont stop clicking...Did you ever get yours fixed? if so, what was the problem? I unplugged every wire one by one (except purple and white ones) from the spark module and still no luck.
Jul 03, 2010 | LG Kitchen Series 30" Self-Cleaning...
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
Lg flat surface stove burner
Replace your infinite switch for this (your lf burner switch). Call a parts supplier with your model number, try and get an exact switch, not a generic switch. Do not replace the switch without unpluggin your range first. Good Luck, Appliance Specialists
Jan 28, 2010 | Kitchen Ranges
LG stove F-1 display stays on. Burners or oven won't work.
Your control is faulty. Check your owners manual for a two year warranty on eletronics. If not under warranty you need to call an authorized LG service dealer.
Jan 16, 2010 | LG Kitchen Ranges
Center burner igniter does not spark.
I had the same issue and it was because the little ceramic starter "button" wasn't either pulled up, or down (I don't remember). The stove is shipped with the piece in the opposite direction it's supposed to be in when operational.
Apr 24, 2009 | LG LRG30355 Gas Range
LG LRE30451 Electric Kitchen Range Logo
317 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
