Question about RTO Stairmaster Clubtrack 510 Treadmill
Hola expertos! tengo una caminadora quinton hyperdrive club track plus que primero simplemente al encenderlo no funcionaba ningun boton, despues de no usarla varias meses la volvi a encender y funciono bien como 5 minutos y ahora marca E203, que hago? vivo en oaxaca, mexico y no hay muchas opciones para mandar a arreglar este tipo de caminadoras, ayudenme porfavor, gracias
2 Suggested Answers
SOURCE: I have a quinton club track treadmill that posts an E203 error
E203 = Motor unable to run. Usually caused by the VSD Lower Board. This board is about 14" square on a Quinton Clubtrack Hyperdrive 3.0
Rather difficult to remove escpecially if your not familair with electronical compnents in a tight space.
My reapir coast $374 from J&R Technical Services and exactly one year later I got the exact same code. Warranty is 90 days.
It appears they rebuilt one of the components on the board called a Phase Modulator. There are three of them. They stated they had replaced it, but upon close inspection it appears that simply replaced the bad micro-component on the modulator and reinstalled the exact same phase again.
I'm debating whether to trust them once again. Little choice though since they control the market and have the equipment to reset the board upon repair. Nobody at thome has this equipment.
Posted on Nov 24, 2009
El control no quiere cambiar de canal
Hola Miguel, es un placer ayudarle. Al parecer tendra que programar el control al receptor de DISH. Para programar el control de DISH Network a su recibidor puede seguir los siguientes pasos: primero debe de accesar la pantalla de System Info esto lo puede lograr con tan solo oprimir el boton que dice System Info enfrente de su recibidor. Una vez este la pantalla de System Info tome su control y oprima el boton se Satellite por 5 segundos hasta que todos los demas botones se iluminen en rojo una vez esto suceda oprima el numero 8 seguido por el signo de numero (#) y despues boton de Record 3 veces. El control deberia de funcionar, puede intentar su funcion oprimiendo el boton de Cancel esto deberia de llevarlo de regreso a su programacion. Puede usar este link que tambien le puede servir mucho en como arreglar su control y los pasos seguir http://www.dishnetwork.com/SupportSection/remote-control
Si tiene preguntas adicionales por favor sientase libre de contactarme a kimberly.escobar@dish.com
Kimberly Escobar
Social Media Representative
DISH L.L.C
Jan 12, 2014 | DISH Network IR Remote Control
Necesito programar mi television sanyo pero no tengo control remoto
Hola Rodolfo, para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales por favor contacteme a kimberly.escobar@dish.com.
Dec 26, 2012 | DISH Network IR Remote Control
Como enlazar un control remoto IR 103602 con una caja receptora DishDVR510
Juan Carlos Hola, se que ha este punto quizas no necesite asistencia con la programacion del control. De todas maneras le dare los pasos a seguir en caso de que los llegue a necesitar en un futuro. Para programar el control de DISH Network a su recibidor puede seguir los siguientes pasos: primero debe de accesar la pantalla de System Info esto lo puede lograr con tan solo oprimir el boton que dice System Info enfrente de su recibidor. Una vez este la pantalla de System Info tome su control y oprima el boton se Satellite por 5 segundos hasta que todos los demas botones se iluminen en rojo una vez esto suceda oprima el numero 8 seguido por el signo de numero (#) y despues boton de Record 3 veces. El control deberia de funcionar, puede intentar su funcion oprimiendo el boton de Cancel esto deberia de llevarlo de regreso a su programacion. Puede usar este link que tambien le puede servir mucho en como arreglar su control y los pasos seguir http://www.dishnetwork.com/SupportSection/remote-control
Nov 20, 2012 | DISH Network IR Remote Control
Codigos de programacion para mi tv tecnomaster
mi televisor teenomaster modelo ttv-2124pf y chasi 01-11-ttv2124pf1026 se bloqueo y solo prende y apaga por el control no realiza ningun mando adicional no cambia ni puedo vajar ni suvir el volumen
Mar 05, 2012 | DISH Network IR Remote Control
Hola tengo un control dish network y una television philips y no tengo el codigo
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televisor Philips. Hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Sharp tenemos los codigos 566,770,741,628, y 521. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 566#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contacteme directamente al kimberly.escobar@dish.com. Gracias y espero esto le sirva de ayuda.
Feb 17, 2012 | DISH Network IR Remote Control
Como puedo programar una tv samsung con el control de dish
Hola! Mi nombre es Kimberly Escobar con DISH Network, sera un placer proveerle la informacion que necesita. Para programar el control remoto a su televisor Samsung hay ciertos codigos que puede integrar al control para que funcionen con la t.v. Los codigos para un televisor Samsung son los siguientes: 738, 516, y el 680. El procedimiento a programarlo el el siguiente: Oprima el boton de t.v localizado en la parte de arriba del control por 5 segundos hasta que todos los demas botones se iluminen rojos, una vez esten iluminados ingrese uno de los codigos seguidos por el signo de numero (#) por ejemplo 738# el boton de t.v deberia iluminarce 3 veces, despues de esto puede tratar las funciones. Si tiene preguntas adicionales puede contactarme directamente a kimberly.escobar@dishnetwork.com
Kimberly Escobar
DISH Network
Aug 07, 2011 | DISH Network IR Remote Control
Hola mi nombre es jose acabo de comprar una lg tv pero el control solo funsiona con el dish y no puedo encender o apagar la tv antes tenia una sony bravia y si funcionaba perfectamente.
Hola mi nombre es Kimberly Escobar con DISH Network lamento mucho que este experimentando este problema. Sera un placer ayudarle y proveerle la informacion que necesita. Para programar el control de DISH Network con su televisor va a necesitar integrar un codigo que sea compatible para el control y la t.v. Ciertos codigos que se pueden integrar al televisor son los siguientes: 678, 156, 520, 505, 654, y 627. El prcedimiento para integralo es el siguiente: Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 654#. El botond de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si necesita ayuda adicional puede visitar este link aqui puede encontrar mas codigos y el proceso a programar el control http://www.dishnetwork.com/SupportSection/remote-setup Tambien puede contactarme directamente a mi correo electronico kimberly.escobar@dishnetwork.com.
DISH Network
Kimberly Escobar
Jul 22, 2011 | DISH Network IR Remote Control
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
Silvania
Ulises realmente es un caso extrano, pero bueno todo puede pasar.
Fijate si no hay ningun boton en el televisor donde se pueda hacer un Reset
Esto seria de gran ayuda. Generalmente los botones de Reset no se ven, no estan a la vista, a los cuales se accede con algun pin u objeto.
Oct 20, 2008 | Televison & Video
RTO Stairmaster Clubtrack 510 Treadmill Logo
89 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
