Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Leaking water and replace filter light not resetting after filter replacement
My Kenmore side by side refrigerator is leaking water inside and on to the floor. Also, I replaced the filter and the replace filter light is still red.
  • mworthen10 May 11, 2008
    yes the filter is installed correctly. The frig was leaking prior to filter replacement. My original thought was the filter was clogged and/or frozen so I replaced it first without any relief from leaking and light on
  • 117 Answers
Take a look behind your ref at the water valve if you can see a broken plastic line
Posted on May 11, 2008
    Genius:
  • 1,073 Answers
Are you sure that the filter is installed corectly
remove the filter and reinstall it to be sure
Low water pressure & ice maker problem
Hi! you don't say how old the refrigerator is, but if it has a water filter, the problem may be that the water filter needs replacement. If there is a water filter, it may be inside the refrigerator side, usually up top towards the back.
If you see a filter, you can buy a replacement at Sears. While your there, check out their water filter subscription. They'll send a water filter to your house on schedule, so you can replace it when needed.
Oct 28, 2013 | Kenmore Refrigerators
Red light on to replace water filter, how to do this?
Knowing just who made your Kenmore refrigerator may some day be important because Kenmore does not make the brands they sell. I am going to try to get you as many different ways the water filter can be changed as I can but if you can you locate the model number of your Kenmore it may make things much easier should you need parts or a manual some day. The number should look like this 521.345678 and located around the inside of the fresh food section door.
Here nis what I have found on different models and water filters from Whirlpool How to Replace In-Grille Refrigerator Water Filter - Push Button
How to Change the Water Filter in Your Refrigerator
Whirlpool Part UKF7003
How to Change a Kitchen Aid Refrigerator Water Filter
Read more:
If by chance you are able to find your model number that looks like the 513.235647 I mentioned before this will solve just what instructions you need or you can post a photo here or swend one to my email appliancepartsse (@) yahoo.com and I will be glad to help you get a manual and instructions for changing your water filter, Thanks Sea Breeze
How to Replace Interior Refrigerator (Filter1) Water Filter
Jun 25, 2012 | Kenmore Side by Side Refrigerator
We have a Kenmore Refridgerator in our rental apartment. The light for the water filter went to red. We called the landlord but they claimed that they replaced it 3 months ago. They suggested we hit the...
recommended replacment time is 3 months and the computer knows it was replaced 3 months ago and has counted down the time the reset button was last pressed and determined its been 3 months. Depending on water quality in your region it may not need to be replaced unless the in door water or ice taste funny or the water dispenses slowly through the door because the filter was clogged and having a hard time having water pass through it.
Aug 17, 2011 | Kenmore Side by Side Refrigerator
How do I change the water filter
Removing and replacing a water filter - upper right hand corner location
Filters situated in the upper right hand corner of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • These eight inch long filters are housed in their own compartment. The base of the compartment can be released by pushing in on the release clip found at the end of the housing unit. Allow the base of the housing compartment to hang down while you remove and replace your filter.
  • Twist the spent filter to the left (counter-clockwise) and gently pull on it to remove it. There is an automatic water shut off to keep leaks and spills to a minimum.
  • Remove the new filter from its packaging. Remove the plastic wrap, and peel off the aluminum topping. Insert the new filter into the housing unit. Twist the filter to the right (clockwise) until it clicks into place. Replace the base of the filter housing by cliping it back in place.
  • Condition the filter by dispensing several glasses of water through your refrigerator. This ensures that all fine carbon particles have been removed.
  • Check the filter and the inside of the refrigerator for leaks. If you find a leak, remove and install the filter again.
  • Finally, reset the 'change filter' indicator light, if your refrigerator has one, at the front of your refrigerator. The procedure for resetting the change filter indicator light can vary from fridge to fridge. Typically, the indicator light can be reset by holding down on the 'lock' button and the 'water' button simultaneously for three seconds. Sometimes, it is the 'lock' and the 'light' button you need to press down on simultaneously for three seconds in order to reset the filter indicator light.
Removing and replacing a water filter - center ceiling location
Filters situated in the center ceiling of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • Turn the filter a quarter turn to the left, in a counter-clockwise motion. The 'unlocked' symbol on the filter will be lined up with the indicator line that is molded into the refrigerator just above the filter. Allow the ears of the cartridge to disengage from the filter holder.
  • Gently pull down on the filter, being careful to not spill any water still in the filter. Discard the used filter.
  • Remove the new filter from its packaging. Remove and discard the red plastic cap found on the top of the new filter.
  • Apply the appropriate month sticker to the filter to remind your self to remove and replace the filter in six months' time.
  • Insert the new filter into the filter opening. Line the 'unlock' symbol on the filter up with the indicator line that is molded into the refrigerator above the filter. Turn the filter a quarter turn to the right, in a clockwise motion. You will be able to feel the filter stop when it is all the way in, and the 'locked' symbol on the filter will now be lined up with the indicator line above the filter.
  • Close the refrigerator door and dispense several glasses of water through the water dispenser in the door in order to purge the new filter of any impurities. Open the refrigerator door again and check for leaks. If you find a leak, remove and replace the new filter again.
Nov 29, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Change filter light
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Sea Breeze
Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
Side by side refrigerator- water dispenser clogged and now leakin
i'd shut off the water take apart and clean change water filter.
Jun 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Leak at filter
Nope. You can't bypass the tube style filter... it's the housing that cracked. That has to be removed and replaced. Sorry to give ya bad news, Mariner.
SG
May 30, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Water filter replacement
I have the same problem. I did change the filter located on the bottom front panel of the refrigerator, but the red light is still on and NO ice. I can't figure it out and I know if I call a tech, its a 300.00 bill. Frustrated.
Sep 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
206 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
