Question about Uniden Cordless Phone
Buzzing on the phone line with incoming calls on a uniden CORDLESS phone - Model # XC310
  • 81 Answers
Unplug your Phone and plug in a regular un-powered phone. If it rings your cordless base station is bad and you will need a new one if it does not ring then there is a problem on your phone line and you need to contact your phone company. Note, the phone company will charge you for repairs inside your house.
Posted on May 04, 2011
How to go back to find incoming calls
That depends on the model. Since you neglected to specify the model of your Uniden cordless phone, I can only suggest you select it from the list beginning here to download a copy of the manual.
Nov 24, 2012 | Uniden Cordless Phone
Where are incoming call numbers stored?
Since you declined to specify the model of your Uniden DECT 6.0 phone, please select it from the list beginning here to download a copy of the manual.
Jan 14, 2012 | Uniden DECT 6.0 Cordless Telephone...
I have a Uniden cordless unit hooked in 4 lines. Incoming calls ring briefly for about 1 second and go out! You can talk if you pick up but not sure why no normal rings. There is no problem calling out....
When someone calls you and your phone behaves this way, does the caller get disconnected? The phone may be causing this, but it may also be due to trouble in the telephone line itself. The trouble is caused by defective wiring, a partial short circuit. When you pick up your phone to call out, the voltage on the phone line is low and it works normally. When you get an incoming call, a high voltage is sent to ring the phone. Because of the partial short, the phone company's equipment thinks you've answered the call as soon as the ringing starts. But you haven't picked up the phone, so the phone company's equipment thinks you've hung up and disconnects the call. The result is that short burst of ringing.
Disconnect the cordless phone base unit from the line and try another phone. If you still have the trouble this confirms the line is at fault. You'll need to contact your phone service provider for service. If it's in the outside wiring, they're responsible for repair. If the problem is in your home wiring, you may need to pay them unless you have a wiring maintenance plan.
If the problem goes away when the cordless base is disconnected, then it's time for a new phone.
Jul 16, 2011 | Uniden Cordless Phone
I have a uniden power max 5.8ghz phone and can't turn on the ringer it will not ring when a call is incoming how do I turn on the ringer ?
The procedure varies from model to model. Since you neglected to specify the model of your Uniden Powermax 5.8GHz cordless phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Mar 30, 2011 | Uniden Cordless Phone
No called ID
Does the LCD just display "Incoming Call"? if so please list your model number and I might be able to help you further.
Jun 23, 2010 | Uniden DECT 6.0 Cordless Telephone...
Can not receive calls. Can call out, but incoming calls give a short beep and then a busy signal.
Is this a cordless phone or a land line. Have you tried another phone ?You might wanna talk to your tel service provider.
Jun 13, 2010 | Uniden DECT-1060 Cordless Phone
Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Apr 29, 2009 | Uniden DECT 6.0 Cordless Telephone...
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
112 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
