Question about Mr. Coffee ECX30 / ECX33 Coffee Maker
Lost the manual for my Mr. Coffee model ECX 33, and I'm just wondering how to clean it. Would appreciate any info you have! Thanks.
    Genius:
  • 1,416 Answers
please use this the instruction as manual guard on how to clean up your coffee maker one after the other y
  1. Remove and dispose of used coffee filter from filter basket.
  2. Add vinegar to the water resevoir until 1/4 full. Fill with water until full.
  3. Run the coffee maker.
  4. Turn off the coffee maker; let cool for 10 minutes.
  5. Run the vinegar and water mixture through the coffee maker again. Let cool 10 minutes.
  6. Run plain water through the coffee maker; let cool 10 minutes, repeat.
  7. Hand-wash the carafe and filter basket in soapy water.
little tips
  1. You can also wash the carafe in the dishwasher.
  2. If the vinegar odor is still present after two rinsings, run more water through coffee maker.
thank you and thanks for using fixya.
Posted on Sep 03, 2010
How do I get a manual for my Mr Coffee BVMCPSTX91-WN? the clean light is on and I don't how how to clean it or how to get the light off
The Mr Coffee web site has the manual on the product page: http://www.mrcoffee.com/coffee-makers/mr.-coffee-optimal-brew-10-cup-thermal-coffeemaker-black/BVMC-PSTX91.html . Click on the Service and Support tab. The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-mr-coffee-Site/Sites-mr-coffee-Library/default/v1426159971356/documents/instruction-manuals/BVMC-PSTX91_43_72624326.PDF . (You'll need Adobe Reader or a similar program to print the manual.)
The Clean light will come on when the Clean button is held. It won't go off until the cleaning cycle is complete; it's completely automated. You need 4 cups (20 oz.) of white vinegar or the Mr. Coffee Cleaner (diluted as directed on the package). Make sure to remove the water filter disk from the unit before cleaning. Pour the vinegar or cleaning solution into the reservoir into the reservoir. Put in a paper coffee filter or the permanent filter into the brew basket and slide it into place. Put the empty decanter in place. Now you should press the Clean button until the Clean light comes on. The unit should slow brew 3 cups of the cleaning solution and then pause for about 30 minutes while the Clean light remains on. It should then brew the remaining solution. After the cycle finishes, the Clean light should go off. Afterwards, you need to empty the decanter and rinse it with clean water. Fill the reservoir with fresh, clean water. Then replace the decanter. The cycle could take an hour.
I hope this helps.
(some brewing systems light the Clean lamp when it's time to clean the unit after lime deposits build up. To my knowledge, most of the Mr. Coffee brewers do not.)
Mar 12, 2015 | Sunbeam MR.COFFE 12CUP P/N/PAUSE,CHROM"
How do I clean Mr. Coffe, Model BVMC-PSTX91. I lost the manual that came with a little pkg of to make a solution for cleaning. Please advise. Thank you
I use a quarter cup of white vinegar and the rest water. do it just like making coffee but don't put grounds in it. then run several pots of water through to rinse it out.
Sep 28, 2014 | Mr. Coffee 072179228578 12 Cup Coffee...
Need to set my mr coffee to brew at a certain time
Hi Val: There are a number of 12 cup Mr Coffee models. Instruction Manuals in PDF can be found listed here:
http://www.mrcoffee.com/InstructionManuals.aspx
Thank you for using FixYa!
Oct 20, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
I have a Mr. Coffee model JHX33 coffee maker, and have lost the owners manual I need cleaning instructions. Can you possibly help me?\r\n Thanks Eddie Thatcher
mcdevito75 here, I too have a Mr. Coffee, coffee maker 4 cup. The instuctions shold be just about the same for both our Mr. Coffee mavhines, ------ With a new or clean filter in the machine fill the pot 3/4 way full of White Vinegaar the pour that into the resovior, place thepot back in place on the machine and start the machine up, let the vinegar cycle thru, when done the vinegar is now in the pot, empty the pot back into the resovoir, and cycle again, this time 1/2 way thru the cycle or pot half full stop the cycle for 30 mins. this will keep the vinegar in the machine and claen all the little ports. After 30 mins, complete the cycle. repaet this 2 more times. Then repaet once the machine is cool but this time use plain water, repaeat plain water cycle 3--4 times to clean out all the vinegar, Mr. Coofee needs claening when you notice coffee brewing has slowed down or maCHINE STEAMS TOO MUCH DURING BREWING CYCLE.
Jun 19, 2010 | Juicers
I've lost my manual for the Oster coffee maker model 3314-33 and the red "Clean" button keeps flashing after the coffee has brewed. Where can I download a manual so I can figure out how to fix this...
Pot needs cleaning. Fill reservoir with 4 cups of vinegar. Press the SELECT button until the red CLEAN indicator light turns on. Let it perk through. It will take 45-60 minutes. It brews a few cups, stops and then should brew the remainder of the vinegar. When the cycle is complete the light will burn off and the coffeemaker will turn off. Discard vinegar solution and run a couple of pots of clear water through. Hope this helps.
Aug 15, 2009 | Oster HDX23 12-Cup Coffee Maker
Clean light won't go out, can't use delay brew feature.
Try unplugging it for several minuets & see if it clears it..
Jul 08, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Cleaning ice tea maker
Try to do that
  1. Pour 1 quart (32 oz.) of undiluted white household vinegar into the water reservoir.
  2. Place the pitcher lid on the pitcher. ...
  3. Push the "on" button to begin brewing cycle. ...
  4. Re-plug the cord. ...
  5. When your machine shuts off, unplug the cord, remove the pitcher.
Feb 24, 2009 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Nov 23, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Mr. Coffee ECX30 / ECX33 Coffee Maker Logo
122 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
