Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
I have a Craftsman air compressor 3 gal model 921.153101-how much oil does it hold? Thank you
SOURCE: lack of pressure
My air compressor builds up to 40 psi and just keeps running, i have a craftsman 5 GAL, 1HP, 125 PSI and pressure goes up to 40 psi and dose not go any higher and on the other hand engine keeps running and dose not stop. Please advise?
Thanks.
Kia
Posted on Nov 25, 2008
hdpanama
  • 65 Answers
SOURCE: owners manual ruined. what type of oil do i fill w before use
you should be able to find the manual online if it's available if not Sears would I'm sure be able to tell you.
Posted on Dec 20, 2008
  • 89 Answers
SOURCE: My craftsman 3 gal. air compressor, 921.153101 won't compress air
I WOULD TRY DISCONNECTING THE PIPING FROM THE HEAD DOWN TO THE TANK AND SEE IF ITS BLOWING AIR. COULD THE COMPRESSOR BE RUNNING BACKWARDS - YOU WOULD HAVE HAD TO CHANGE THE WIRING IN THE MOTOR.
VALVES IN THE HEAD COULD ALSO BE BROKEN. YOU CAN REMOVE THE INTAKE AND IT SHOULD **** YOUR FINGERS AT THE OPENING. HOPE THIS HELPS.
Posted on Mar 14, 2009
  • 98 Answers
SOURCE: where do i find the Owners Manual or Service
Its best to use a 30wt non detergant
Posted on Jul 21, 2009
  • 50 Answers
SOURCE: Craftsman 3 gal., 1.5 hp air compressor: won't
The compressor will not auto shut off until it reaches the preset pressure which is usually around 100-130 psi - your problem is leakage of air from the oil filler cap suggesting that you have a failed internal valve.
Posted on Sep 24, 2009
What type of oil does me Craftsmen 1.5 air compressor use
It uses a special oil, not motor oil, it is called Craftsman 2 Stage Compressor Oil, here is a link to the oil.
http://www.sears.com/shc/s/p_10153_12605_00916427000P?i_cntr=1295304743644
Jan 17, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal., 1.5 hp air compressor: won't auto shut off, builds only 40 lbs pressure, air leaks from the 2 holes in oil filler cap?
Sep 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 1/3 hp compressor leaking oil
most defintly you need a head gasket but you will also need piston rings look up your local sears service center not automotive or the store you want appliance service center
Jun 17, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Oil capacity for craftsman air compressor circa 1978 model #106..
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
Apr 25, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Owners manual ruined. what type of oil do i fill w before use
Dec 19, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
216 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
