HP ipaq hx 2000 pocket PC
Further to my problem with my HP ipaq hx2000 pocket PC where it will not recognise any compact flash card. I t works fine using a sd card. Is there any way around the problem?
Regards,
Derek Collings
  • 1 more comment
  • Derek1945 May 11, 2008
    Yes the are type II CF cards. I have a similar pocket PC witch is a HP ipaq h2210 and the CF cards work fine in this.
    Could this be a hardware fault?
    Regards,
    Derek1945
  • Derek1945 May 14, 2008
    Thank you for your help but I have tried every thing you suggested to no avail.
    I have now return the pda back to where I purchased it for a refund.
    Derek1945
  • Rob Wilkins May 11, 2010
    Are they type II compactFlash cards?
  • 20 Answers
It could be, or it could be something to do with configuration. I researched this earlier, and this CF card problem is something that has come up for several years now, on several different devices, but usually with the Windows OS 2003 or later. Here's a basic summary of the recommendations I found :
- Soft reset the device, using the reset button (on the hx2000 series, that's recessed on the left side of the bottom of the device, and you can press it with the stylus). This sometimes solves the problem, but you will often find that it recurs afterwards. It's more of a short term fix than a permanent one.
- Back up the CF card's data, then reformat it and make sure that it is FAT32. This is the most universally recognized file format and has the least problems.
- If this doesn't work, then a last resort option would be to try backing up your device's software and performing a hard reset to return the device to its factory defaults. Make sure you have everything you want backed up before you do this, though, as it will lose all programs and files that you don't have stored. To perform a hard reset on the hx2000 series :
1. Press and hold down the Calendar and iTask buttons.
2. While holding the buttons, press the stylus against the soft reset button and hold it there for about seconds.
3. Once the screen begins to fade, first release the Calendar and iTask buttons, then release the stylus from the reset button. (If you hold all three for more than two seconds, the device will disconnect itself from the battery and power off - apparently if this happens you can simply push the reset button again, or you can plug it into an AC adapter.)
The device should now begin to restart. After this, you need to select to restore the factory settings. Go to Start --> Programs --> File Explorer --> My Device, then open the iPaq File Store. In there, select all files, and then delete them.
If this doesn't work after restoring it to the factory defaults, then I think you may well be stuck with a faulty flash slot. However, let's hope it doesn't come to that - good luck with resolving this problem!
Posted on May 12, 2008
Unlock code hp hx2795b
If you mean the hdd or system is locked, contact the manufacturer with the code and they may be able to help.
Oct 29, 2016 | HP Computers & Internet
Hp back files on card can my computer restore these
The Hx 4700 series and the & The Hx2190 have a removable card Compact Flash or SD Card, if the information you want was stored on these you can buy a USB Card reader from woolies plug the SD or Compact flash into the card reader and plug it into the USB port of your PC or mac and it will be readable (no drivers needed). You may also be interested to know that there are updated ROMS available for this model to update the OS & the Office Apps + increase the max capacity of the storage cards that are recognized.
Mar 29, 2014 | HP iPAQ HX4700 Pocket PC
How do i get a new start up disc for a hp ipaq hx 2400?
Microsoft Windows for Pocket PC 2003 is the software on your hp ipaq hx,
Here is the link for it:
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=9996b314-0364-4623-9ede-0b5fbb133652
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 08, 2010 | HP iPAQ HX2400 Pocket PC
My ipaq hx 2415 will not go past the ipaq screen reset screen
Have you tried a hard reset (deletes everything)
2. While holding down these buttons, use the stylus to lightly press the Reset button on the bottom of the iPAQ Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the Calendar and iTask buttons first, and then remove the stylus from the Reset button.
4. The Pocket PC resets and powers on.
Mar 18, 2009 | HP iPAQ HX2415 Pocket PC
My hp ipaq hx 2790 don't read the memory cards
Are the memory cards of similar size to what you have used before? Some large capacity ones cannot be used. Have you used a memory card before in this device so you know it was working?
Jan 08, 2009 | HP iPAQ HX2790 Pocket PC
How to hard reset hx2490b
Recovery Procedure for HP iPAQ hx2750, hx2490, and hx2790 Pocket PC Series:
To perform a Hard Reset on the iPAQ Pocket PC by pressing and holding the Calendar and iTask buttons (1 and 4).
2. While holding down the Calendar and iTask buttons, use the stylus to lightly press and hold the Reset button, which is located at the bottom of the iPAQ Pocket PC, for approximately two seconds.
3.. Release all buttons.
4.. Connect AC power to the iPAQ Pocket PC. The handheld Powers On,
performs the normal boot sequence, and automatically restarts system.
Oct 30, 2008 | HP iPAQ HX2490 Pocket PC
Media Player won't read storage card library
I gave up and bought ($23) Conduit's Pocket Player which has no problem seeing and reading my MMC card which I sync to from Media Player on my PC through the PC's card reader. Job done!
Liz
May 24, 2008 | HP iPAQ HX2490 Pocket PC
I recently purchased 2nd hand a HP ipaq hx2000 pocket PC. It all appears to function ok apart from it will not recognise any compact flash card when I insert it into the slot. I have tried several CF...
Have you tried using an SD card? The hx2000 is supposed to support SD cards and CompactFlash Type II memory cards. If it doesn't respond, it's possible that your second-hand device simply has a faulty card slot.
May 10, 2008 | Computers & Internet
Biometric fingerprint
In my iPAQ 2790 , I found an icon in SETTING ( HP Protect-Tools) that help to configure the security in your devise.
Mar 22, 2008 | HP iPAQ HX2790 Pocket PC
Ipaq H4150
Have you used a Vista PC as the host machine? ROM updates can only be done from a Win XP or 2000.
Hook the iPaq to an Win XP or 2k PC, install active sync first, and then get the ROM update again. Run the Rom Update Utility and it will recognise the iPaq and will update it correctly. :)
Dec 10, 2007 | HP iPAQ H4150 Pocket PC
Computers & Internet Logo
396 people viewed this question
David Payne
David Payne
