Question about LG 47LH3000 LCD TV
LG 47LH3000 - sound can be heard, but no image is being displayed. Have checked all wires but no luck. TV is relatively new as well, only bought in June.
  • LG Master
  • 8,457 Answers
Turn on tv have flashes of pictures few sec.than dies have sound left only.Yes,than the 2 long boards call the LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long refurbishes LCD inverter boards for the replacement.This tv is under a year old right?Look in ur user manual for the service phone numbers.Call for a warrenty repair.
Posted on Sep 03, 2010
  • Eliseu Oct 14, 2011
    I would like to buy default tv LG 47LH3000
LG TV 42LD520-UA has no sound but the picture is great.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 10, 2016 | LG 42LD520 42 in. HD-Ready LCD TV
What is causing a slow image transition on my vizio LED tv?
I have never heard of this problem on this site.
Oct 03, 2016 | Vizio Televison & Video
Have a LG Tv that has sound but no backlight, can see image with flashlight. When you first power on TV show white screen with LG logo then goes black. Tv is a 55LN5790-ULBUSULJR
Well, you've done the easy part. The unit has sound and picture, but no backlight. The next part is tedious and delicate: dismantle the unit and find the cause. Many times, the problem is cabling or wiring, but once in a while the problem is control related. if the unit is under warranty, have it serviced by an authorized service dealer. If not, it's up to you. The new, flat tv's are super easy to wreck once the case comes off, so unless you really know what you're doing, it is very easy to justify paying a competent professional to repair the unit.
Jul 29, 2016 | LG Televison & Video
How to repair LG 50PZ550-UA has no image and no audio?
Unfortunately it sounds like your power board has died.
Contact LG, or if you're comfortable with it, open up your TV and look for swollen capacitors. You could replace those, or simply replace the board that they're on.
Sep 21, 2015 | LG Televison & Video
How Much Does Screen Repair LG 47LH3000
If you mean the cost for replacement of display panel, it might cost around 2/3rd of the total cost of a new TV.
Jun 18, 2013 | Televison & Video
Bought it a week ago today. now it mysteriiously
It sounds like it may have an bad solder connection in the power supply. Or It may have bad componets in the power supply. I would even try to take the battery's out of the remote just in case it is cause it to turn on/off.
Feb 25, 2010 | LG 47LH3000 LCD TV
I have A LG 50PX4D TV the display has gone off
Most likely the tv has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If its under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Image stretched
No offense, but if you're an IT ignoramus, you should know how to fix this. I see you said 2 monitors, did you see that you could've added display to the second monitor making it look out of proportion? A simple fix is either adjust resolution, disconnect second monitor, or you could do the hardest one, test every single component related to display until you find the problem. Good luck with the last one,if you come down to it.
May 07, 2009 | Dell Computers & Internet
LG 37" lcd tv weird noise using hdmi ports bought new main board still does the same thing! Need solution! Lg says "i don't know never heard of this problem", BS!!!!! Ok remote for the tv worked before...
Use an other HDMI cable. Still the problem persists, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Mar 09, 2017 | Televison & Video
42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Dec 31, 2007 | LG RU-42PX10 42 in. HD-Ready Plasma...
LG 47LH3000 LCD TV Logo
152 people viewed this question
Computer Repairing
Computer Repairing
