Question about GE Profile WPSR3120WWW
WPSR3120 agitator wont spin
My agitator wont spin i wanan try and remove it.how would i go about removing the agitator?
  • 1 more comment
  • Anonymous Jul 31, 2008
    GE WPSR3120WWW
    agitator wont spin... how do i remove the agitator
  • snarkel Jul 31, 2008
    my agitator will not spin on my ge wpsr3120. how do i get my agitator off? i don't see a solution.
  • lrochele Feb 23, 2009
    my agitator won't turn during the wash cycle. It will spin during the rinse.
I tried that already
Posted on May 12, 2008
Just pull up very hard with a hard ****
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
Washer agitator wont turn!
what do you mean wont turn, do you mean when it spins that agitator is stationary ? in that case you need a new transmission. if you mean that in a dual action agitator that you can spin the agitator top left and right with no resistance / the bottom doesnt move either, then you will need new agitator dogs. remove the top of the agitator and i mean the cap, some have fabric softner dispensers on the top, which means pull the green tab up and the dispenser will come off, then you remove the cap to the agitator. under that is the agitator cam. you either need a 11mm socket to take it off, or you will need a 1/2 in ratchet and extension to take it off. after that it should be very easy to replace the agitator dogs
Feb 07, 2011 | Washing Machines
+whirlpool LSQ8243HQ0 water valve works. wont wash or spin. new motor coupling and timer.
Under the agitator you have what is called (agitating dogs). The agitator will have to be removed. The top should spin off, you will be able to look down into the agitator and see a bolt. Remove this bolt and the agitator can be pulled out. The agitators are small pieces of plastic with small teeth. These teeth get worn out over time or if the washer is overloaded. When the agitator free spins one way the teeth grab a (gear) on agitator and this is how you get the washing action (agitating). These dogs are easy to replace and cost about $5. If you need more info check out *how to replace agitating dogs)
Dec 15, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine GLWS1649ASO wont spin on spin cycle. motor and pulley turn, but belt doesn't move. Is it the belt?
no it will not be the belt more so it will be a bad transmission.or something stuck under the agitator i have seen drill bits and keys get stuck under the agitator and cause the transmission to stop
remover the agitator first and check it is there is nothing there the transmission needs to be replaced
Oct 02, 2009 | Frigidaire GLWS1649A Top Load Washer
Wont agitate or rinse
I would request you to Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
This would help you.
God Bless.
Jul 08, 2009 | GE Washing Machines
Agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Jun 29, 2009 | Washing Machines
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Apr 15, 2009 | Amana ALW480DA Top Load Washer
Kenmore Elite 23012 - 23014 mfg in 01 wont spin
Once the top cap of the agitator is removed, take a pair of pliers and pull up forcefully on the plastic cap inside. Then take a 7/16 socket wrench and remove the agitator bolt. Pull the agitator apart. Get part number 3366877 from any appliance parts store.
Apr 07, 2009 | Kenmore 23012 Top Load Washer
Wont spin or pump out
these wahers are problematic and expensive to repair. remove whirpool emblem on front and remove 1/4 screw pull top foward and up look inside of front panel and you'll see tech manual
Dec 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer will not agitate but will spin
You are correct that motor turns one direction for agitate and the other for spin. The problem you describe sounds serious but there is a chance it is not. First, try to turn the transmission by hand. If it wont turn by hand, remove the agitator and see if something has gotten under it and has it locked to the basket. To remove the agitator, pop off the top cap and look down inside. You will see the bolt that holds the agitator on. After you take it loose the agitator will slide off.
If there is nothing there, the transmission will need to be replaced. If the washer is less than 5 years old, the transmission may still be covered by warranty. Check your owners manual for warranty details. Post back to let me know what you find out.
Oct 21, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Washing Machines Logo
388 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
