Question about Dryers
I need a free user guide for my Creda T622CW condenser dryer. can you supply it or can i get it online?
  • 776 Answers
Please find the link to download the manual online:
http://www.manualsmania.com/model.php?model=48983f95998639116f99e91ddc9999f1f69bb0
Posted on Sep 03, 2010
Creda T601CW 6Kg Advance Condenser Dryer The belt
Creda I don't know from. Sorry
Nov 20, 2011 | Dryers
My creda simplicity t622cw condenser dryer wont turn
Broken or belt has come off. If can open back and fix or replace. You may need to remove the top. Careful of the heat element, lift out drum and place new belt on motor holding it while you put the drum back keep hold of belt and place around drum replace top and should be ok. Hope this Helps
May 25, 2010 | Dryers
Creda simplicity condensor dryer model no T622CW.Problem, dryer continues to turn when door is opened.Which part(inc part No) do I require?
You need to replace the door interlock or switch as it is better known.
You could spray inside the switch opening with WD40, before replacing switch, as it could be just sticking.
Please rate my solution.
Thankyou.
Jan 27, 2010 | Dryers
Creda T622CW condenser tumble dryer drum wont turn
You need to check if the belt is o/k.
Remove top cover, and grasp belt, it should be firmly wrapped around drum.
If o/k, then could be a motor problem, or programmer fault
Once you have got the drum turning again, it is possible the filter light will go off,if not, then you have another fault
Hope this helps.
Dec 16, 2009 | Dryers
My creda t622cw dryer had no heat so I have replaced the thermostats, but when I tried it there is heat but the heating element gets very hot and turns red, is this normal or do I need to replace this as...
The fact that the element gets red hot, shows that there is nothing wrong with the element, it will get red, more so if you tried it without a cover or panel over it, as normally the fan blows the air over the element, make sure the drive belt is o/k, and the drum is turning.
Thanks.
Nov 13, 2009 | Frigidaire Electric Dryer
A Creda condenser dryer TCR2, it went off won't work at all now
There is a lint filter inside the front of the m/c.
A filter at the bottom left of m/c,undo catches to release it, remove it and wash out under running water to thoroghly cleanit.
.Remove water container at top left front , and empty.
Make sure air intake and air out lets are clear, one at front right, and one at rear of m/c.
You can download user instructions.
Goto;;
www.hotpoint.co.uk
Click on (after sales), click on download user instructions, and follow the guide
Plz rate my solution.
Thanks.
Dec 29, 2008 | Creda IWD12 Front Load Washer / Dryer
Tumble dryer wont dry
hi do you have any blockages in the vent system (lint) can you hear the fan running and are the filters clean.did you put it back together correctly.hope this helps.
Mar 05, 2008 | Dryers
Thermostat wiring diagram for creda t622cw
I assum there are four wires, you really cant get them wrong as they are all Neutral wires so it won't go of bang, it just may not heat as it should, I would connect them as you think it should and try them.
Dec 02, 2007 | Dryers
Drum wont turn on my creda t622cw tumble dryer
my tumble dryer drum wont go round
Nov 15, 2007 | Dryers
Dryers Logo
178 people viewed this question
Top Dryers Experts
