Question about Dell Inspiron B120 B130 1300 / Latitude 120L Motherboard - RJ273 - GG0
What type of network controller this computer use? I can not install the network controller in my computer
    President:
  • 2,571 Answers
It uses the integrated 440x 10/100 chip, you have mentioned 4 different laptops here, all use the same chipset, so the drivers should be the same.
Try here http://support.euro.dell.com/support/downloads/driverslist.aspx?c=uk&cs=ukdhs1&l=en&s=dhs&os=WW1&osl=en&SystemID=LATITUDE%20120L&catid=-1&impid=-1
Posted on Sep 03, 2010
No network coverage
Set IP Address Configuration
Click the "Start" button and select the "Control Panel" from the right column to open it.
Select the "Network and Internet" section of the Control Panel.
Click "Network Connections" if using Windows XP to view the available network icons.
Or, click "Network and Sharing Center" if using Windows 7 or Vista and select "Change adapter settings."
Right-click your network connection icon which displays either the yellow triangle or red "x" indicating limited or no connectivity.
Select "Properties."
Click on "TCP/IP" to select and highlight it. Click "Properties."
Select both the "Obtain IP address automatically" and "Obtain DNS server address automatically" radio buttons.
Click "OK" and then "Close" in the Network Connection Properties box. Close the Control Panel.
Manually Renew IP Address
Click the "Start" button and choose "Run" from the list.
Type "cmd" in the "Run" box and press "Enter" to open the Windows Command Prompt.
Type "ipconfig /release" in the Windows Command Prompt and press "Enter."
This releases the current IP address of your computer.
Type "ipconfig /renew" and press "Enter" to obtain a fresh IP address.
When renewing your IP address, Windows automatically attempts to connect to the network.
Powercycle Router and Modem
Turn off your computer.
Unplug both the Internet modem and wireless router's power adapter from the electrical outlet. Wait for two minutes.
Plug the Internet modem into the electrical outlet first. Wait for connectivity lights to appear.
Plug the wireless router's power adapter back into the electrical outlet.
Confirm that lights appear on the router indicating that it has established a connection to the modem.
Turn on your computer.
Open "Network Connections" if your computer does not connect automatically to the network.
Select a network from the list, input the network password if one exists and click "Connect."
Open your Internet browser to test the connection.
Update Network Interface Card (NIC) Drivers
Click the "Start" button. Right-click "My Computer" or "Computer" from the Start Menu. Select "Manage." Click "Yes" if a user account control message appears.
Click on "Device Manager" from the list of System Tools.
Find the "Network adapters" listing and click the "arrow" or "plus" symbol to expand it.
Right-click your computer's network adapter from the list and select "Properties."
Click the "Driver" tab and select "Update Driver."
Follow the on-screen prompts to allow Windows to find and install the drivers automatically. Restart the computer when the process is finished and attempt to re-connect to the network.
Reset Internet Protocol (TCP/IP)
Click the "Start" button and select "Run."
Type "cmd" and press "Enter" to open the Command Prompt.
Type the following line into the Command Prompt and press "Enter":
netsh int ip reset resetlog.txt
Close the Command Prompt. Issuing this command tells Windows to remove and then re-install the two registry keys used by the Internet Protocol (TCP/IP) component of Windows.
Restart the computer.
Attempt to connect to the network if a connection is not established automatically.
Sep 06, 2013 | Computers & Internet
I deleted my internet program and now cannot connect
What type of computer ?
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
or you could download one
http://download.cnet.com/2000-20_4.html
on the homepage you will see a search bar type in the ethernet controller freeware you want/need
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html
http://download.cnet.com/network-drivers/3150-2112_4-0-1-4.html
Aug 06, 2013 | Computers & Internet
NETWORK ADAPTER
"Enabled"ima
Jul 08, 2013 | Dell OptiPlex 380 MT Desktop Computer...
I am unable to access the internet connection on my system as some Adapter is not recognised by the system. Please tell me what is it
first you have to check whether the LAN drivers are installed properly to find whether LAN card is installed properly right click my computer then properties then hard ware then device manager then in network adapters do you see a circle with yellow color uninstall and reinstall the LAN driver then restart your system then click start run and type cmd and click enter then type ipconfig /release after ipconfig is release type ip config /renew then type ping 192.168.0 1 you will see the files pinging it means the computer is connected the modem if not pinging go to network connection in your control panel then right click you default device then click networking then select internet protocol and click properties make sure obtain an ip address and dns is marked if not mark them then save and exit
Apr 28, 2011 | Gigabyte Computers & Internet
How to install an wirless adapter to mi desktop
Install a wireless network adapterIn areas that are served by a wireless network, you can connect to a computer network without using a cable, and surf the Internet or connect with other computers. To connect to a wireless network, your computer needs a wireless network adapter.
Many new computers-especially laptops-come with wireless adapters. Before using your computer, check to see if it already has a wireless network adapter.
If your computer doesn't have a wireless network adapter, you can install one.
Install a wireless USB network adapter. Most people prefer this type of adapter for any type of computer, because it's easy to install.
Install a wireless CardBus or CF network adapter. For portable computers, this type of adapter (also called a PCMCIA or PC Card) is easier to travel with than a USB adapter, because it is often smaller and fits securely in the PC Card slot on the side of the computer.
Install a wireless internal network adapter. If you have a desktop computer, you may prefer an internal adapter so that you can use the USB port to connect another accessory.
The type of adapter you install depends on your computer and your level of expertise.
How to determine if you already have a wireless network adapterMany portable computers manufactured after 2000 have wireless networking built in. However, because the antenna is hidden inside the computer, it's not easy to see.
To see which network adapters are currently installed in your computer
1.
Click Start, and then click Control Panel.
69010-click-control-panel.gif 2.
Click Network and Internet Connections.
69010-click-network-and-internet-connections.gif 3.
Under or pick a Control Panel icon, click Network Connections.
69010-click-network-connections.gif 4.
Microsoft Windows XP displays your network adapters. Wireless network adapters are labeled Wireless Network Connection. If an adapter displays a red X, it is disconnected. If the Network Connections window is blank, your computer doesn't yet have a wired or wireless network adapter.
Nov 12, 2010 | Computers & Internet
Hoe to fix the code 28 & install back the noetworks controller
Hi gregdouglyn.
Let me provide you the detailed troubleshooting steps to resolve this issue.
1) Please press the "Windows+R" keys simultaneously.
2) This should open the Run command window.
3) In the Run command window, please type "devmgmt.msc" and press Enter.
4) Please click on the "Network Adapters" and right-click on the "Network Controller"(Ethernet Driver).
5) Then, select the Un-install option.
6) Click on the "Scan for Hardware changes" option at the top of the Device Manager window.
7) This should re-install the Network Controller Driver.
Performing the above steps should resolve the issue.
If the issue still persists, please perform the below steps:
1) Right-click on the Network Controller Driver.
2) Then, select the "Update Driver Software" option.
3) Then, select the "Browser my Computer for Driver Software" option.
4) Then, in the Search Driver location type "C:\Windows\inf" and also check the "Include Sub-folders" option.
5) Once you have done the above steps, please click on "Next".
6) By doing this, the Operating System will search for the best Driver for Network Controller.
Please perform the above steps.
This should resolve the issue.
Hope this helps.
Please feel free to ask further questions.
Aug 23, 2010 | Computers & Internet
Cant install network controller
IF you don't need the network controller to use your laptop then don't worry about it. The problem may be that you type of computer doesn't support that specific update.
Jul 13, 2010 | Dell Inspiron 1420 Notebook
How do I set it up for wireless
Install a printer on a home network The most common way to install a printer on a home network is to install it as a stand-alone device on the network, and then add a connection to the printer on each computer that is on the network.
If you're not sure what type of network printer to install, decide if you want to:
  • Use a wireless printer. These printers use a built-in wireless card and plug into a power source, not your network or computer. After you turn on the printer, you need to refer to the information that came with the printer to set up a wireless connection to each computer on a home network. Security options for wireless printing are determined by each printer manufacturer.
  • Connect a printer directly to the network. To do this, you need to plug in the printer to your network hub or router. How to install these printers depends on whether the printer and your network device use an Ethernet, universal serial bus (USB), or another type of connection. You also need to refer to any installation information or tools provided by the printer manufacturer.
  • Connect more than one printer directly to the network. To do this, your hub or router must be able to support more than one printer connection.
Hide all expcol_imgs.png To install a network printer
  • To find out how to install a network printer, check the information that came with the printer.
expcol_imgs.png To connect to a network printer After you have installed a network printer, you need to add a connection to the printer for each computer on the network.
  1. Open Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
  2. On the toolbar, click Add a printer.
  3. In the Add Printer Wizard, select Add a network, wireless or Bluetooth printer, and then follow the steps in the wizard.
Feb 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Can;t use intent on mobile
Here is what you should do step by step:
I.Configure your Computer
1.Install Bluetooth Adapter
2. Bluetooth Configuration->Local Services-> Add Serial Services ->Bluetooth Serial Port->Properties
Check – Startup Automatically
Check – Secure Connection
COM Port: COMx( mine is COM6)
3.Control Panel -> Phone and Modem Options->Modems->Add-> Check Don’t detect my modem->Next->(Standard Modem Types)->Communication cable between two computers->Next-> on witch port do you want to install it ? -> Selected ports -> COMx ( in my case COM6)->Next->Finished
Now in phone and modem options->Modems you should have : Communications cable between two computers : Attached to : COMx ( COM6 my case)
Select Communications cable between two computers -> Properties->Modem-> Maximum Port Speed : 115200 -> ok ->ok.
4.Control Panel ->Network Connections ->Create a new connection-> Next->Set up an advanced Connection-> Next-> Accept incoming connections->Next-> Check : Communications cable between two computers ->Next-> Check: Do not allow virtual private connections->next->next->select: Internet Protocol(TCP/IP)->Properties:
Network access : Check Allow callers to access my local area network
TCP/IP address assignment : Specify TCP/IP addresses:
To: 192.168.0.y (y=52 in my case)
->OK->Next->Finish
5.Network Connections
Bluetooth Network -> Enable
Internet Connection ( your internet connection ) -> properties->Advanced->Check:Allow other network users to connect trought this computer’s Internet Connection->OK
If all goes well : Bluetooth Network-> Properties-> Internet Protocol ( TCP/IP)->Properties Should have the following setting:
Checked Use the followind IP address:
IP address: 192.168.0.1
Subnet mask: 255.255.255.0
->OK.
6.Start->Control Panel->Administrative Tools->Services->Routing and remote access->Properties->General: Startup type : Automatic - this service MUST be started
**7.Install AnalogX Proxy http://www.analogx.com:80/files/proxyi.exe (for the latest version)
Proxy->Configure-> Proxy Binding: 192.168.0.x ( for me x=50 )->ok.
! If you use a proxy, remember to start it .
II. Configure Phone:
1.Install GnuBox - http://gnubox.dnsalias.org/gnubox/ ( for the latest version)
2.Configure Access point
Tool->Settings->Connection->Accces Points-> New Access point->Use Default Settings
Connection name: Bt
Data Bearer: Packet data
Access point name : Bt
User name: none
Promt Password: NO
Password: ****
Authentication: Secure
Homepage: none
Option->Advanced settings
Network Type: IPv4
Phone IP address: Automatic
Name Servers: Automatic
**Proxy serv. Address: 192.168.0.x ( for me x=50)
**Proxy port number: 6588
3.Configure all the applications from your phone witch require internet acces to use Bt Access Point
4.Configure GnuBox
Options->Install Set to GPRS
Options->Install Create Records
Options->Install->Copy settings from GPRS
Options->Install->set RAS login script
Exit GnuBox
Open Gnubox
Options->2box Bluetooth->Serial Port
Select – your computer
Do you want to require encryption? Yes
Options-> Install->change default AP
** Configure NetFront
Options->Settings->Connection
Enable Proxy : Yes
Proxy Host : 192.168.0.x ( in my case x=50)
Now you can browse the internet from your phone.
NOTE: First Configure the phone and your pc without the ** settings, and if you can’t browse the Internet form your phone then use the ** settings.
Hope this works fine.Thank you.
Nov 25, 2008 | Computers & Internet
Use two computers with one printer
Printer Sharing (This is good for Windows 2000, XP and Vista)
Sharing will be very easy if your network is working.
You need to consider the computer where the printer connected as the "Host" and the other computer that wants to print to that printer as the "Client".
Before you do such sharing, you need to acquire each computer's IP address.
You can do it by accessing MSDOS Prompt and typing in ipconfig/all. Write down your IP addresses and the share name on a paper.
For your Host:
Install the driver, make sure that you can print on direct bi-directional connection (such as USB).
Go to Control Panel >Printers and Faxes* >Sharing >Share this printer >Type in your share name, good example is PRINTER (this is case sensitive).
For your Client:
Install the driver, make sure that you can print, same with the Host.
Go to Control Panel >Printers and Faxes* >Properties >Ports >Add Port >Add local port type in \\ (the IP Addressof the Host) \ (share name), click OK.
ex. \\192.168.1.3\PRINTER (watch your backslash, no spaces)
*Term used is "Printers" for Windows Vista and Windows 2000
Oct 23, 2008 | NetGear FS105 5x10/100 Mbps Networking...
Dell Inspiron B120 B130 1300 / Latitude 120L Motherboard - RJ273 - GG0  Logo
78 people viewed this question
Alun Cox
