Question about Toshiba 160GB EXT-USB 2.0 PRTBL SHOCK MOUNT 160 GB Hard Drive
Hey.. I have a toshiba 160GB portable hard drive and its got very important data for my work.. a while back it used to just stop working when i view some old files and then all of a sudden it just stopped working! it makes a clicking sound and the light goes of whenever i connect it.. and it doesnt show in my computer or device manager.. what can i do?
  • Toshiba Master
  • 27,725 Answers
Give the hard drive a firm tap on side it sounds like a dirty hard drive the clicking sound is the reader arm scating across the platters once you get access to your hard drive then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive
good luck with this
Posted on Sep 03, 2010
How to retrieve data from toshiba 3.0 portable usb storage malfunction
That all depends on how badly the drive is broken.
If the problem is mechanical, suspect a bad connection first. Almost everything else has that as an underlying cause.
If you suspect it has been struck or dropped, there are some tricks to get it spinning long enough to recover the files. Sometimes gentle tapping or drop from an inch or so - no higher! - can loosen things up to get it spinning. Where so-called "stiction" is involved, sometimes alternately freezing and warming the drive can "un-stick" the mechanism through expansion and contraction of the moving parts.
How badly you want the files will determine whether you are willing to pay for a data recovery service.
Only if you are certain that the hardware is working correctly should you attempt to use software utilities in an attempt to repair and recover the file system, most importantly because such utilities need to write to the disk and therefore are likely to write over your files.
The simplest way would be to restore your files from your backup drive.
May 22, 2014 | Toshiba Canvio 1.0 TB USB 3.0 Portable...
How to recover data from my toshiba 320 hard disk?
Data lost due to unintentional formatting of the drive or when someone knowingly delete some data later on realizing that the data was important, In situations like this one should use a data recovery tool. To know more about data recovery process visit http://www.recoverlostfile.net
Dec 23, 2012 | Toshiba HDDR320E04XW 320 GB USB Hard Drive
I have a toshiba 500GB portable external hardrive....it still has 50GB more space left...however when i tried to open it...it wont open and i cant see my files...the computer says that it cannot fix the...
You can recover data from portable hard drive with data recovery software.Tenorshare data recovery is one of the bests. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,bad section, virus attack etc.Download it and scan your external hard drive for free to preview whether your files can be recovered.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm After you recover your data,you can format it to check out whether it can be fixed.
Jul 10, 2011 | Toshiba 640GB USB 20 Rocket Red Portable...
I have a Toshiba Canvio Pocket-Sized 320GB Hard Drives no longer works and I want to know how to open the box and change
(ASP) Asian Power Device Model WA-18G12U functions properly on both of my book HP 160GB and my 1T
FIXYA - Keep the money...
Feb 20, 2011 | Toshiba Canvio Plus 320 GB 2.0 Portable...
My portable HD when i insert to my computer the motor run and stop imediatly
-The only problem is supply, try to replace your power cable , if your hard drive using only usb cable to get power that is the only you need to replace
- replace your enclosure or housing of your hard drive, possible that your housing already damaged
Feb 05, 2010 | Toshiba 160GB USB 2.0 Portable External...
I have an external hard drive, Toshiba 160gb, model# HDDR160E03X, S/N 48UPF7OZSXS5..It was working fine but suddenly stop working. I change cable but still the same. When I connect it to the computer it...
Buy yourself a USB to IDE & SATA disk adapter from eBay fro a few $$$. Then open the Tosh case and unplug the drive and power supply connectors and remove it from the case - carefully. Plug it into the USB to IDE /SATA adapter and lay it flat on a non conductive surface and connect the USB to your PC should see it as a new drive. This will allow you to get the data off the drive, check for errors and reformat it. If you can’t see the drive from the PC then it is likely that the drive is fatally faulty.
Oct 13, 2009 | Toshiba 120GB USB 2.0 Portable External...
What to do with a portable toshiba hard drive that clicks
A hard drive that is making clicking noises is faulty.
Replace the hard drive in the portable Toshiba case.
Oct 09, 2009 | Toshiba 160GB USB 2.0 Portable External...
My back up 160GB Rugged drive quit working,felt hotter than normal and gives off a 'burnt' cct. smell. MacBook Pro using XP pro SP3 with Firewire link. Backup size about 70GB with five years of photos....
One of the circuits in the back up drive failed. Your options are to send to to the manufacturer for possible repair or you can try removing the drive unit, that is actually what is inside that, and putting it in a portable case, available from Best Buy for about 39.99, and continue to use the device. or take it as a lose of data and get a new back up drive.
Sep 08, 2009 | Computers & Internet
Maxtor basics 160gb portable hard drive is showing error performi
go to my computer p[roperty then hardware -> device amnager then uninstall usb drivers from it then install aagain.
then connect your harddisk then it found.
Jun 23, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
Toshiba 160GB EXT-USB 2.0 PRTBL SHOCK MOUNT 160 GB Hard Drive Logo
162 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
