Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Put new bulb in hitachi ultravision dlp tv and lamp light flashes and tv will not turn on. Have reinstalled old build and works fine. Is there any type of reset that needs to be set. New bulb no tv, old bulb tv works. Have power cycled And basic troubleshooting.
    Sergeant:
  • 171 Answers
Hey there it sounds like the problem is coming from your ballast board, the ballast board is the power source to the lamp. with time this part starts to wear out and get weak your old lamp is already burning out there for it does not need that much voltage to turn on but the new lamp has not been worn out or used there for it needs the ballast to be working at 100%
hope this solution helps
Posted on Sep 03, 2010
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
Samsung HL -5656 fan light blinking BUT no other lights blinking
Its probably not the lamp but I would try it first. Buy it from a place that will take it back as I suspect you have a bad power supply. http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?
check this link against your symptoms and then check out Pureland Supply for a new lamp. Samsung DLP TV Lamp
Jan 10, 2018 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
I have a spot in the middle of the screen that red shows up as almost black. It looks like the old problems when magnets were put on the old fashioned TV's It is a 50 inch Hitachi Ultravision. I replaced...
That is going to be a failure of the light engine itself. The part number for that is UX25302R. The part is not a user replaceable part due to the complexity to remove and reinstall the new one. Here is a link for the part and to purchase it as it runs 521 dollars. Please take a few moments to rate my answer. Thanks...
http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/UX25302R/New.aspx
Nov 16, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Replaced a lamp and unable to turn on television, lamp light flashes
this works. remove lamp and place in your freezer for 5 minutes. reinstall. when unit comes on, go to menu and find lamp setting. reset lamp to zero hours. the unit still thinks it has old lamp
Nov 11, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
I have a 50vs810 dlp. The blue and red lights flash in sequence when I turn it on.When they stop flashing the red light for the lamp is on. The yv has no volume and no picture. Is it just the bulb or does...
More than likely, it is the bulb. My hitachi 50v715 would come on(light up and show picture) 3 to 30 sec's with out the lamp indictor even lighting up. Put a new bulb in and works great. So I would try a new bulb. Look in your manual for the bulb number. Buy an original hitachi bulb they last a little longer.
Nov 05, 2009 | Hitachi 50VS810 50" Rear Projection HDTV
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Lamp went out on DLP TV
Did you replace the lamp door? A flashing red light is an indication of a door open or an impropely seated lamp. Try removing the lamp and reseating it. Reinstall the door and try turning it on again. Also, you may want to unplug the TV from the power source, count to about 20 and then plug it back up again. This may reset the TV.
Good luck
Aug 09, 2009 | Hitachi Televison & Video
Product- 50VS810 Hitachi TV Replaced burnt out
check your lamp and lamp door saftey switches. If they are ok then could have also got the ballast.
Aug 09, 2009 | Televison & Video
Problem with tv
Pretty typical for lamp life. Buy a new bulb (not the whole lamp assy) from us (sedonix.com) or one of the many bulb sources on the net, install it yourself and save a lot.
Dec 31, 2007 | Televison & Video
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
684 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
