Compaq presario beeps but the monitor does not come on
The monitor does not come on and when the cpu is turned on it beeps,I know it means something but ot enough to translate in to a dignosis.I just got the cpu back from repairing and reformatting the hard drive, and everything worked fine.
  • 3 more comments
  • kaushi kaushi
    kaushi kaushi May 11, 2008
    Memory had come lose brfore, and the problem was fixed.I will check again if the memory is in its place.I have connected a new 22 inch monitor which is working fine with other cpu, so there is no problem with the monitor.Could it be power suppy? When I turn the cpuon it beeps like this "beep- beep-beep" "beep-beep". what could that mean?
  • kaushi kaushi
    kaushi kaushi May 12, 2008
    I am so sorry about the ratings...and thank you for letting me know..very new at this.
    How can I go to the bios if my monitor does not display anything?
  • kaushi kaushi
    -'Use PCI VGA/Display card' - isn't this card that's messed up?
    and if I don't have monitor display how can i go to BIOS?
    OR
    am I supposed to get the on-board card out from one slot and try it in the other?
    Please do not get angry as I am learning it as it comes.
    Thank you already for your patience.
  • kaushi kaushi
    kaushi kaushi May 13, 2008
    Now, I did take out the vga card cleaned the connection point but did not help, same beeping condition.How do I know that I have on-board disply or not? If I need to try out different card what kind of vga card should I use? I dont have any other empty slot to try my old card out.
  • kaushi kaushi
    I did take out vga card, cleaned the connection point and put it back no change in the beeps.Now , how do I know if I have on-board display card ? I also tried to put the old vga card in to another pci slot but I do not have an extra.If I need to get a new vga card what kind do I buy from the compatibility point of view?
  • 652 Answers
If there is long beep it means you have problem in your memory.
  • To fix this type of problem, Remove RAM clean its connection point and place it again. If still problem then you should try new RAM.
Thanks
Iqbal
Posted on May 11, 2008
  • 1 more comment
  • Iqbal Husain
    Iqbal Husain May 12, 2008
    If you have beeps like "beep- beep-beep" "beep-beep".
    Means you have promlem with your display adopter.
    • Go to BIOS setup make On Board Display Disabled.
    • Use a PCI VGA card in any one of your PCI slot.
    • Then connect monitor to this card.
    • And boot, It will work.
    And friend don't make ratings till your problem resolves. Because negative ratings made our average down. If you have problems just put a comment as you have posted and I will try best to resolve.
    Thanks
    Iqbal
  • Iqbal Husain
    ok
    • Use PCI VGA/Display card, then try to go BIOS to disable onboard VGA. Actually if you left it Enabled it might cause conflict to your windows when yo will install driver for VGA/Display.
    And please if it helps you then rate as HelpFull and if it resolve your problem then rate Fixya..Otherwise post comments I will try to answer you.
    Good Luck
    Iqbal
  • Iqbal Husain
    kanitikar1,
    The on-board VGA/Display means there is chipset mounted on your motherboard for display.
    The PCI card means a PCI card which you can insert in PCI slot of your motherboard.
    Now if you don't have on-board VGA/Display and you are already using PCI VGA/Display card, then remove it and clean the connection point and put it again in the slot. Then try out if no luck then try to use other PCI slot if you have other on the motherboard, if still no luck then try another PCI VGA/Display card.
    If you have on-board VGA/Display card then get a PCI card and try to do the things I told.
    Good Luck
    Iqbal
  • 21 Answers
Is the screen completely dead?
If not then go tp the BIOS setup screen by pressing F1 or F10. Wait 5 seconds. Press the F5 key to restore the default settings of the BIOS. Press Enter to accept the change and wait five seconds. Press the F10 and then the Enter key to save the changes and exit from the BIOS.
OR
If possible, connect the monitor to another computer that is known to work correctly. Connecting the monitor to a different computer helps determine if the problem is with the monitor or with the video display hardware (the video card).
Mine does the same thing...beeps and thats all. If I shut it off and wait for a couple of days it will work fine again.
Posted on Mar 24, 2011
Compaq turns on cap locklight on f12 light on and power light on black screen
Have you tested this laptop using an external monitor? If your laptop works good with an external monitor, it means your laptop screen is dead and needs to be replaced. If the external monitor displays black screen , it means there is something wrong with the GPU and or motherboard.
Mar 10, 2014 | HEWLETT-PACKARD Compaq Presario CQ56-129NR...
No start up and continuous repeated long beeps?
Hello
Here are the bios beep codes:
1 long, 2 short
Video adapter error
Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly.
Repeating (endless loop)
Memory error
Check for improperly seated or missing memory.
1long, 3short
No video card or bad video RAM
Reseat or replace the video card.
High frequency beeeps while running
Overheated CPU
Check the CPU fan for proper operation. Check the case for proper air flow.
Repeating High/Low
CPU
Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed.
Check computer beeps and act according to suggestion
Hope it helps if so do rate the solution
Dec 20, 2010 | Compaq Presario Notebook
Compaq presario cq60 no display
have you tried plugging in the laptop to a pc monitor ?? this will tell you if its your screen or there are other problems with the laptop please let us know if this helps ok
Jan 31, 2010 | Compaq Presario CQ60-220US PC Laptop
Problem with compaq presario r4000 constant beeping no keyboard
Need to know the number of beeps. They're called beep codes. This page lists some of the Compaq beep codes and what they mean.
http://www.bioscentral.com/beepcodes/compaqbeep.htm
Nov 06, 2009 | HP Compaq Presario R4000 Notebook
Compaq Presario F700 keeps turning on and off
At this point I assume you've tried to go into SAFE mode, and into BIOS with no luck. You're right about the overheating but I think the damage is done. If the unit will no longer stay on in any mode or condition then heat has ruined something. First easiest part to check is memory. The check the CPU (most laptops still have a plug in CPU). If neither of these are suspect then take everything off the motherboard, including the screen (I use and external monitor). If the problem still exists then it's time to use a scope.
May 30, 2009 | HP Compaq Presario F730US Notebook
My pc monitor keeps going off and when the computer boots up it beeps and the monitor wont turn on properly . however the monitor works fine when attached to another laptop computer. does this mean the...
Yep, problem is with the video card. If it's a desktop you can pull the video card out and install reseat it back into the motherboard to see if that fixes the problem.
Let me know.
Feb 23, 2009 | HP Compaq Presario V2000 Notebook
'03 compaq presario x1000
On a desktop pc u hear continuos beeping it's something to do with da ram so try replacing the ram or reseat the ram for help go to compaq.com
Nov 11, 2008 | Compaq Presario X1000 Notebook
Compaq Presario
twice beep means either video card is disconnected or it's non-functional.
if it's a laptop under warranty, take it to an authorized dealer
if it's not under warranty and you are not comfortable in breaking down your laptop, then see if a local computer place can check it out
if not under warranty, and you are fairly computer savy, reseat the video board, memory, and cpu (if possible). somewhere there is a loose connection. if not working, the main board might be bad.
Jun 06, 2008 | HP Compaq Presario V2000 Notebook
Wont post
after turning on wait for a moment.. about 5 mins. then press fn+f4
Jan 04, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
2,831 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
