I have an hp scan jet 4470c and unable to find instructions for using. Is there any way to get a manual for this model?
  • Computers & ... Master
  • 5,344 Answers
You can get a tutorial from HP: http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&product=57956 . Click on the How To link.
Using the scanner depends slightly on the OS that you are using. XP has an option that allowed you to scan from the computer using Paint. Most of the time you will use the HP software. If the monitoring program is working you can use the buttons on the scanner itself. Check that the HP PrecisionPro program is the destination in the LCD Screen (or at least no other program is listed). Use the Select Destination button to change this. Place your document face down on the glass or face up in an ADF. Press the Scan To button (with the ScanJet Copy utility closed) and the program (HP PrecisionScan Pro) will open and will select the optimal settings (you can modify them) Next you will see a preview image, to adjust the area to scan click in one corner of the desired image and drag the mouse to the opposite corner. This will form a dotted square around the desired image. When you are done adjusting the image, press the Print button.
I hope this helps.
Posted on Sep 03, 2010
  • 1,183 Answers
The link for on how to use the scanner is given below
How to instructions
In case you need furthur help ,feel free to ask.
Thanks for using Fixya
Proton
I need the power cord for the HP scan jet 4470c. Where can I buy one.
You can buy it direct form HP or buy it form HP resellers, or buy it from where you buy the unit
Sep 07, 2011 | HP Scanjet 4470c Flatbed Scanner
Scanjet 4470c. Can't get it to work with Windows 7. Any ideas on a solution or is there a Windows 7 driver out there?
Hi ,
I succeeded to make my Scanjet 4470c run in WIA mode under W7 32-bit Ultimate . Should also work with W7 64-bit .
Make sure driver XP ( yes , XP ) is correctly installed .
Then , download and install FreeKapture ( yes , it's free ) from here : http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Load Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanner works fine in this mode but if you choose HP PrecisionScan Pro , program will freeze .
In any case , no slides or negatives scans possible but the rest works .
Regards .
Dec 13, 2010 | HP Scanjet 4470c Flatbed Scanner
Cannot connect hp scanjet 4470c to windows 7
There is no driver for this scanner under W7 but I succeeded to make it work this way :
Make sure driver XP ( yes , XP ) is correctly installed . Then , go to http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html and install FreeKapture , it's free .
Load FreeKapture , clic on Scan and select WIA Hewlett-Packard . Scanner works fine in this mode . If you choose HP PrecisionScan Pro , program will hang .
Regards ,
Nov 27, 2010 | HP Scanjet 4470c Flatbed Scanner
Hi! I need driver for HP 4470c for Windows7 Please Help!
Hi ,
I succeeded to run my Scanjet 4470c under w7 32-bit Ultimate this way :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Open Freekature , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
Regards.
Nov 05, 2010 | HP Scanjet 4470c Flatbed Scanner
There is no driver for the scanjet 4470c that works with my Vista system on my Toshiba laptop.
Hi ,
Vista or W7 , it's the same problem : there are no more drivers for Scanjet 4470c .
I find a way though , to make the mine work in WIA mode under W7 32-Bit Ultimate . Should work with Vista too .
Make first sure driver XP ( yes , XP ) is correctly installed .
Now , download and install Freekapture ( it's free ) from :http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
In any case , no slides or negatives scans possible but the rest works . As for the buttons , only power button will respond .
Regards .
Oct 09, 2010 | HP Scanjet 4470c Flatbed Scanner
I need Windows Vista drivers for scanner hp 4470c. The support product of HP does not have it. Thanks
I checked the HP website - probably just like you did. They do not have drivers for the Scanjet 4470c. Looks like time to get a new scanner... You can list the current model on craigslist - maybe someone would be interested in it themselves.
Sep 23, 2010 | HP Scanjet 4470c Flatbed Scanner
Find doesn't work in acrobat reader (pdf) after
I cane gete because "Find" simply doesn't work (for me?!) in many .pdf documents after updating to the latest Acrobat (around June 2010). I solved this by installing Foxit Reader instead.
Feb 01, 2010 | HP Scanjet 4470c Flatbed Scanner
HP 4470c flatbed
If you can get the software onto your computer, try right clicking on the scanner program--properties--compatability tab--check "run this program in Xp compatability". Worked for me in Vista
Jul 06, 2009 | HP Scanjet 4470c Flatbed Scanner
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
