Question about Canon PowerShot SD600 Digital Camera
Pictures too bright
When i take picture outdoors or in bright light, everything is white.  changing settings does not help.  when taking pics indoors or using the movie setting, it's fine.  please help
  • Canon Master
  • 4,738 Answers
This has happened to me also. You mention that you were changing settings. The symptoms sound like your camera is in a special setting other than "Auto". Examples that would produce such results include Fireworks or Manual. Recommend trying to change your settings one more time:
1. Turn the camera on, and press the FUNC/SET button.
2. Press left or right on your circular dial switch until "Auto" is selected.
3. Press the FUNC/SET button one more time to set the camera to Automatic.
Now take a picture to see if this fixed it.
Posted on May 11, 2008
When i take picture,the picture is white n some time become very very bright, but if take video is ok.
this can be usually associated with your white balance in still camera mode.
Check to see your white balance is set correctly or just set it to auto. Also make sure the mode you are in it set. (ie. indoor, outdoor, auto, speed)
May 04, 2011 | Canon PowerShot A460 Digital Camera
When pictures are taken outside during the day they are unclear with some white horizontal lines and when taken indoors its ok.tried everything the manual said but still no changes
White shadow or white lines may occur if the light was too bright when you take the picture, especially in strong sun light. Have you turn off the flash light when you taking those picture ? If you haven't, then you should try to turn off your camera flash light manually. And I must remind you not to take a picture with your lens faced the sun light or other light (lamp etc) directly. Even if you take a picture outdoors, try to make your lens shaded by something, you can even use your own shadow to shade them.
Hope this help and be kind to rate please.
(^_^)
Jan 08, 2011 | Cameras
My Canon G11 - most indoor pics have a strong yellow-orange hue. What can I do to correct this or is the camera broken?
Light from ordinary light bulbs has a strong yellow-orange cast, which our eyes tend to adjust for without thought. Check the white balance setting on your camera. This is to adjust the camera for the color of the light, to try to make white come out white, hence the name "white balance." Set the white balance to incandescent (light-bulb icon) for indoor shooting under light bulbs, or to automatic to let the camera take its best attempt.
Try experimenting with the white balance setting. Taking pictures in bright sunlight with the incandescent setting will give your pictures a very blue cast, making things look a little colder. There are other settings, such as flourescent.
Sep 19, 2010 | Cameras
Yashica ez digital 6032- 6 mp camera.. i got one sparingly used yashica camera... with above spec... which shows trouble when taking stil pictures outdoors... indoor pictures and video indoors n outdoors...
i am using yashica ez digital 6032 camera but while using SD card of 4GB memory, it is not working. it is asking to format. Pl. help me regarding this problem. Shall i format the camera?
Apr 27, 2010 | Cameras
I cant get into my camera function
From the BlackBerry Curve 8520 Home screen, press the Camera key on the side of the phone > Press the Menu key > Scroll to and select Options > Scroll to and select the desired setting: * White Balance : This setting changes the contrast of the pictures taken to optimal for the listed conditions:
o Automatic: The device automatically adjusts the contrast for each picture.
o Sunny: Ideal for outdoor pictures on a sunny day.
o Cloudy: Ideal for outdoor pictures on a cloudy day.
o Night: Ideal for pictures in low-light conditions.
o Incandescent: Ideal for indoor pictures with incandescent lighting.
o Fluorescent: Ideal for indoor pictures with fluorescent lighting.
* Picture Size: To change the size of pictures taken. Larger pictures require more storage space.
o Large (1600 x 1200)
o Medium (1024 x 768)
o Small (640 x 480)
* Picture Quality: To change the quality of pictures taken. Finer quality pictures require more storage space.
o Superfine: Best quality
o Fine: Medium quality
o Normal: Lowest quality
* Color Effect
o Normal: To take color pictures.
o Black & White: To take black and white pictures.
o Sepia: To take pictures with a sepia tint for an old-fashioned look.
* Store Pictures: This gives you the option to store pictures you take to either the device memory or the media card, if available.
* Folder: To change the default storage location for pictures taken with the camera.
After you adjust your BlackBerry Curve camera settings, pess the Menu key and select save.
Nov 19, 2009 | RIM BlackBerry Curve 8520 Smartphone
Blackberry Pearl - camera stopped taking decent pics
You checked to see if the Color option is set to negative. Either that or the camera is ddead on the phone. Sorry.
If you updated the os on this phone to 4.5 they have been seeing issues with this problem happening on pearls using 4.5.
Dec 31, 2008 | RIM BlackBerry Pearl 8100
Outdoors pictures too bright
I think your ISO setting is very high or is in default.
Please shift it 100 whent you thaking outdoor snaps in daylight or normal indoor light. It will help you to produce a better photograph.
Best wishes.
Nov 30, 2008 | Canon PowerShot A420 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
159 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
