Question about Dynamic Arrow Fastener Co. T50PBN Staple & Gun With Expando Attachment
I have an Arrow JT-21M staple gun. How do I open it to add more staples?
There is no loading trya that pops out. the pusher arm is removable. when that is taken out you slid in the staples and replace the pusher with the locking tooth facing up.
http://www0.epinions.com/prices/Arrow_Fastener_PK21_Parts_Kit_for_JT21M_And_JT21CM_Staple_Gun_Tackers
Posted on Apr 18, 2011
  • ainostef Apr 18, 2011
    sorry for my spelling errors
    *tray
    *slide
Cant open jt27 staple gun to load staples
Hi Maria, I'm sorry you are not having luck with your JT27 stapler. Unfortunately you did not purchase the correct staples for this tool. The JT27 Stapler uses the JT21 staples in a green box. The staples come in 3 different sizes (1/4", 5/16", 3/8"). You can purchase these staples online or at your local Home Depot or Lowe's Store.
As for opening the tool - please see the attached picture for assistance.
May 07, 2015 | Arrow Tools & Hardware - Others
Arrow jt27 staple gun won't load or staple
Everyone here is assuming that you have fully operational gun. I have a business where we use these guns. I can tell you now that 3 out of 5 of the Arrow JT-27 just don't work. The staples won't advance. After looking at the information online, it is probably due to a weak spring. The best solution is to go with a different brand of stapler. This one is just not worth the trouble.
Jan 16, 2013 | Tools & Hardware - Others
Unable to load my Arrow Fastner Model JT-21. Can you help?
is there a problem with it? here is a manual that has pictures. If you have a jam or something, repost what the problem is.
Aug 09, 2011 | Arrow T50P ARROW STAPLE GUN
How to load staples?
    • 1 Push in the push rod plate on the back of the Arrow T50P and press down to unclip the push rod from the gun. Pull the push rod out of the staple channel and away from the staple gun.
    • 2 Insert a strip of staples into the channel with the tips of the staples pointing toward the bottom of the staple gun.
    • 3 Place the end of the push rod into the staple channel of the gun. The end of the push rod has a small, solid piece of metal that fits into the staple channel.
    • 4 Press the rod all the way into the staple gun until the rod plate engages in the notch at the rear of the gun.
Jun 26, 2011 | Arrow T50P ARROW STAPLE GUN
How do you fill JT-21 staple gun? I have JT 5/16 inch staples. I know to fill from the back. I can pull out the little silver thingy in the back so that I can see the long screw. Do I put the staples...
Just pull the spring assembly out completely (silver thingy), slide one full length of staples into the gun, then reinsert the spring assembly until it locks in place. Hope this helps!
Jan 25, 2011 | Hand Tools
My husband got staples stuck in my Arrow JT 21 staple gun. I can't get them to budge, and loading it is a problem. NOthing seems to work. Does anything flip down? The spring is out; staples are stuck...
Its not your husbands fault Truthfuly the gun is a peice of junk it was never made to last they start to rust on the inside and that bindes it all up you have broken springs honestly throw it in the trash and get a new one but spray WD 40 in it this will make it last longer
Dec 07, 2010 | Arrow T50P ARROW STAPLE GUN
Staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
May 26, 2010 | Arrow T50P ARROW STAPLE GUN
Directions for Arrow JT-21 staple gun
The jt 21 is that little red one, I have one in my shooting box, only takes the jt staples, and operates just like any staple gun. Feed it from the back.
Feb 20, 2010 | Hand Tools
My jt 21m stapler is jammed and i cant get it to open
At the end of the stapler opposite where the staplers are driven out is a release. Push it in and turn it should come out with a long spring.
Jun 26, 2009 | Arrow Fastener Co. Lt Duty Staple Gun -...
Dynamic Arrow Fastener Co. T50PBN Staple & Gun With Expando Attachment Logo
1,444 people viewed this question
Top Dynamic Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Dynamic Tool and Hardware - Other Expert? Answer questions, earn points and help others
