Question about 2wire 1800HG Router (RG1800HG00)
Unable to actually connect to the internet?
I have a 2wire 1800HG wireless router that I am using through an ethernet internet connection. It works just fine with my desktop computer but when I connect the wireless connection on my laptop it connects just fine but doesn't is like it isn't actually connected to the internet because it won't let me do anything on the internet in any different programs. I was thinking that it could be the wireless card but my computer works just fine on other wireless networks elsewhere. Please help. Thanks.
  • 47 Answers
Have you tried restarting your router? If not, try unplugging the ac power from the router, wait 30 seconds, and plug it back in. That will usually take care of this problem. If that doesn't work, you can try going into "manage your wireless connections", delete your wireless network from the list, then reconnect to your network.
Posted on May 11, 2008
Xbox 360 wireless adapter wont connect to my 2wire
Have you tried removing all security protocols on the 2wire and trying to connect?
Good Luck!
Jesse
Jan 05, 2010 | 2wire HomePortal 1800HG Router...
Unable to have internet connection with my desktop that is connected to HomePortal (1800HG) by USB but my laptop can connect to internet that is attached to Local Ethernet Connection port; the three green...
Oh my ... This is a question where I dont have to ask for more information.
Pleae connect your desktop to the router using a Cat 5 ethernet cable. I'm not a fan of USB connection for networks ... Ethernet works so much better. Do this even if you have to add a NIC to your computer.
You may find some benefit from using Network Magic, free to download and evaluate. You may like it as much as I do and pay for full extended use NM can perform all your network administrator duties. (I have 5 interconnected networks in my house that connect more than 20 computers)
Thanks for using FixYa.com
Positive comments always welcome
a
Oct 28, 2009 | 2wire HomePortal 1800HG Router...
Ethernet works wirelss is very slow
Most of the wireless adapters connect at a speed of 54mbps max, while wired lan connection adaptors (LAN adapter/cable) works at max of 100/1000mbps. hence use a cable to connect the PC to make it faster than using wireless.
Aug 17, 2009 | 2wire 1800HG Router (RG1800HG00)
How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
The easiest way to connect to Xbox Live without using your pc is to buy a
wireless network adapter for your Xbox.
You would then go into the system settings on the Xbox and configure the settings for your wireless network.
http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
Xbox 360 - direct to internet - No PC.
Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
Ipod touch connection using 2 wire 1800HG
not sure if the 1800hg is the issue log into the router and turn off the encryption temporarily then try to connect the ipod. if the router connects double check your encryption key. if not or it connects for a second and then drops may be the internal security for the router stopping the connection you may have to call 2wire to help you turn off some of the security to keep the ipod connected.
Apr 08, 2009 | 2wire 1800HG Router (RG1800HG00)
I can't hook my computer up to my phone line for internet. I have my router and another desktop hooked up to the phone line through the router.
That modem is in itself a router. However it only has one Ethernet port and no means of broadcasting a wireless Internet Signal which makes its function of a Router somewhat useless. What you need a(n) (wireless) access point. The Access Point will give you more Ethernet slots allowing more computers to be connected to the modem/router via CAT5 (Ethernet) cables. Depending on if you get a Wireless access point or not you might also be capable of using a wireless adapter to connect to the 2wire and get Internet access.
Let me know if I need to clarify any of the points above or if I can assist you further.
Mar 16, 2009 | 2wire 1800HG Router (RG1800HG00)
1800 hg 2 wire wireless
1.can i use my 2wire 1800hg with vista?hooked up to ethernet connection.- yes its possible make sure you enable dhcp on your lan side of you router and under tcp/ip on your pc set it to authomatic assign IP address and dns server address. most router use 192.168.1.1 as thier default address to access it.
to fix your passkey problem.need to access the router and try to change the passkey then save and don't forget to restart the router after you save it,by unplugging it. "make sure your passkey is 8 characters long"
Nov 11, 2008 | 2wire 1800HG Router (RG1800HG00)
Red light
Can any computer connect to the internet?
You said you connected the computer with the cable to the 2wire using an ethernet cord, did it go to the internet?
Do you have a modem connected with the 2wire? (not a computer modem)
Do you have the DSL package or Cable package from Time Warner?
Aug 24, 2008 | 2wire 1800HG Router (RG1800HG00)
Replaced my old 2wire 1800HG with a new one and can't connect it
hi!
first of all, let's try to make the broadband link light turn green. open any browser, go the modem's UI by typing gateway.2wire.net or homeportal/setup on the address bar, follow the onscreen instructions on running the system setup wizard. it should make the broadband link green now. for wireless connection, click on the airport icon, and select on the SSID or network name in the drop down menu. if ssid is not on the drop down menu, click on other. type the SSID in the network name field and wireless security is none. (SSID is the last 3 nos. of the SN)
Apr 22, 2008 | 2wire 1800HG Router (RG1800HG00)
Desktop unable to launch internet explorer
If the laptop is working then your router is probably working correctly. Is the desktop wired to the router or running wireless?
Feb 20, 2008 | 2wire 1800HG Router (RG1800HG00)
2wire 1800HG Router (RG1800HG00) Logo
115 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
