Question about Toshiba 61A61 61" Rear Projection Television
I have the Toshiba 61A61 TV. I am not sure what exactly happened, but when the TV was on, suddenly the picuter went black. I still receive the normal sound, but can't get any picture (totally black). I am assuming it is a picture tube that needs replacement, but again I am only assuming. What may be other reasons that I lost my picture but not my sound?
I have the toshiba tv the picture has color but it has a 3d look to it
Posted on Nov 06, 2010
  • Toshiba Master
  • 8,457 Answers
Check all connections?Unplug,replug the cable box about an hour later let it upgrade it software.The projection lamp has not been replaced in this tv the last 1 1/2 or 2 years?The tv been on and watches at lest 4 or 5 hours a day?Yes,than the projection lamp life is over.Require a new projection lamp.
Posted on Sep 03, 2010
Audio Issue
Hi Sharon,
I have the same exact TV and the same exact problem....except today the screen went black and I no longer get a picture from any source. I've had the TV for exactly 13 months. IF you've had your TV for less time, I'd return it.
Jul 20, 2012 | Toshiba 55G310U LCD TV
The picture went black but we do have sound. It was running perfect and picture was great until it just went black.
If this is a Toshiba 61A61 rear projection. First you have to determine if it has high voltage. You can find this out by looking at the end of each picture tube where the socket is to see if there is an orange glow indicating that the filaments are lit and the set has high voltage. If they are not lit then I know from experience with this set that there is a bad connection on the deflection board where the high voltage transformer is located. The HV transformer has red wires coming out of it. You will have to turn the deflection board upside down and look for the bad connection. But first just tap lightly on the deflection board with the handle of a screwdriver to confirm the bad connection. If the set comes on you will be required to solder the connection with a soldering iron and rosin core solder. Now if the orange glow is there you have bad capacitors on the hyper module. The hyper module is located to the right looking from the back and stands upright and is soldered to the main board. It will be required to unsolder and inspect the capacitors for bulging at the top. The hyper module is likely to not be available anymore. Changing the capacitors will fix the video problem
Nov 11, 2011 | Toshiba 61A61 61" Rear Projection...
Toshiba tv 61a61 screen all red
jeffjo7,
Your unit is 10 years old and more than likely needs the drives adjusted on the blue and green guns. I have a tip at http://www.fixya.com/support/r6814105-adjust_screen_drive_crt_projection_tvs
which explains the process to adjust the screen drives for the best picture.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 14, 2011 | Toshiba 61A61 61" Rear Projection...
Tshow me how replace ir sensor on toshiba tv 61a61
http://www.fixdevice.com/smanuals/file/31211.html
Please find above your service and repair manual, inside it shows you everything you need to know to accomplish this.
It is NOT a difficult task. BUT you will need a soldering iron on some sub chassis. Others use a plug and Wire, and one simply unscrews the old, unplugs from the sub board and replace. Other ones are soldered to a sub board, and need to be removed with a soldering iron. Either way it's a doddle. (Easy to do)
Aug 25, 2010 | Toshiba 61A61 61" Rear Projection...
61A61 TV IS WILL ONLY PICK UP ONE CHANNEL #66 AND NOT CABLE INPUT
Cable companies are slowly but surely reducing the channels you can get without a digital box, which they will supply. You will need to cantact them and rent a HD cable box or converter from them that will work with your displays built-in tuner. However, if your display is HD compatible, then I would just asked your cable company for and non-DVR HD cabe box and connect it to your display with component cables....
May 30, 2009 | Toshiba 61A61 61" Rear Projection...
Lines across screen
I think its an electronic interference problem
Mar 25, 2008 | Toshiba 61A61 61" Rear Projection...
Toshiba no picture
then your optical section has fault.
Mar 17, 2008 | Toshiba 61A61 61" Rear Projection...
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Toshiba plasma tv 42hp94 works good for 20 to 30 minuts and then the screen starts flikering and the pictures go black. once i put a fan behind it the picutes come back ok and tv works good. what could be...
My 42hp83 will only stay on for 30 seconds and then turns off. Repair service came to the house today 2/27/08 and said they could do nothing with it. I think I'll get a second opinion.
Oct 31, 2007 | Toshiba 42HP95 Television
Toshiba 61A61 61" Rear Projection Television Logo
212 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
